Post by Deleted on Apr 10, 2014 6:57:59 GMT -6
you set the pattern on the PSU via the pattern switch, which I believe affects the voltage applied (polarization) to each side of the capsule. that's why I posted the picture of the mic with PSU, so you could see the pattern switch.
Shannon just mods the capsule, he doesn't touch the PSU.
Post by svart on Apr 10, 2014 6:58:08 GMT -6
Changing mic patterns is as easy as applying voltage to the backplate or diaphragms of the capsule, or grounding them.
Post by henge on Apr 10, 2014 7:04:42 GMT -6
I was listening to some early Jackson Browne last night - and there it was...sounds like it's Cowboy's 67 straight into the board...it's definitely THE sound... Anyway, yesterday, Herbie mentioned how we always used to ask how the big studios get THAT sound...and that here it is - a fantastic vintage mic(s). That's definitely the truth - the mic is THE most important piece of the chain...After I sang through it I was telling him, "maybe I should sell x,y,z and just invest in a vintage mic..." But after listening, I don't think that's the right move for me. IMHO, the improvement in quality isn't worth selling off my entire signal chain to buy a vintage mic that might never be as good as the one Herbie got. One day I definitely want to add one, but I'm really happy with what I've got right now... Herbie's daughter sang a tune for me and killed it! It was also the best vocal sound I've ever had the pleasure of working with. That 67 is AWESOME!
Post by Johnkenn on Apr 10, 2014 7:34:08 GMT -6
I think you guys were misreading what donr was asking...I'm pretty sure he knows how to change the pattern on a mic...
Post by watchtower on Apr 10, 2014 7:44:06 GMT -6
It's early, and while I've had 75% of my coffee, it's still early, so just to make sure, this is a U67 versus a modded CV4 BEFORE you asked Shannon to make it more like a U67?
Also you can easily make the CV4 cardioid-only without modifying the PSU
Post by Johnkenn on Apr 10, 2014 7:52:33 GMT -6
No - the first two clips are the U67 vs. a modded CV4. Neither eq'd. While I realized they sounded a little different, I was shocked at how similar the two sounded, so I thought I would post it. I then posted the third clip - which it the same modded cv4 with my attempt at EQing it to more closely match the original U67 clip.
My intention in posting this was not to say "omg - This mic sounds exactly like a 67". It was more like, "omg - this mod was done without ever hearing this U67 and listen to how close they are." No one is trying to say you should never buy a vintage 67. If it's in your budget, you SHOULD.
Post by svart on Apr 10, 2014 8:00:28 GMT -6
I wouldn't. The nostalgia doesn't ring home with me. I buy mics that I need, not mics that I want. I'd be much more inclined to buy the CV4 than a U67, even if I had the money. However, I prefer Gefell mics to Neumann every day of the week including Caturday, so there's that.
then again, I'd probably just EQ my 300$ C12 clone until it sounded similar to whatever and call it a day. Or maybe I'd just EQ it to fit the singer's voice and call it a day, whichever sounds better in the song.
Post by jcoutu1 on Apr 10, 2014 8:08:00 GMT -6
There is a bit of difference in the upper mids. The CV4 has a little nasal trail off on the "ings" sounds. The U67 has a bit more of a "chesty" sound. This is spot on. it was apparent on first listen with crappy desktop computer speakers. The eq'd sound was more in the ballpark, but still more like the way the Raiders and A's play in the same park.
Post by dandeurloo on Apr 10, 2014 8:12:53 GMT -6
I listened on my laptop. My laptop speakers show the ugly upper mids of mics well. I do prefer the 67. Its smoother in the upper mids and doesn't have that Chinese sizzle. What I prefer even more then that is the thousands of dollars saved by using the modded mic and some serious eq to smooth out the upper mids.
I would love to have heard the 2 mics on an acoustic guitar as well. Backed up a little so you can hear the reach on the mics. The reach is something an eq can do nothing for.
Post by tonycamphd on Apr 10, 2014 8:23:10 GMT -6
It's early, and while I've had 75% of my coffee, it's still early, so just to make sure, this is a U67 versus a modded CV4 BEFORE you asked Shannon to make it more like a U67? Also you can easily make the CV4 cardioid-only without modifying the PSU Why would u want to make the cv4 cardioid only?
Post by donr on Apr 10, 2014 8:31:30 GMT -6
I think you guys were misreading what donr was asking...I'm pretty sure he knows how to change the pattern on a mic... I should have written more clearly. I have a stock CV4 and it sounds smoother toward omni. Figure 8 works too, I have gobos around the mic to cut room pickup.
Post by watchtower on Apr 10, 2014 8:36:39 GMT -6
It's early, and while I've had 75% of my coffee, it's still early, so just to make sure, this is a U67 versus a modded CV4 BEFORE you asked Shannon to make it more like a U67? Also you can easily make the CV4 cardioid-only without modifying the PSU Why would u want to make the cv4 cardioid only? I wouldn't. I thought that's what John said Shannon did to his. If that's accurate, then it's probably for the small benefits of "true cardioid" and the fact that John is mostly/only singing with the CV4, from what I understand.
Post by wiz on Apr 10, 2014 14:38:53 GMT -6
Listening to the U67 vs the EQ clip, John thats close enough for me. I bet you often get more tonal differences in various vocal takes, and certainly from day to day, than that. I'm not saying that I can't hear differences, but that the differences are within acceptable limits for me.
I demo'd a CV4 here , and I didn't like it very much at all. You know, it was good, but not great. But the sound of the mic with shannons mods is very very impressive. If I didn't love my U87 in such an unhealthy way bordering on sexaul obsession, I would be looking into it 8)
(and given that Cowboys U67 is touted as a bit of a gold standard of U67s, then thats even more impressive, nice work Shannon!! )
Post by sll on Apr 10, 2014 14:57:12 GMT -6
That CV4 clip does sound nice on your voice John. A lot different and better than the stock ones I've heard. I'm curious what the mod entailed? Did he replace the capsule?
There's still something about the U-67 that's smoother in the top end. I certainly wouldn't be ashamed to use the CV4 you have however.
Post by unit7 on Apr 10, 2014 15:59:49 GMT -6
Clips with John's vocal would sell me any mic. I consider myself a badly f*cked up slut for gear, but emotion/vibe trumphs everything. I'd rather have John with an SM58 than a ok/good singer with any high end mic in the world.
Post by Johnkenn on Apr 10, 2014 17:15:15 GMT -6
Thanks, unit7...I'm blushing... Like wiz said...I hear the differences...I agree - I think you can objectively say that the 67 sounds "better" compared to the CV4 without EQ. But - IMHO, comparing the 67 with the EQ'd file, I think the preferences are subjective. Between those two, I think the Modded CV4 with EQ sounds better. I'm sure some don't. Now, I'm sure once you slap EQ on that U67, it could possibly sound even better...BUT - folks, we're not talking HUGE differences here. I would venture to say that there are MANY 67's that don't come close to sounding as good as either of these two examples.
Post by Johnkenn on Apr 10, 2014 20:47:29 GMT -6
BTW - I find it interesting that there have been 40 plays of the U67 file, 31 plays of the CV4 File and 19 of the EQ'd CV4...Hmmm.
Post by tonycamphd on Apr 10, 2014 23:15:35 GMT -6
I've listened to both the 67 and eq'd cv4 in equal parts since you put it up??
I know Shannon put one of his killer capsules in the cv4, was there any additional mods or component swaps done to the power supply or the mic circuit itself? I know i've done some mic modding where the power supply was less than stellar, the effects of which were a lurchiness, or a jumpyness in the dynamics. As a general rule, the mic goes as the psu goes, as a matter of fact, almost any piece of audio gear goes as the psu goes, you'd get a 99.999% consensus over at Groupdiy on that one.
the main reason i mention the mods is because if you have NOT had them done, that mic is worth having them done, even if it makes it only marginally better IMO
Post by Deleted on Apr 10, 2014 23:48:53 GMT -6
Shannon only touches the capsule. I didn't send him the PSU when I had mine done
Post by littlesicily on Apr 11, 2014 19:07:08 GMT -6
I thought the eq'd version of CV4mod was "closer" and most definitely more than useable...it's good. But... I will say that the beauty of a great u67 is that it tames those peaky harsh notes in a beautiful way. Eq gets it close, but not quite same thing. Blah, blah... end of day either mic works. Shannon does fabulous work on vintage mics and his new creations. Great to have him so close by!!
Post by Shannon on Apr 11, 2014 20:37:24 GMT -6
First off thank you for the kind words.
And for the record, I didn't know that I worked on Cowboys Mic previously, it wasn't till we were packing it up as I grabbed the Korby Power Supply that I was oh shit
Johns mic was never meant to be a U67 it was meant to compliment him, just chance they compared them. Now I wonder though if set out to build U67 how it would compare knowing the direction and sound. The traits that everyone mentioned are spot sweet smooth and the mids etc.. Thinking gonna have to give it a try just for shits and giggles.
Post by Deleted on Apr 11, 2014 20:52:43 GMT -6
*sends back CV4 for free guinea pig treatment*
Post by Johnkenn on Apr 11, 2014 21:14:37 GMT -6
I was gonna get Shannon to tweak a little...but I don't want to screw up a good thing. I'm keeping this one the way it is...
Post by popmann on Apr 11, 2014 21:49:54 GMT -6
I'm gonna tell you the two qualities about the 67 that make it special for me. The combo of bright cap with the negative feedback means the highs are EVEN--which means all you do it compress and add Pultec plug and you can boost so much there's nothing BUT air...which is different than brighter airier MICS OR darker MICS--where the highs are less even, this you can't boost to taste--you hit a wall--and the compression on a bright mic tend to make the highs even MORE uneven..,
Second part is that it breaks up when you belt it. I've put some of McBride's 67s to the backplate...I'm kinda loud...but, assuming no ones thinned the Mylar (likely the case with the ones fom there I've used)...it gets this kind of saturation in the middle when you belt it--makes it seem "louder" even once it's leveled--allowing it to take more leveling before the life is gone.
If you're building one..Id find a tube that does the air like a 269. They're wholly better than straight 67s...my understanding it there are some other tubes that sound close to an ac701 without having to put such a rare expensive tube in there.
Post by dandeurloo on Apr 12, 2014 8:16:07 GMT -6
Popmann is right on. The modded mic sounds really nice. To do what is described above I bet you would have to do some surgical eq cuts in the upper mids to smooth out that range. Then you could go for the compression and pultec. Not a big deal with a really nice digital eq.
John, what tube is in your mic? Tubes make a big difference.
The DIY 67's I built do that well. I do track with pultec eq on them and they sound great. They do sometimes get a little peaky around 3k when I push them hard there. These use the BeezNees capsules.
My 269 I built is super smooth and sweet. It has a original Neumann capsule in it.
I have heard a pair of Stephen Paul Modded 67's with 3 microns capsules. Yuck! Why ruin a good thing.
