Post by svart on Oct 19, 2020 19:55:11 GMT -6
So I have this 69 epiphone newport bass that someone gave me a long time ago. It's seen better days for sure and it's got a lot of poorly done mods that I'm wondering if I can remove and go back to mostly stock.
Someone changed the pickguard outline and changed the bridge from stock, and in doing so filled some leftover holes and left some others and covered them up with the bridge and some of the leftover pick guard material.
Also, there's a ton of nicks and scratches and a place where someone punched through with a screw and closed it back up with a dowel. It's obviously been repainted at some point, but they used nitro it seems.
I know it's not worth top dollar as is, but I'm considering stripping the body, fixing all the bad stuff and redoing the nitro finish to get it to some kind of sellable quality but I've never done anything with nitro at all, only enamels and epoxies.
Anyone had experience that can tell me if I should tackle this or not?
Post by stratboy on Oct 21, 2020 20:55:08 GMT -6
Check Stewmac.com for info on how to do it. I have two Epi LPJrs that I want to refinish and Stewart-MacDonald seems to be a good source of info on the process.
Post by svart on Oct 22, 2020 14:06:50 GMT -6
Check Stewmac.com for info on how to do it. I have two Epi LPJrs that I want to refinish and Stewart-MacDonald seems to be a good source of info on the process. Thanks. I'm still unsure whether it would be easier to just strip and refinish the whole thing at this point, or try to fill the chips and scratches and redo the back paint or not. Seems like nitro is just a lengthier process but still easy overall.
Post by johneppstein on Oct 23, 2020 12:49:26 GMT -6
Is it one or two pickups? I don't believe it was in the catalog, but I have seen 2 pickup versions with the later, asymmetrical body and batwing head.
Post by svart on Oct 23, 2020 13:19:21 GMT -6
Is it one or two pickups? I don't believe it was in the catalog, but I have seen 2 pickup versions with the later, asymmetrical body and batwing head. The one wide eb0 humbucker pickup. Looks like this but with different bridge and modified pick guard: www.epiphonewiki.org/index/File_NewportEBS2.php
