Post by craigmorris74 on Mar 29, 2022 19:59:15 GMT -6
Curious to see if anyone had tried it out yet. Usually their stuff is fantastic.
Post by bossanova on Mar 29, 2022 21:16:34 GMT -6
I have not. I’d be interested to know if it’s an algo or based on IRs. Plate IRs are really hard to get right for all sources, IMO. I think Valhalla Plate is still the gold standard for a “plate” that’s fully flexible and tweakable, especially in the context of a mix. That said, everything I’ve used by Fuse is highly impressive.
Post by Deleted on Mar 29, 2022 21:35:56 GMT -6
Bought without even trying it. I always find a use for all fuse. Totally killer stuff from Ray Dratwa. right now I'm loving the VQP and TCS-68
Post by kcatthedog on Mar 30, 2022 1:07:44 GMT -6
$29, kind of a no brainer .
Post by craigmorris74 on Mar 30, 2022 6:38:01 GMT -6
$29, kind of a no brainer . That's kind of what I thought, but the demo isn't knocking me out. Right now it's reminding me of a plate where the tension has slipped and needs a tune up. Maybe I don't have have it set up to get the most out of it?
Post by kcatthedog on Mar 30, 2022 7:13:51 GMT -6
Fair enuff, I have a number of good plates plugs already, thought this was good if someone had none ?
Post by craigmorris74 on Mar 30, 2022 11:02:54 GMT -6
Fair enuff, I have a number of good plates plugs already, thought this was good if someone had none ? I'm sure it is. I always expect Fuse stuff to be a notch above the competition, so maybe I'm not using it right.
Post by deaconblues on Mar 30, 2022 11:21:21 GMT -6
$29, kind of a no brainer . That's kind of what I thought, but the demo isn't knocking me out. Right now it's reminding me of a plate where the tension has slipped and needs a tune up. Maybe I don't have have it set up to get the most out of it? I kinda dig the scuffed, lived-in feel of this one vs some of the others in my collection. I was doing beta for this and another company’s more clean plate at the same time, and I kept coming back to this one, even just for the grind of slamming the limiter. When I tried using the cleaner ones, they felt tighter but a bit more boring. Obviously, a lot of this comes down to the type of material you work on.
Post by deaconblues on Mar 30, 2022 12:49:13 GMT -6
I have not. I’d be interested to know if it’s an algo or based on IRs. Plate IRs are really hard to get right for all sources, IMO. I think Valhalla Plate is still the gold standard for a “plate” that’s fully flexible and tweakable, especially in the context of a mix. That said, everything I’ve used by Fuse is highly impressive. Got you an answer....from Raymond: The early portion of the response is generated using an IR, the tail is generated using an algorithm that simulates the response and the decay profile of a real plate which also allows for arbitrary decay times. So to sum this up: It’s a hybrid approach.
Post by the other mark williams on Mar 30, 2022 12:54:35 GMT -6
I have not. I’d be interested to know if it’s an algo or based on IRs. Plate IRs are really hard to get right for all sources, IMO. I think Valhalla Plate is still the gold standard for a “plate” that’s fully flexible and tweakable, especially in the context of a mix. That said, everything I’ve used by Fuse is highly impressive. I remember really liking the LiquidSonics Plate plugin back when I had the Slate subscription. Have thought about buying it outright on several occasions, but haven't done it.
Post by Johnkenn on Mar 30, 2022 16:46:33 GMT -6
The Sunset IK plug is not very tweakable, but has a really nice plate.
Post by bubblejackets on Feb 25, 2024 21:35:55 GMT -6
Just bought this (sale for $20 ends tonight). Liking the drive and width knobs.
Post by bikescene on Feb 25, 2024 22:40:59 GMT -6
Just bought this (sale for $20 ends tonight). Liking the drive and width knobs. Thanks. I passed on the last few sales but grabbed it this time.
Post by jaba on Feb 26, 2024 7:20:15 GMT -6
I like all things Fuse so yes, their plate is great. Doesn't sound like the real one I've used but none do and I imagine most physical plates vary in sound as well. Said that, I can't say I like it a whole lot more than other options I've used.
FWIW I find myself using the Fuse spring (305) a lot more. It's not sproingy and has a bit of plate-ish sound to it. Fits beautifully in a mix.
Post by drumsound on Feb 26, 2024 9:02:45 GMT -6
I like all things Fuse so yes, their plate is great. Doesn't sound like the real one I've used but none do and I imagine most physical plates vary in sound as well. Said that, I can't say I like it a whole lot more than other options I've used. FWIW I find myself using the Fuse spring (305) a lot more. It's not sproingy and has a bit of plate-ish sound to it. Fits beautifully in a mix. I need to remember I have the spring and use it more often...
Post by jaba on Feb 26, 2024 10:44:27 GMT -6
I like all things Fuse so yes, their plate is great. Doesn't sound like the real one I've used but none do and I imagine most physical plates vary in sound as well. Said that, I can't say I like it a whole lot more than other options I've used. FWIW I find myself using the Fuse spring (305) a lot more. It's not sproingy and has a bit of plate-ish sound to it. Fits beautifully in a mix. I need to remember I have the spring and use it more often... It's a great reverb, spring or not.
Post by drumsound on Feb 27, 2024 8:44:15 GMT -6
I need to remember I have the spring and use it more often... It's a great reverb, spring or not. I put the spring on a mix yesterday and it did just what I wanted. If I didn't have 3 plate plugins already, I'd probably look into their plate.
