Subs
May 7, 2014 10:46:16 GMT -6
Post by Johnkenn on May 7, 2014 10:46:16 GMT -6
So - this is kind of me free associating from several other threads regarding mixing...I started one about how I mixed something for a guy with zero equipment and plugs and I pulled it up at home and it sounded freaking awesome....Anyway, I've had a sub here with my ProAcs since I've had them. They need it for "satisfying" playback...but maybe I've been making a mistake mixing with them. I can defeat the sub with a pedal and just depress the pedal to check...I think that's what I'm going to start doing for all my mixes. Makes me work harder...
Thoughts?
Post by nico on May 7, 2014 11:42:33 GMT -6
Depending on how low your ProAcs go and how well you can hear this low in your room, activating the sub for removal of low freq hum/ any kind of disturbances you don't want may be a good start, then deactivate after the check if you prefer, and put them up once in a while to check the lows?
Post by svart on May 7, 2014 11:52:53 GMT -6
I don't mix with a sub. I found it really messed me up more than without it. I think too many folks actually try to get too much low end in their mixes. Most "deep" low end these days is actually psychoacoustic, being made up by harmonics in the upper ranges.
Read up on "missing fundamental" mixing.
Subs
May 7, 2014 12:52:12 GMT -6
Post by matt on May 7, 2014 12:52:12 GMT -6
So - this is kind of me free associating from several other threads regarding mixing...I started one about how I mixed something for a guy with zero equipment and plugs and I pulled it up at home and it sounded freaking awesome....Anyway, I've had a sub here with my ProAcs since I've had them. They need it for "satisfying" playback...but maybe I've been making a mistake mixing with them. I can defeat the sub with a pedal and just depress the pedal to check...I think that's what I'm going to start doing for all my mixes. Makes me work harder... Thoughts? I am getting rid of my mono KRK 10" sub, in favor of going 2.2 with my BM5As and a soon-to-arrive pair of BM9S subs. I will set them up at ear-level, effectively creating a 3-way system with no center sub. I think that the KRK, being under-desk and only decoupled from the floor with a stabilizer, is giving smeared, indistinct low-end info. I am always second-guessing the level of information below 100hz. It's been bumming me out. I also need to treat my room; this is next.
Post by dandeurloo on May 8, 2014 22:38:58 GMT -6
Subs are tricky to get to work properly. Honestly, if you have a great power amp you Proac's don't need a sub. It's probably causing more problems then it's worth. I have never regretted ditching my sub!
If I want subs I will get a bigger 3way system in my new space.
Subs
May 11, 2014 17:33:36 GMT -6
via mobile
Post by littlesicily on May 11, 2014 17:33:36 GMT -6
Subs are tricky to get to work properly. Honestly, if you have a great power amp you Proac's don't need a sub. It's probably causing more problems then it's worth. I have never regretted ditching my sub! If I want subs I will get a bigger 3way system in my new space. I find the proacs to be lacking in the lows, my subs seem to help. Not a perfect room by any stretch. Your comment has me thinking though.
Subs
May 11, 2014 20:09:25 GMT -6
Post by Deleted on May 11, 2014 20:09:25 GMT -6
Just my humble .02.
I hated a sub setup the normal way with the typical crossover point. I find it useful when I let the monitors do all they can and then base the crossover on their deficiency. In my case, I have the sub crossed at 50hz. I realize it may seem weird, however, it seems to be working great.
Subs
May 11, 2014 21:49:46 GMT -6
Post by jeromemason on May 11, 2014 21:49:46 GMT -6
When I had my Proacs I tried a sub, but never could make it translate. Do you have the Proacs up against the wall? I moved mine near about touching against the wall and they produced much more lows. Just a thought.
Subs
May 11, 2014 23:12:39 GMT -6
Post by littlesicily on May 11, 2014 23:12:39 GMT -6
Reid Shippen told me he runs his Proacs full range w/ a sub. That's what I've been doing. as well.
Subs
May 11, 2014 23:59:02 GMT -6
Post by winetree on May 11, 2014 23:59:02 GMT -6
I've found with SUBS, you have to make sure they are time aligned with the speakers. Meaning all diaphrams are in the same vertical plane. The early or late arrival of the sub info can cause problems in the listening position. They should also be centered between the speakers, off in a corner may work for home theater, but not mixing. All speakers should be phyically isolated. This seems to work for me.
Subs
May 12, 2014 7:07:15 GMT -6
Post by Deleted on May 12, 2014 7:07:15 GMT -6
Full-range monitoring is critically important. I've heard so many mixes with waaaay too much low end, simply because the mixer was compensating for what his own monitors wouldn't show. Besides the artistic part, subs will help you hear traffic, mic-handling issues and other noises in the room. Adding subs will accentuate the problems you might have with room modes. So before adding subs, treat the room. Spending a few Franklins on some Aurolex or other solutions (bass traps, diffusion, etc) will make a bigger difference than spending more on monitors.
But assuming your room is under control, a decent well-calibrated sub is important. You need to be able to get down to 30Hz or so. I don't think there's much that's musically useful down there (organ music excepted) but there's a possible world of hurt that you need to deal with. You can always grab a pair of NS-10s or some old Horrortones to see how well the mix translates.
Subs
May 12, 2014 7:33:55 GMT -6
Post by tonycamphd on May 12, 2014 7:33:55 GMT -6
My new monitoring system is as follows, my trusted Mackie hr 824's, DIY proAc's, DIY auratones and DIY 2-10" subs, JW modded adcoms gfa 555, still need to load speakers in tones and Ac's, set up on speaker switching of some sort, sub will be used for fun and problem revelation as expo suggested
Post by Bob Olhsson on May 12, 2014 12:56:40 GMT -6
I was one of the first people I know to adopt subs in the mid 1970s. I played with every configuration imaginable for twenty years ending up with the placement of dual sealed subs directly under the speakers aligned with several different flavors of measurement tools including time delay spectrography.
Then I got my Duntech Sovereigns which go down to 27 Hz. for the mastering facility in San Francisco that never got built. The difference in translation put my jaw on the floor. In hindsight, I think when full range speakers aren't available, headphones are a better way to find out and fix what's going on below 50 than a sub is. My mentor in motion picture post had the same experience trying to mix films using subs or even worse, "bass management" rather than full range speakers.
Subs
May 13, 2014 17:00:01 GMT -6
Post by scumbum on May 13, 2014 17:00:01 GMT -6
I am no pro mixer.......but I didn't like using a sub . When I wanna check the low end to make sure its right , I go for a drive in the car and check it against other Pro CD's . The car stereo for me is the best test there is .
Post by donr on May 13, 2014 17:47:14 GMT -6
I had nothing to contribute to this thread until I realized that before speakers got so good in the headroom dept, you could find out where your mix was too hot by just cranking the volume on your monitors. Whether is was Altec 604's or JBL 4310's or 4311's, when mixing, you could just crank the level 'till something folded, then you knew if the bass was too heavy, or the top end. When the whole speaker folded across the spectrum, the mix was balanced. At least for the end user!
Amended to say the treble in my experience was never the question. It was ALWAYS about how much bass you had, and could support with the speakers. And the speakers would tell you, when it got loud. When the mix was balanced, the speakers distorted when you pushed them but it was still musical, in an 80's car stereo/boombox/carnival/ghetto sense.
Subs
May 13, 2014 21:40:19 GMT -6
Post by Johnkenn on May 13, 2014 21:40:19 GMT -6
Bob Olhsson's Duntech reference led me to a google search which led me to some list of the top 25 audiophile monitor/speakers... I had no idea there were speakers that cost $176,000...Wilson Audio? Man...it's good to be rich
Post by Bob Olhsson on May 14, 2014 14:01:33 GMT -6
Just because speakers are expensive doesn't automagically make them good.
Subs
May 14, 2014 16:02:45 GMT -6
Post by wiz on May 14, 2014 16:02:45 GMT -6
Just because speakers are expensive doesn't automagically make them good. There is a whole industry predicated on the fact that they do..... 8) cheers Wiz
Post by tonycamphd on May 14, 2014 16:44:18 GMT -6
Just because speakers are expensive doesn't automagically make them good. There is a whole industry predicated on the fact that they do..... 8) cheers Wiz Did you mean to say "there is a whole industry predicated on the idea that they do....."
Subs
May 14, 2014 17:03:07 GMT -6
Post by tonycamphd on May 14, 2014 17:03:07 GMT -6
For about $700, I'm building a pair of proAc knock offs that "should" sound better(or at least be more accurate) than the originals based on putting in the absolute top of the line components and a super accurate/sensitive scanspeak paper n pulp drivers, the analysis plots show them to be really accurate, and the designer says he had high expectations, and they do not disappoint, now whether they will be a joy to listen to in my world.... remains to be be seen? but here's to hoping and saving around $1,400!
I know my lowly and completely understood mackie hr824's will be along side of them until i feel comfortable setting them free 8)
