Post by kcatthedog on Dec 6, 2021 8:05:46 GMT -6
Trying the demo anyone got it working on an m1 , website says there could be problems ?
I downloaded and installed but first open seems to be going to the cloud or something ?
Post by mcirish on Dec 6, 2021 10:54:26 GMT -6
I'm on PC Windows 10. Works fine there but I know that it doesn't work on Windows 11 at all. I'm not really sure why it takes them so long to do updates for current operating systems. Maybe the fix for M1 is coming this month. They said Windows 11 support should be this month but could get pushed back.
Post by kcatthedog on Dec 6, 2021 11:41:55 GMT -6
I could try it on my mbp which is running Catalina just hate the screwing around.
Post by plinker on Dec 6, 2021 13:46:37 GMT -6
I have it working on my M1 Mini. It's good enough for now. Some problems:
- Sometimes, the Apple sound preferences will stop recognizing it...just stops seeing it...so suddenly sound isn't being calibrated by SW. - The toolbar icon has only the current preset visible, so you have to go into the application to change to another one. Reference 4 didn't have this bug. - The DAW plugin has startup settings for the Wet/Dry mix at 100% Dry, and the output volume so low that you can't hear anything. It's an easy fix, but not so easy to spot -- lost some more hair on that one!
Good luck! It's certainly more stable on M1/Monterey than Reference 4.
Post by kcatthedog on Dec 7, 2021 11:16:34 GMT -6
I got my measurements done, but I don't hear any difference in logic on my headphones or speakers when I enable or unable.
SW4 was simple to set up IDR seems less so, any tricks for getting it working in logic ? I reached out to SW CS but so far their instruction have not helped.
Post by Guitar on Dec 7, 2021 11:28:20 GMT -6
I'm on Windows 10. The VST plugin works fine for me, in Cubase. The system wide software is buggy as hell and has been for months worth of updates. But I love the sound and use it anyway. Windows 11 is a non starter.
Post by plinker on Dec 7, 2021 11:49:39 GMT -6
I got my measurements done, but I don't hear any difference in logic on my headphones or speakers when I enable or unable. SW4 was simple to set up IDR seems less so, any tricks for getting it working in logic ? I reached out to SW CS but so far their instruction have not helped. If you're not already, you need to use the plugin with Logic. It functions about the same as the standalone application. I'm also using the plugin with Logic Pro -- see my previous post about correcting the default wet/dry blend and volume in the plugin. Also, it's probably fine to reuse the SW4 room correction in IDR -- that's what I did, and it's working like it did with SW4. Please let me know if they recommend shooting the room again for IDR.
Post by kcatthedog on Dec 7, 2021 16:48:23 GMT -6
I never used the system wide service only plug in in daw. I had all previous versions just find the new set up more cumbersome and not well explained.
I was just watching a set up video and think I identified a missed step: I’ll check.
It’s all the set up fucking around I hate and more money for , for me many useless new features. I only care about the freq response correction, that is really all SW’s does, no time domain analysis and correction.
SW is a one trick pony that should be easy to set up: to me the website has gotten taken over with marketing come hither verbiage: tedious.
Post by plinker on Dec 7, 2021 17:59:10 GMT -6
Yep!
The correction is fantastic. I'm not sure I can listen anymore without it.
Everything else is PITA BS...
Post by kcatthedog on Dec 7, 2021 19:07:03 GMT -6
I seem to have it working,
