Post by jcoutu1 on May 20, 2014 15:19:43 GMT -6
Well, I skipped the Sta for now and grabbed one of these. Stereo matched, linkable, dual LA-2A. Is it going to sound like a vintage LA-2A...probably not. Will it sound good...I hope so!
Anyone used one of these?
Post by nico on May 20, 2014 15:58:34 GMT -6
No but I'd like to know experiences with it as well, some soundbytes would be awesome!
Post by cowboycoalminer on May 21, 2014 3:26:44 GMT -6
Yes sir, used them. Sound great. I'm sure you'll be pleased.
Post by jcoutu1 on May 21, 2014 5:26:04 GMT -6
Yes sir, used them. Sound great. I'm sure you'll be pleased. How did it compare to an LA2A? I've seen people saying that it sounds more like the LA on the LA610, but I imagine those people ate listening with their eyes and not their ears. The circuit doesn't look like the LA610 from an amateur prospective. I expect that it'll be here early next week and I have 30 days to evaluate, so it'll be put through it's paces nicely.
Post by Johnkenn on May 21, 2014 7:55:45 GMT -6
I thought the T4 optos were the same ones from the LA610's and not the LA2A's...I think that was the "knock" on them...
Post by jcoutu1 on May 21, 2014 8:41:49 GMT -6
I think that it's the transformers that are different, not the optos. According to this video, they have LA3A transformers. They also say that there is fast and slow T4's, but they didn't end up putting in the fast setting, so it only has the standard LA2A slow T4. When I get it in, I'll pop the top and have svart and unit7 take a peek at the guts. I'm sure that they could get an idea of what it looks like in there. I picked it up from Guitar Center, so I get the 30 days to play. I just gotta decide if the hardware is $3000 better than my Waves and IK LA2A emulations.
Post by svart on May 21, 2014 8:56:00 GMT -6
I bought my T4 for 75$ from JBL directly before they stopped selling them to consumers making clones and selling them..
Anyway, yes, I'd love to take a look inside and see what's going on. Should be relatively simple to know what's happening. IMHO, I don't think the transformers make a *huge* difference in the sound. The originals were so good that it was hard to saturate them. Other folks might have a different idea, but I think the majority of the sound comes from the T4 response and the type of valve circuit being used.
If you wanted to try that theory, you can do what I did and use an XLR-to-XLR pad and knock the output down a bunch. That way you have to turn up the internal gain and get the output transformer warmed up!
Post by jcoutu1 on May 21, 2014 9:05:24 GMT -6
I have to imagine that this unit is actually pretty good and just got a bad rap because it looked like the LA610 and not a vintage Teletronix unit. Here is some info and pic that I found on the UA site. Not sure if you can tell anything from here... Replacing Tubes: 2-LA-2 These units require changing four 12AX7 tubes at locations V3/V4/V8/V9, two 12BH7 tubes at locations V5/V10, and two EL84 tubes at locations V2/V7. Locations V2 and V7 are not marked on the main board (these are location designators listed in the schematics). The EL84 – V2/V7 sockets are located to the left of the T4 cells at locations T7/T9. www.uaudio.com/media/blog/2012/05/tube_14.jpgInfo is from here... www.uaudio.com/blog/support-report-tubes/
Post by nico on May 21, 2014 9:09:23 GMT -6
great info...a little audio whenever you have the time would be great though hell a LA610 - 2-LA-2 - orig LA-2a - reissue LA-2a roundup would be saucy regards, Nico
Post by svart on May 21, 2014 9:31:02 GMT -6
The 12BH7 is a good sign. Those were used in the original as the output driver, whereas the LA610 did not use them and suffered for it. The EL84 is different from the original LA2A, I assume they use it to replace the more rare 6AQ5 that was in the sidechain of the original LA2A since they are similar.
Post by jcoutu1 on May 21, 2014 9:46:27 GMT -6
great info...a little audio whenever you have the time would be great though hell a LA610 - 2-LA-2 - orig LA-2a - reissue LA-2a roundup would be saucy regards, Nico I'll get some audio samples posted when it comes in. I thought about grabbing a LA610 at the same time and returning it so I could do the comparisons, but the preamp stage of the LA610 can't be bypassed. I don't have access to an original or reissue LA-2A unfortunately. I will shoot it with my Retro Doublewide and Thermionic Culture Phoenix for sure though. Maybe even my old Joe Meek VC1 for shits and giggles.
Post by svart on May 21, 2014 10:57:28 GMT -6
Don't get too hung up on comparison. The originals had 10-20% components and could vary wildly in their sound. The LA2A is a vibe device, you aren't looking for a specific texture but just the overall vibe.
Post by nico on May 21, 2014 15:25:19 GMT -6
[/quote]I'll get some audio samples posted when it comes in. I thought about grabbing a LA610 at the same time and returning it so I could do the comparisons, but the preamp stage of the LA610 can't be bypassed. I don't have access to an original or reissue LA-2A unfortunately. I will shoot it with my Retro Doublewide and Thermionic Culture Phoenix for sure though. Maybe even my old Joe Meek VC1 for shits and giggles.[/quote] looking forward, awesome, thx
Post by Ward on May 23, 2014 6:35:14 GMT -6
I have one also, modded by some guy in NYC to match the LA2a spec. They are seriously awesome, modded or stock. They need at least 30 minutes warm up time to start sounding right. And with regards to the output driver tubes, an EL84 is a 6BQ5... really not that different to a 6AQ5. It's nice that this is used as 6BQ5/EL84 valves/tubes are readily available...so retubing doesn't become much of an issue. They're also the first to go south so you need to watch them and smell them. If they start glowing more red than orange, it's time to replace them. If they start smelling like a VOX AC30, it's time to replace them... but then you can use the 'spent' EL84s for another 300 hours or so in your Vox amp! If you start hearing some guitar amp like overload when you turn the make-up gain past 5, it's time to replace them... unless you're looking for crunchy vocals.
UA should have marketed the heck out of these instead of canceling them. Usually found for $2500, they are one serious bargain!! But I guess selling full-size mono LA2aunits at $3700 a pop is more profitable.
Post by jcoutu1 on May 23, 2014 7:13:26 GMT -6
Hey Ward, thanks for the great info. I'll make sure to give it some decent warm up time before diving in. Looks like I won't be able to pick it up until next Thursday though, then I'm immediately leaving for vacation. The timing couldn't be much worse. Ohh well.
Post by Ward on May 23, 2014 8:24:38 GMT -6
Then let me save you some time....
When you get it installed, get a source or program material running into a pre or line source and get it to the nominal digital zero for average (-18DbFS). Then patch that into one channel of the 2LA2. set gain reduction at zero, set it to 'compress', adjust makeup gain so that it comes back into the system at nominal zero. Then start slowing bringing up 'peak reduction' until you can 'feel' it. Adjust makeup gain to keep the output at nominal zero. Now repeat the process with it switched to 'limit' mode.
You have just completed the learning curve of a 2LA2, same as any old LA2a. Favorite setting for me: for vocal, acoustic instruments or anything else is peak reduction at 3.5, compress mode, make-up gain at 4.5-5.5
There's really nothing else.
Post by Martin John Butler on May 23, 2014 8:33:35 GMT -6
Congrats jcoutu1, I'm looking forward to hearing about your impressions.
When I looked up the 2 LA-2. (I didn't know what it was), I also got lots of LA-2 and LA-610 links at eBay. After looking at the prices, I'm even happier I have the UAD LA2 plug, as I sure can'r afford that kind of kit.
Post by Ward on May 23, 2014 8:41:19 GMT -6
Regarding an LA2 'plug'. Take a picture of a bald man. Print it out. Take a black sharpie and color in 'hair'.
That's what a plug-in is like.
Post by jcoutu1 on Jun 19, 2014 21:22:19 GMT -6
Well, turns out is going back. The sides aren't matched, knobs or action. I set the inpyt levels to each side with a test tone, then set gr for each side, then run a duplicated vocal through both sides. Not matched at all, linked or unlinked. Just totally off.
Post by mulmany on Jun 19, 2014 21:35:15 GMT -6
Well, turns out is going back. The sides aren't matched, knobs or action. I set the inpyt levels to each side with a test tone, then set gr for each side, then run a duplicated vocal through both sides. Not matched at all, linked or unlinked. Just totally off. How is it as a la2a?
Post by jeromemason on Jun 19, 2014 21:41:22 GMT -6
Well, turns out is going back. The sides aren't matched, knobs or action. I set the inpyt levels to each side with a test tone, then set gr for each side, then run a duplicated vocal through both sides. Not matched at all, linked or unlinked. Just totally off. Man that sucks..... Is it calibrated with a variable resistor like an 1176?
Post by jcoutu1 on Jun 19, 2014 21:50:56 GMT -6
Well, turns out is going back. The sides aren't matched, knobs or action. I set the inpyt levels to each side with a test tone, then set gr for each side, then run a duplicated vocal through both sides. Not matched at all, linked or unlinked. Just totally off. Man that sucks..... Is it calibrated with a variable resistor like an 1176? I don't know enough about it to answer. I'm under the impression that maybe the T4's haven't aged equally causing them to react differently. I'm sure that it could be usable for mono sources and/or by trying to get the sides close enough tonally, but I'm looking for something quick and easy, ya know? Plus, my resale value won't be there if I need some cash quick, so it's gotta go.
Post by Deleted on Jun 19, 2014 22:28:44 GMT -6
Regarding an LA2 'plug'. Take a picture of a bald man. Print it out. Take a black sharpie and color in 'hair'. That's what a plug-in is like. Ward - that is the best line ever!
Post by jeromemason on Jun 19, 2014 23:10:40 GMT -6
Post by Ward on Jun 20, 2014 7:20:54 GMT -6
Regarding an LA2 'plug'. Take a picture of a bald man. Print it out. Take a black sharpie and color in 'hair'. That's what a plug-in is like. Ward - that is the best line ever! Thanks, but I think I only said what a lot of others are thinking...
