Post by btreim on Jul 29, 2013 15:27:01 GMT -6
I'm going to take advantage of the "no dumb questions here".
Can someone explain impedance? For some reason I've always had a block in my head that I just can't seem to shake. I keep trying to come up with some sort of example to explain it to myself, and that's just not working.
Here's how I understand it, if someone would be so kind as to tell me how wrong I am.
Air is blowing through two straws at the same speed. One straw is Jumbo sized (less resistance) one is a coffee straw(more resistance) The air coming out of the smaller straw has more air pressure, even though there is more resistance.
So a ribbon mic with low output will react better with more input resistance, or a higher impedance?
Impedence
Jul 29, 2013 21:21:29 GMT -6
via mobile
Post by svart on Jul 29, 2013 21:21:29 GMT -6
Impedance is to AC as resistance is to DC, is essentially the idea.
If your air pressure(voltage analogy) is the same on the source sides of the straws and stays constant, the the size of the straw(resistance/Impedance analogy) Will determine the flow(current analogy) on the output.
Taking this, the Mic has only a certain amount of power (voltage x current) can generate. A series impedance will drop the power it can transfer to the load by limiting current and therefore voltage. A shunting or grounding impedance/resistance will drop the power by wasting current as heat. In either case, the Mic will probably lose low end frequencies first and then lose level as the series impedance/resistance is increased or the sinking impedance/resistance is decreased.
Post by horvitz on Jul 30, 2013 4:18:09 GMT -6
Post by svart on Jul 30, 2013 8:22:00 GMT -6
I forgot to add, yes, a ribbon mic that sees a higher impedance will give a higher signal power to the receiver. However, since impedance is a complex system, there are a lot more things to take into account. If you aren't matching load impedance to the source, then you can start having things happen like resonances and over/undershoot, etc.
Post by jimwilliams on Jul 30, 2013 10:51:05 GMT -6
Impedance is the resistance you get from your wife.
Impedence
Aug 1, 2013 16:40:04 GMT -6
via mobile
Post by brianellefson on Aug 1, 2013 16:40:04 GMT -6
Impedance is the resistance you get from your wife. I thought maybe this was Jim Williams the tech, but then I'd never read a post of his that had JUST humor in it.
Post by Deleted on Aug 6, 2013 3:56:08 GMT -6
Post by btreim on Aug 6, 2013 8:29:21 GMT -6
Thanks for the great info everyone. I feel like I'm starting to grasp the concept more, starting with how to spell the word impedAnce.
