Post by indiehouse on Aug 11, 2021 15:12:53 GMT -6
What is your experience/thoughts on top down vs bottom up mixing? Do you treat subgroups first, then individual tracks? Or vice versa?
Post by Tbone81 on Aug 11, 2021 16:04:46 GMT -6
I do a little of both but start top down I suppose. I start by inserting some HW on the 2bus, usually a pair of vp28's and my sebatron pre's. Then I'm balancing volume and pan on all tracks. Then isolate the drums and add compression to the bus, get some reverb/ambience going, use a pair of AML ez1073's as HW inserts, and then start mixing the drums from the bottom up. Same type of thing with all my other busses. Once its all sounding realtively good I insert some compression on the 2bus and mix into that.
Post by Deleted on Aug 11, 2021 16:04:48 GMT -6
It’s okay for a rough tracking mix but no, then I end up never fixing problems with individual tracks and can be lulled into mediocrity, eg lot of cool tube stuff requires you to really eq your tracks before or after to not sound awful and if you never get around to doing this you can miss out on the best option for your mix in favor of the merely “acceptable” option.
And sometimes cleansing your tracks really is sweeping around and around to find that resonance that’s there but no big deal when the track or mix is unprocessed but annoying as shit when it hits the cool processed. If you presume that what should be a notch is a tonal error before starting, then you’ll never stamp out the nastiness and will reject what could be cool and fit the tempo and vibe of your mix better because it will never sound good.
Compare that to building a mix from the bottom up when it sounds good after you clean up your tracks and greet when you go back and adjust them.
This is how we get too compliant and lulled into using things that always work but if everything is the same then nothing stands out for what you do. You’ve made the mix fit your mold of what a mix in that genre should be instead of letting the recordings bloom into something unexpected that you’re shaping it as it goes to sound as best as possible for what it is.
This is how we ended up with modern productions that all sounded the same. Sounding the same as everything else is sounding unexceptional. I don’t want to aim to sound the same.
Post by Blackdawg on Aug 11, 2021 16:05:45 GMT -6
As will most things...
It depends.
On big sessions, I do more "top down" style stuff usually. Smaller session bottom up. Just depends on the track/instrument count for me personally. I'm not sure one is "better" than the other.
Post by gravesnumber9 on Aug 11, 2021 20:20:09 GMT -6
I started mixing into the 2 bus recently and it saved a lot of hassle. Things really change when you add things like bus compression, this saves me from having to go back and redo a bunch of stuff a second time.
Post by jampa on Aug 12, 2021 3:41:12 GMT -6
I'm in-the-middle mixer
It either explodes or implodes
Post by nick8801 on Aug 12, 2021 6:26:16 GMT -6
I like to start with what I think is the focus of the song, usually the vocal.
Post by phantom on Aug 12, 2021 6:49:56 GMT -6
I start with bottom up mixing always. At some point I'll bring the 2-Bus process, hardware or software: usually a compressor, an eq and something for vibe. Sometimes I'll bring the 2bus compressor early on then the rest.
Drum Bus sometimes gets it's own compressor earlier than that as well.
After that, there are no laws anymore. I'll tweak what need as I go.
But as a general rule I try not to mask any track problems with bus process.
Post by indiehouse on Aug 12, 2021 7:51:16 GMT -6
I like to start with what I think is the focus of the song, usually the vocal. I've heard this often as well, building the song around the vocal. So, are you treating the vocal in isolation then? Or around the unmixed backing tracks?
Post by Johnkenn on Aug 12, 2021 8:11:26 GMT -6
What is your experience/thoughts on top down vs bottom up mixing? Do you treat subgroups first, then individual tracks? Or vice versa? Always build bottom up. I think of it like a pyramid…foundation is drums and bass…et al
Post by jaba on Aug 12, 2021 10:32:05 GMT -6
I typically start with whatever happens to be the main focal point (vocal, drums for dancier stuff, etc) and play with different combos to find what works best and then build from there. No real set schedule, let the tracks guide things, fix what's needed, then start popping in some 2-buss stuff to support it and going from there.
I liked Dan's post about dealing with issues/resonances off the bat. Sometimes deadlines get in the way so going for feel and fix what's getting in the way of that is the best option - will often work on groups sooner than later here - but pre-mix prep work can lead to great results. Not only does it open up tracks and make them sound better even before you start mixing, but you'll likely discover things that you might've otherwise not stumbled across, subtle things that easily get lost but can be quite special when pushed to the foreground. Sometimes the artist is pleasantly surprised to hear things they didn't even know were there!
Post by thehightenor on Aug 12, 2021 12:21:38 GMT -6
I mix with Bob Katz K14 calibrated monitoring method (yep I'm the one :-)
So I use K14 monitoring in Cubase and then pull up my kick and have is sit about -5dB (k14) or -18dBFS and then build dynamically from there.
So I find this method kinda requires bottom up.
It's not a biggie though, I'm basically using K14 so I'm running my Cubase mixer and my analogue outboard with lot's of headroom as to my ears and experiments it sounds better this way.
Post by jmoose on Aug 12, 2021 13:44:00 GMT -6
I like to start with what I think is the focus of the song, usually the vocal. I've heard this often as well, building the song around the vocal. So, are you treating the vocal in isolation then? Or around the unmixed backing tracks? Why would the vocal be in isolation? For me its never isolated... if I'm mixing around the vocal it means the vocal is never/rarely muted. And its volume, the fader position is locked too. Building around = everything else develops around the vocal. Always in context never isolated. No idea what top vs bottom up means but often, after listening to rough mixes and raw tracks I try to establish a tangible image of what the final mix should like. I'll hear things I either want to do, or need to do in the case of problem solving & overall sound sculpture... and then, kinda start hacking away piece by piece until the mix starts to resemble what was in my head. Sometimes the mix doesn't wind up going in the same direction my head was in. Then I have to decide if the alternate development is cool, or even cooler then the initial idea..? Or does it get wrestled into conformity? During all that buttons & knobs, both physical analog and virtual digital get turned & pushed. And ploop..! On the other end of the sausage machine we have a mix! But yes mostly I think of the mixing process like a sculptor with a block of marble or wood. Chipping away until the final form is revealed like magic.
Post by nick8801 on Aug 12, 2021 18:31:16 GMT -6
I like to start with what I think is the focus of the song, usually the vocal. I've heard this often as well, building the song around the vocal. So, are you treating the vocal in isolation then? Or around the unmixed backing tracks? So I don’t necessarily treat the vocal other than making it sound smooth and balanced. Sometimes that means eq and compression, sometimes if I feel it, verb/delay. Mostly just setting it were it feels good based on my mixing levels. Then I bring up the rest of the track around it. Usually drums first. I find if you can get the drums and vox to groove together everything else will fall into place much easier. This is a new thing for me, but I like the way things have been turning out so far!
Post by theshea on Aug 13, 2021 1:10:32 GMT -6
i am always jealous off the tracks the pro mixers are getting: they sound almost finished.
so i start with fixing the recorded tracks. one by one mostly this means cutting resonances, lo- and hi-cutting. sometimes a bit of compression with a tape plugin. THAN i start mixing. with gain staging and balancing. than its time to get the drums right with eq and comp, set up the drumbus. than the bass comes in to make a whole with the drumbus. THAN i will insert a comp (mostly spl iron) on the mixbus. i continue with the rest of the tracks and have a look at the spl iron from time to time. it should compress 1db at maximum. strangely vocals come last for me ... ok, they come before tamburine and shakers :-)
Post by Ward on Aug 13, 2021 4:32:34 GMT -6
What is your experience/thoughts on top down vs bottom up mixing? Do you treat subgroups first, then individual tracks? Or vice versa? Always build bottom up. I think of it like a pyramid…foundation is drums and bass…et al Almost the same for me. I've tried top-down mixing many times but always end up with compromises that lead to a wimpy sounding mix. Start from the bottom up, but turn things on and off to balance a mix also.
Post by Ward on Aug 13, 2021 5:24:23 GMT -6
*and yes, I mix into a buss comp most of the time. I routinely turn it off to see what's getting creamed, and evaluate what my sub-group comps are doing.
Post by svart on Aug 13, 2021 8:52:01 GMT -6
I've tried it all. Here's what works for me:
Bottom up. Subgroups/Busses for every instrument (folders, really). Parallel bus for drum shells (feeds into drum bus) Busses for verbs (room, snare, vocals, etc) into a main verb subgroup/bus.
I always have the same template (even though it's evolving every mix). On the 2 bus there is always a SSL bus comp (always shooting for about 3dB of GR), always a limiter (currently L1, usually kissing around 3-5dB of GR on peaks). Right now I also have Pultec style EQ doing a boost at 12K and a bump at 60 of a few dB each.
That's my starting point for the whole mix. Each bus has some stuff going on, usually a bit of compression. EQ is usually at the track level and there are EQ moves I have mostly the same on every mix so far, but are evolving as I go.
Post by notneeson on Aug 13, 2021 9:12:00 GMT -6
I've tried it all. Here's what works for me: Bottom up. Subgroups/Busses for every instrument (folders, really). Parallel bus for drum shells (feeds into drum bus) Busses for verbs (room, snare, vocals, etc) into a main verb subgroup/bus. I always have the same template (even though it's evolving every mix). On the 2 bus there is always a SSL bus comp (always shooting for about 3dB of GR), always a limiter (currently L1, usually kissing around 3-5dB of GR on peaks). Right now I also have Pultec style EQ doing a boost at 12K and a bump at 60 of a few dB each. That's my starting point for the whole mix. Each bus has some stuff going on, usually a bit of compression. EQ is usually at the track level and there are EQ moves I have mostly the same on every mix so far, but are evolving as I go. Man, that 2 buss approach is very very familiar here.
Post by srb on Aug 13, 2021 9:21:38 GMT -6
I'm an "all faders up" mixer. If I've tracked the material, I already have most of the sound I'm looking for on the way in. I mix into a RND Master Buss Processor and a Chandler Curve Bender. I prefer using a console (5088).
I'll still utilize this approach if I didn't do the tracking. Historically I may find I'm doing a bit more soloing or building up by instrument group, but not much.
I'm looking to take what I have and make it work as a whole. I do solo things occasionally if I note any problems, but almost all of any changes made, are made in context of the whole mix.
The one area where I might spend some time tweaking individual elements in solo or in group is with drums. It's tracking dependent, but I will work via a gate or through editing (last resort there) to minimize cymbal bleed on individual drums as much as I can where it's creating more issues than cohesion.
A good vocal comp will require time spent in solo, of course, but for me that's to check mostly for clean edits.
Post by svart on Aug 13, 2021 11:41:33 GMT -6
I've tried it all. Here's what works for me: Bottom up. Subgroups/Busses for every instrument (folders, really). Parallel bus for drum shells (feeds into drum bus) Busses for verbs (room, snare, vocals, etc) into a main verb subgroup/bus. I always have the same template (even though it's evolving every mix). On the 2 bus there is always a SSL bus comp (always shooting for about 3dB of GR), always a limiter (currently L1, usually kissing around 3-5dB of GR on peaks). Right now I also have Pultec style EQ doing a boost at 12K and a bump at 60 of a few dB each. That's my starting point for the whole mix. Each bus has some stuff going on, usually a bit of compression. EQ is usually at the track level and there are EQ moves I have mostly the same on every mix so far, but are evolving as I go. Man, that 2 buss approach is very very familiar here. After years of thinking I was too cool for school and going my own ways, I've realized that the reason it's a popular approach is because it just works.
Post by notneeson on Aug 13, 2021 12:23:39 GMT -6
Man, that 2 buss approach is very very familiar here. After years of thinking I was too cool for school and going my own ways, I've realized that the reason it's a popular approach is because it just works. Indeed. We get a lot of Americana and acoustic stuff because my studio partner is in that world. Works for that as well as it does for rock or anything else I've encountered.
Post by sean on Aug 13, 2021 12:33:28 GMT -6
Lately I’ve had the best luck with starting with my Spectra V610’s and Smart C1 in dual mono the mix buss (usually 4:1 with 3ms or 10ms attack time and auto release) and building my mix with those in from the top. I usually rough in my levels and panning and then start doing some EQ to address some issues (resonant bass frequencies *especially with uprights*) and try to get each instrument sounding as good as it can on its own…working with acoustic instruments I’m mostly trying to get each note on a bass even without having to compress it much and try to make each string of the instrument sound balanced. And then I’ll add some compression if needed, ride the fills and solo, and ride the vocal / vocals. I have a VCA that have every audio track on it so if I’m pushing it too hard into the mix buss chain I can bring everything down (or up if I want to hit it harder).
I also have a pair of AML ezp1a that I’ve level matched with a little 8K boost and a 100hz boost that I’ll try after I’ve got a mix I think is happening and those either make it sound better or too bright or too boomy. But their polish tends to help a lot. I’m sort of going back and forth with following that with an Overstayer MAS. Not sure if I’ve found the magic settings on that yet
Post by christopher on Aug 13, 2021 13:37:11 GMT -6
I'll go track by track and make sure it sounds how I'd like them to before I start mixing. The best way for me is to re-record it, then it feels like I was part of the tracking, or often I use EQ that I was afraid to do in the moment. I can be more heavy handed here, and usually I keep my risky experiments. Also I do editing to clean stuff up. Once its re-captured as a stereo wav, I'm less tempted to surf plugins trying to improve it, I like seeing a clean project with no plugins. Often I'll export the wavs out after more editing or plugins and automation just so I can get that nice, clean project feel again before I start mixing. I divide the project into 6-7 stereo submix elements, I like to lay the submixes on the console, about 12-14 channels hard-panned. I'll solo each and EQ them on the board, then I'll pull all the faders up, listen, then go group by group in solo and address things, usually stuff ITB that needs help, clip fades, corrective automation, maybe notching out something with EQ. So I'm always going back and forth between the subgroups and 2 mix. Once its all working together, I take a pic for recall, and I might decide to start manually working the faders while printing. This is not easy at all, but its pretty a nice feeling to me, to know my hands are on the flow in real time. Its like learning a new instrument or a new song, takes some practice. Automated faders might be nice, then again, this is working for me right now.
Post by jampa on Aug 13, 2021 15:30:44 GMT -6
If I tracked it - all faders up - sorted into lots of subgroups - with light 2 bus processing - start by adjusting fader balance if required, then turn to individual tracks
If I didn't track it - all faders up only to get the big picture, then all down - bring faders up one by one for rough balance, then as per above processing
