Post by kcatthedog on Feb 11, 2021 12:16:51 GMT -6
New update , release note posted by Drew at UA Forum:
UniversalAudio's Avatar UniversalAudio said: 15 Minutes Ago LUNA 1.1.5 Has been released.
LUNA v1.1.5 IMPORTANT “ LUNA sessions opened in v1.1.5 cannot be opened in earlier LUNA versions due to file format changes
NEW
Recording Count-In
- Toggle a 1, 2, or 4 bar count-in before recording begins - New Count-In Toolbar Icon and CLICK pop up menu display count-in and metronome settings - Configure metronome to run during only playback, recording, or both - K or Numpad 7 Toggle Metronome keyboard shortcut - Shift + K or Numpad 8 Toggle Count-In keyboard shortcut
NEW
Sends Group Setting
- Added "SENDS" group setting in the group edit browser - Added individual send slot modifiers to group functionality - Added batch Modifiers to group functionality
IMPROVED-Oxide, Studer A800, and Ampex ATR-102 Extensions' meters now display the exact same post-tape signal as the original hardware circuitry and UAD Plug-Ins
IMPROVED-Added separate CREATE and OPEN RECENT buttons on the CREATE page
FIXED-Resolved an issue that caused delay compensation issues after changing sample rates
FIXED-Resolved an issue that could cause Extension and Instrument plugin presets to recall incorrectly when undoing a preset change
FIXED-Undo / Redo no longer applies to session data changes while a text entry pop-up is focused
FIXED-Resolved an issue that could prevent undo after using the Mute All command for sends
FIXED-Fixed a crash that could occur when editing MIDI notes or MIDI CC automation
FIXED-"Rescan Drives" now finds instrument data on an external drive that has been connected after launching LUNA
FIXED-Resolved an issue that could cause LUNA to hang when quitting
FIXED-Folder Open/Close states in the Inserts browser prior to text searching are remembered after clearing the search filter“
Post by Johnkenn on Feb 11, 2021 19:16:48 GMT -6
The new VU meters are a major improvement. Luna just keeps getting better and better.
Post by kcatthedog on Feb 11, 2021 19:34:01 GMT -6
Is that on the tapes: ampex/ studer or the summing neve/ API or all?
Post by Johnkenn on Feb 11, 2021 22:44:27 GMT -6
Seems like all of them
Post by Johnkenn on Feb 11, 2021 22:45:21 GMT -6
I don’t know all the dbu=db=vu blah blah…but these now make sense to me.
Post by kcatthedog on Feb 12, 2021 6:52:04 GMT -6
If you are interested in straight forward, short, Luna user tutorials on set up and tweaking, this guy is doing them on YT videos: youtube.com/c/owlwoodsouth
Post by kcatthedog on Feb 12, 2021 6:55:39 GMT -6
I don’t know all the dbu=db=vu blah blah…but these now make sense to me. The simple way I understand it is they are now aligned ? I imported a 2 bus mastered logic mix, played around with adding oxide, neve summing etc., It honestly sounded improved. But, as I said in my m1 mini thread, the m1 mini seems to sound a little better to me too.
Post by kcatthedog on Feb 13, 2021 13:33:00 GMT -6
Post by phantom on Feb 13, 2021 13:37:33 GMT -6
It would be better to have one thread for Luna and concentrate all this weekly news there.
Post by kcatthedog on Feb 13, 2021 14:13:43 GMT -6
Johnkenn ?
Post by Johnkenn on Feb 13, 2021 14:57:24 GMT -6
Post here
Post by kcatthedog on Feb 14, 2021 6:16:36 GMT -6
Here’s a guy, Phil, posting timely Ytube videos on luna’s new features:
Post by Drew @ UA on Feb 14, 2021 11:14:38 GMT -6
Hey John, Since you've designated this an official LUNA thread, I'll keep it open and monitor it and answer any/all questions.
Post by Johnkenn on Feb 14, 2021 12:02:57 GMT -6
Hey John, Since you've designated this an official LUNA thread, I'll keep it open and monitor it and answer any/all questions. You da man
Post by javamad on Feb 15, 2021 5:00:34 GMT -6
Version 1.1.5 working great here.
I have now started to use LUNA on my own upcoming album (mostly audio recorded in Logic and a few VI’s) and this week started using it on a second client (pop project with all VI’s so far)
If one is careful around updates (backing up projects and keeping an older version of LUNA running, I don’t see and reason to not dive in :-)
The sonics, to me, are just great. The tracking/editing workflow is also great with the omission of audio-quantize. Hoping that comes in to a version real soon. Workaround with manually moving Warps is decent enough unless you are gridding the whole thing, which I just don’t want to do anyway.
Tempo adjustments to audio are scary good with the different algorythms.
I have the Neve Summing and the Ampex Master tape and they just sound great to me.
One pet peeve with the tape though ... and this goes for Studer too .. I get frustrated by the adding of hiss on certain presets. I will NEVER want this .. so I would love a master, account level setting that would 100% disable this and never have to start searching my project for the culprit again.
Post by kcatthedog on Feb 15, 2021 5:53:32 GMT -6
I think you can pop the hood on ampex and studer, to turn off hiss and save in your template by using the save as command and renaming ?
Post by javamad on Feb 15, 2021 11:30:19 GMT -6
I think you can pop the hood on ampex and studer, to turn off hiss and save in your template by using the save as command and renaming ? I could alright ... but I would have to go through every preset and see if it had hiss on it and save/rename ... Then I would have to scroll to my personal presets, I think ... sounds like a lot of trouble but I may just have to bite the bullet and invest the time.
My suggestion/gripe was to ask for some sort of click-once solution to never have to hear that sound again... I just feel its a little gimmicky
Post by kcatthedog on Feb 15, 2021 11:52:37 GMT -6
Oh I understood:) maybe Drew will chime in an correct me but I don’t believe there is a mast off like you describe.
Or build a little template with it set the way you want, sound silly but like HW you likely use a particular setting on each group or input( guitar, vox, drums, etc., you could just build that template once: inputs and busses and save as your default. So the heavy lifting would be done, and then just tweak to taste as you track/mix ?
Post by javamad on Feb 15, 2021 12:04:58 GMT -6
Oh I understood:) maybe Drew will chime in an correct me but I don’t believe there is a mast off like you describe. Or build a little template with it set the way you want, sound silly but like HW you likely use a particular setting on each group or input( guitar, vox, drums, etc., you could just build that template once: inputs and busses and save as your default. So the heavy lifting would be done, and then just tweak to taste as you track/mix ? Its not a big deal really .. I work with 8 Stereo buses in LUNA (replicating my previous hybrid mixing template) and I add Master Tape to them all. Default setting sounds great and seems to add an octave below. Very cool. Then I start messing around with the vocals bus or the guitars bus and all good .. then when I stop .. if I am on headphones I can hear the hiss that is set on the non-default preset I just picked. No problem, I can go turn it off .. cos I know what I just changed. But of I am on speakers, its not as evident and I could be hours down the road when I realize.
It particularly bothers me when I can hear it at the start or end of a track ...
Anyway .. enough de-railing of the LUNA tread! I'll shut up now :-)
Post by Drew @ UA on Feb 15, 2021 13:56:48 GMT -6
Studer defaults to noise off and has for a while in LUNA. I hear you on the presets, but since they're interchangeable with UAD, it's a big change.
We're close to getting session templates so this will be something you can deal with in your template soon. Glad to hear you're enjoying LUNA.
Post by Drew @ UA on Mar 2, 2021 10:40:46 GMT -6
Hi all, We previewed the new features coming to LUNA 1.1.6.
Post by javamad on Mar 2, 2021 11:43:37 GMT -6
Hi all, We previewed the new features coming to LUNA 1.1.6. A nice few features .. keep 'em coming. On the Opt-K to put into Input monitoring mode ... I don't understand the difference with Shift T which is already there??
Post by Drew @ UA on Mar 2, 2021 12:38:41 GMT -6
Hi all, We previewed the new features coming to LUNA 1.1.6. A nice few features .. keep 'em coming. On the Opt-K to put into Input monitoring mode ... I don't understand the difference with Shift T which is already there?? Option K does all rec enabled tracks. VERY useful if you're tracking a full band and need to get them all into Input mode at once.
Post by javamad on Mar 2, 2021 13:29:36 GMT -6
A nice few features .. keep 'em coming. On the Opt-K to put into Input monitoring mode ... I don't understand the difference with Shift T which is already there?? Option K does all rec enabled tracks. VERY useful if you're tracking a full band and need to get them all into Input mode at once. Sweet. Thats clear and a great idea. Thanks.
Post by Drew @ UA on Apr 5, 2021 14:34:42 GMT -6
New show today, all about buses and groups.
