Post by kcatthedog on Jan 27, 2021 5:21:47 GMT -6
Post by the other mark williams on Jan 27, 2021 7:48:37 GMT -6
I can confirm this. Got all my plugs installed on Monday night, and iLok stuff was flawless. It’s all these other companies with homebrewed copy protection schemes that took forever.
Post by kcatthedog on Jan 27, 2021 10:47:46 GMT -6
Nice, how’s the mini so far ?
Post by the other mark williams on Jan 27, 2021 17:17:26 GMT -6
Nice, how’s the mini so far ? A little puzzling. I haven’t tried everything yet, but I already discovered I can’t use the Magic Death Eye plugs. They spike the usage meter and stop playback immediately. I’m not sure where DDMF is in the updating process, but I should probably drop them a line. I like those plugs. I haven’t tried to track anything yet. Hopefully in the next couple days... EDIT: and this is running Logic in Rosetta mode, of course.
Post by kcatthedog on Jan 27, 2021 17:42:04 GMT -6
I thought logic was big Sur certified but you are doing that for your non bs certified plugs ?
Post by the other mark williams on Jan 27, 2021 20:37:33 GMT -6
I thought logic was big Sur certified but you are doing that for your non bs certified plugs ? Yep. Logic is fine with both Big Sur and Apple Silicon (of course), but a large portion of my 3rd party plugins are not Apple Silicon ready. I've heard from folks that the best thing to do is to run Logic in Rosetta as long as you're using plugins that are still Intel only.
Post by kcatthedog on Jan 27, 2021 20:50:47 GMT -6
I understand, I hadn’t realized logic was running in rosetta, having only read about it. I thought rosetta was running in logic !
Post by the other mark williams on Jan 27, 2021 21:41:10 GMT -6
I understand, I hadn’t realized logic was running in rosetta, having only read about it. I thought rosetta was running in logic ! The way it works is that Logic can run in either native ARM mode or in Rosetta Mode. It will naturally want to run in native ARM. But if you do a COMMAND-I "Get info" on the Logic application in the Finder, you'll see a little checkmark box where you can check "use Rosetta".
Post by wiz on Jan 27, 2021 22:12:20 GMT -6
I understand, I hadn’t realized logic was running in rosetta, having only read about it. I thought rosetta was running in logic ! The way it works is that Logic can run in either native ARM mode or in Rosetta Mode. It will naturally want to run in native ARM. But if you do a COMMAND-I "Get info" on the Logic application in the Finder, you'll see a little checkmark box where you can check "use Rosetta". Performance hit ? ARM vs Rosetta
Post by the other mark williams on Jan 27, 2021 23:40:13 GMT -6
The way it works is that Logic can run in either native ARM mode or in Rosetta Mode. It will naturally want to run in native ARM. But if you do a COMMAND-I "Get info" on the Logic application in the Finder, you'll see a little checkmark box where you can check "use Rosetta". Performance hit ? ARM vs Rosetta Good question, Peter. I'm not sure how to quantify it yet. I haven't had enough time with it. I haven't even tried to run it in ARM-mode yet...
Post by kcatthedog on Jan 28, 2021 0:51:22 GMT -6
The you tube videos I have seen indicate minimal performance hit with Rosetta with m1, but it would be most efficient in Arm.
Post by cyrano on Jan 28, 2021 13:06:20 GMT -6
It depends. Reaper, for instance, is running very well, but jesusonic scripts tend to be slower in native ARM mode. Rosetta 2 is partly in hardware. Apple has built a few Intel instructions into the ARM SOC. That's part of the reason it's so fast and a lot of the reason it's so compatible. In general, the M1 transition seems to go very well for Apple. I wonder how people feel that recently bought the latest Mac Pro... After the Macbooks from the latest decade, I was ready to jump to Linux (for audio). The M1 is sexy enough to keep this sheep in the herd.
Post by kcatthedog on Jan 28, 2021 15:14:23 GMT -6
Next 6 months plus should see new iMacs and the mbp 16 inch, sure they’ll be more expensive, but more cores, I/o and memory, so more pro and the next gen m1x chips.
A good time to be a Mac hound.
