Post by Bender on Oct 29, 2020 15:25:01 GMT -6
Looking to step up my single pcb holder that can handle bigger/multiple pcb builds at a time.
I'm diggin this design, but is there anything else out there that would do the job without such a price tag? Maybe even some diy alternative??
Post by mulmany on Oct 29, 2020 21:52:08 GMT -6
That's pretty cool! Should definitely be handy for op amps. I use the big panavise and can get 2x 500 series boards in at the same time.
Post by plinker on Oct 29, 2020 22:01:06 GMT -6
Yes! I learned in a shop with a Panavise. When I started working on my own this was the first thing I bought. www.panavise.com/index.html?pageID=1&page=full&--eqskudatarq=5The Panavise allows you to stuff parts, then quickly flip the board to solder. Speeds things up and holds everything securely. It's also good for holding other projects besides PCBs. It's way more than a tinkerer like me needs, but it is Real Gear.
Post by mulmany on Oct 30, 2020 6:33:50 GMT -6
Post by svart on Oct 30, 2020 9:04:18 GMT -6
Post by Bender on Oct 30, 2020 12:12:49 GMT -6
That's pretty cool! Should definitely be handy for op amps. I use the big panavise and can get 2x 500 series boards in at the same time. Thanks for the scoop! I'm familiar with the panavise line, but I never felt the need to justify the xtra coin vs the cheapie single pcb holder I have now that can be adjusted and flip around as well... hence this search!!!
When I'm building say 6 vp28's at a time or whatever I'd really like to have em all out at once for stuffing and soldering to streamline the process and save time.
Post by johneppstein on Oct 30, 2020 17:22:29 GMT -6
Yes! I learned in a shop with a Panavise. When I started working on my own this was the first thing I bought. www.panavise.com/index.html?pageID=1&page=full&--eqskudatarq=5The Panavise allows you to stuff parts, then quickly flip the board to solder. Speeds things up and holds everything securely. It's also good for holding other projects besides PCBs. It's way more than a tinkerer like me needs, but it is Real Gear. Panacise makes several interchangeable heads, including one for fairly large PC baoards and a normal small vise-type head in addition to the one in the ad.
Post by johneppstein on Oct 30, 2020 17:23:48 GMT -6
Yeah, that's the one for larger boards.
They also have/had a "Junior" model that wasn't interchangeable, and bases for the interchangerable line that either bolted/screwed down or used a vacuum shoe for adhesion.
Post by svart on Oct 30, 2020 17:53:14 GMT -6
I also have a panavise. I use it occasionally but since I usual work with SMD, I usually just put the boards flat on the bench when soldering.
