Post by kcatthedog on Jan 26, 2022 12:08:08 GMT -6
Copied from Drew’s post at UA forum.
UniversalAudio said:
8 Minutes Ago
LUNA 1.2.5 is out! Get it in-app!
LUNA v1.2.5
NEW Quantize Audio
- Audio clips can now be quantized to the grid using the Quantize command
- "Q" button now appears on audio clips. Click to access the Quantize browser.
- All existing Quantize browser features now function for transients by snapping the audio event nearest to the grid into alignment
- New "RANGE" control specifies the area around a grid value within which events will be quantized, allowing control over the extent of quantization (RANGE control has also been added for MIDI quantize operations)
- New group Track Priority feature allows quantization to be driven by specified tracks in a selection or group, ensuring that desired instruments in a multi-microphone recording are snapped to the grid, while preserving phase alignment on related tracks
See here:
NEW Align Grid Command
- Use Align Grid to calculate a tempo map to the cursor position at a resolution matching the current grid setting
- Option + Command + I: Align Grid
- Shift + Option + Command + I: Align Bar
IMPROVED Significantly improved performance for Razor Blade and UA Polyphonic warp algorithms
IMPROVED Sidechain input assignment is now assignable for groups of tracks when the track group MIXING option is enabled
FIXED Resolved an issue that could cause playback of MIDI Pitch Bend data to sound different than when originally performed
FIXED Resolved an issue that could prevent some LUNA Extension and UAD Instruments presets from reloading correctly
FIXED Resolved a crash that could occur when downloading instruments to an external drive on M1 Mac computers IMPROVED
FIXED Resolved an issue that could cause undo queue issues after writing automation from a control surface
FIXED Resolved an issue that prevented Command + Clicking the Console alias in the INSERT mixer row from toggling between Enabled / Disabled
FIXED Resolved an issue that caused some characters to be silently dropped from an exported file name
FIXED Resolved an issue that prevented all tape slots from updating when holding Option and toggling Tape power in the mixer
FIXED Resolved an error message that could occur when loading Audio Units plug-ins made by Neural DSP
