Post by kcatthedog on Mar 17, 2022 5:41:30 GMT -6
Can I create mono aux or busses, mine seem to default to stereo?
Post by wiz on Mar 17, 2022 5:50:14 GMT -6
Can I create mono aux or busses, mine seem to default to stereo? Click on the double circle
Post by kcatthedog on Mar 17, 2022 6:05:08 GMT -6
Thx Wiz yes I know that! It’s weird I can make aux mono but in me headphones it’s panned left, not certain why. I am experimenting with adding ob to my mix and hsve found the Aurora n control software not intuitive. I have utility io on my mix buss feeding my ssl comp, am sending snare and kick to outs directly and to my wa76, Was experimenting with sending bass to another ob comp but have the mono panned left issue. I’ll make stronger coffee !
Post by enlav on Mar 17, 2022 6:48:53 GMT -6
I am experimenting with adding ob to my mix and hsve found the Aurora n control software not intuitive. Don't say that! I just got my order in on one!
That noted, let's pretend your Aux out is going to Output 7... Can you assign output 7 to both sides of your headphones in Aurora N Control? Otherwise, without knowing much about Logic, you'd presumably want to send out that Mono Aux master to Channels 7 and 8 instead. It could still be a mono Aux, just routed to two outputs.
Post by kcatthedog on Mar 17, 2022 7:08:00 GMT -6
I love the Aurora N sound , the sd disc, will never use, it should be a module so you could not get it at all and lower price .
N control works by clicking on what you want the output to be, but I still have trouble grasping it. My symphony mkii gui with ob and logic utility I/o worked perfectly straightforward , I can get 1 stereo pair working with Aurora , then normally problems start.
I know there are others here on usb for whom Aurora n gui worked fine for ob, not for me on tb3.
Post by enlav on Mar 17, 2022 8:29:30 GMT -6
Did the routing trick work for your mono headphone mixes?
