Post by svart on May 24, 2014 17:26:06 GMT -6
So i got a crazy deal on a pair of ns10t. Word is they are the home version of the ns10m and may or may not have a slightly different crossover.
Anyone have these?
Post by svart on May 25, 2014 8:10:35 GMT -6
I guess no one eh? I'll report when I get them. Now I need a good power amp. The only one I have is small and used for driving my auratones.
Post by tonycamphd on May 25, 2014 8:51:06 GMT -6
I guess no one eh? I'll report when I get them. Now I need a good power amp. The only one I have is small and used for driving my auratones. Pick up an adcom 545 or 555, u can get em for a song, and with ur skill set, u could dial it into an unobtanium quality level! IMO
Post by svart on May 25, 2014 9:30:33 GMT -6
Ah good suggestion. I found one for like 90$ broken on ebay. I'll see how my 70W LM3886 amps do on these before going to the Adcom 545 which is only 100W. I don't plan on driving these beyond 85dB anyway, so barely loud.. Really I only need the power for making the drivers reasonably reproduce instantaneous transients.
Post by svart on May 30, 2014 20:38:32 GMT -6
Well, I got my NS-10T pair today. Yep, they're NS-10s. Sound pretty much identical except the bass is a little more boomy due to the larger box. I might glue a piece of 2x4 inside the boxes to get the volume back down to the size of the NS-10M but otherwise, I'm painting the horrid wood grain and putting them up on the console with my JBLs and Auratones. Now I have the gamut of monitors.
I pulled up the mixes for the band I've been recording and listened through the NS-10T's. I have to say that I found a couple little spots that needed some cuts but other than that, I was pretty spot-on using the JBL/Auratones. The NS-10 set did help me with the low end a bit. I've heard of the "flab" that can happen if the bass region in a mix is sorta messed up and these NS-10's found that pretty quick. A small cut in the lows on the bass guitar set that straight.
And yes, these sound absolutely terrible, but my mix sounds wonderful elsewhere.
Seems like my gainclones worked OK. I might still try the Adcom solution, but I read from a few sources that sometimes they don't play well with NS-10s.
I also took the speaker apart and checked out the crossover. The NS-10M studio version used 2x 2.7uF caps in parallel to make 5.4uF. These have a single 4.7uF cap. The inductors look similar but it's impossible to tell if they are the same without comparing with an LCR meter.
Post by tonycamphd on May 30, 2014 21:14:18 GMT -6
Well, I got my NS-10T pair today. Yep, they're NS-10s. Sound pretty much identical except the bass is a little more boomy due to the larger box. I might glue a piece of 2x4 inside the boxes to get the volume back down to the size of the NS-10M but otherwise, I'm painting the horrid wood grain and putting them up on the console with my JBLs and Auratones. Now I have the gamut of monitors. I pulled up the mixes for the band I've been recording and listened through the NS-10T's. I have to say that I found a couple little spots that needed some cuts but other than that, I was pretty spot-on using the JBL/Auratones. The NS-10 set did help me with the low end a bit. I've heard of the "flab" that can happen if the bass region in a mix is sorta messed up and these NS-10's found that pretty quick. A small cut in the lows on the bass guitar set that straight.And yes, these sound absolutely terrible, but my mix sounds wonderful elsewhere. Seems like my gainclones worked OK. I might still try the Adcom solution, but I read from a few sources that sometimes they don't play well with NS-10s. I also took the speaker apart and checked out the crossover. The NS-10M studio version used 2x 2.7uF caps in parallel to make 5.4uF. These have a single 4.7uF cap. The inductors look similar but it's impossible to tell if they are the same without comparing with an LCR meter. i'm glad to hear this, i kinda noticed that in the latest parking lot mix, I didn't want to be a pita and say something, post up the new mix when you can, i'd love to hear it!
Post by svart on Jun 1, 2014 0:01:49 GMT -6
So I really didn't like the wood grain..
Post by jimwilliams on Jun 1, 2014 11:32:09 GMT -6
Yamaha crossovers are pretty bad quality. I used to replace those caps and coils way back in the 1980's ,when they were more universally used. A quality 4.7 uf film cap like a Rel-Cap RT does the trick. Add a .01 uf RT 600V as a bypass. Then, remove the iron cored coil and measure it's DC resistance and inductance on a meter. Swap it to a copper foil inductor as made by Aries or Solo, (available from www.michaelpercyaudio.com) and hear what that crap crossover has been filtering out for you.
