Post by kcatthedog on Sept 15, 2021 15:28:46 GMT -6
LUNA Release Notes
Note: LUNA Recording System is available for Mac only.
Related Information
LUNA System Requirements
LUNA User Documentation
Download LUNA
Tip: To get the latest version of LUNA, choose "Check For Updates..." under the LUNA menu in any previous version of LUNA.
Version 1.2
September 15, 2021
New
Sidechain Input
New Sidechain utility feature allows assignment of a persistent sidechain input per track/bus
Sidechain directly from Console emulations (API Vision Channel Strip / API 2500) or any capable Audio Units plug-in
Sidechain trim allows you to adjust the sidechain source track level
Sidechain Solo allows you to temporarily listen to the sidechain source
MCU Control Surface Support
Control LUNA using any control surface that implements the Mackie Control Universal protocol
Configure up to 6 MCU compatible control surfaces on the new CONTROLLERS tab of the SETTINGS page
Dedicate a single fader controller as a "Focus Module" that always follows the LUNA Focus Channel based on track selection
Use your surface to change volume and pan, toggle mute, solo, and record enable for every track in your session
Spill Bus track sources onto the surface using the record enable button
Change automation modes for selected tracks so fader moves can easily be recorded during playback
Control LUNA's transport controls and toggle looping and click
Access many additional controls using common surface features like zooming, scrolling, and much more
Click here to learn more
Improved
LUNA v1.2 will automatically install iLok License Manager 5.4
Copy to CUES and Copy to SENDS command now works based on the track selection instead of all tracks
Using keyboard shortcuts to extend the track selection now scrolls the timeline view when necessary
Focus Channel now shows the last selected track in a selection of tracks and switches to any clicked track in an edit group where all tracks are selected
Fixed
Resolved an issue that could cause Console channels in ISOLATE mode to stop passing audio when opening a session with a soloed track
Resolved an issue that prevented renaming a template
Resolved an issue that could prevent quantize settings from being shared between session versions
Resolved an issue that prevented timeline selection on bus tracks that were at Mini or smaller track heights
Command + Up/Down arrow no longer fails to change the track focus when renaming tracks with the track color picker open
Tracks now retain their current track view when duplicated
Related Information
Download LUNA
Version 1.2
September 15, 2021
New
Sidechain Input
Improved
Fixed
