Post by gwlee7 on Feb 23, 2020 14:27:32 GMT -6
Not trying to be that guy but I just took delivery of an ASP 880 from a major retailer with a generous return policy. I have not opened it. It checks all the boxes for me but now all of a sudden issues with them dying, fritzing out, and not working properly are popping up every where. Should I just send it back and not potentially cause myself any grief? It’s not like there a ton of 8 channel mic pres with ADAT out there that have these features. First world problems for sure.
Post by veloce on Feb 23, 2020 15:15:44 GMT -6
I bought one used about three years ago. It has worked really well… Although the power supply blew a capacitor last year. I sent it to a repair facility in Los Angeles recommended by Audient. Been working great ever since.
Based on my experience, I recommended this unit to a friend of mine figuring that my errant power supply issue falls under the heading of sh@t happens….
His experience has been an utter nightmare… Bought the first unit, It quickly went bad… Sent it back and got a second unit… That one immediately went bad… Sent it back… Got a third unit… Same scenario.
So while my personal experience has been good with the unit, something definitely seems to be up with their quality control of late.
Post by kcatthedog on Feb 23, 2020 15:19:37 GMT -6
3 recent bad ones and other anecdotal info about poor qc is concerning.
Your new unit could be fine. I’d plug it in and don’t turn it off, ensure it’s ventilated but if some part is bad it should just go: soon!
If everything is ok, it should just keep working.
Post by gwlee7 on Feb 23, 2020 15:21:21 GMT -6
This is what is concerning me. I don’t want to get on the bad batch merry go round.
Post by kcatthedog on Feb 23, 2020 15:23:52 GMT -6
Qc and SPC stats are in your favour, as out of spec parts/ builds should be in the very, very small minority. Your call. I’d plug in in !
Post by gwlee7 on Feb 23, 2020 15:24:22 GMT -6
3 recent bad ones and other anecdotal info about poor qc is concerning. Your new unit could be fine. I’d plug it in and don’t turn it off, ensure it’s ventilated but if some part is bad it should just go: soon! If everything is ok, it should just keep working. or, I could return it, add $2k to the purchase price and have a Grace. 😂
Post by kcatthedog on Feb 23, 2020 15:31:55 GMT -6
Options are your friend !
Post by gwlee7 on Feb 23, 2020 15:37:52 GMT -6
Options are your friend ! But alas, not all options are prudent. Your suggestion of busting it out and plugging it up is sage advice indeed.
Post by Tbone81 on Feb 23, 2020 15:55:33 GMT -6
I had one and used it regularly for 2 years. Worked flawlessly. Like all things sometimes manufacturers get a bad run of components etc. Audient is generally a reliable company.
Post by kcatthedog on Feb 23, 2020 16:48:57 GMT -6
If it’s got a bad part or parts, they should just fail.
I’d stress test it, from cold turn it off and on a silly number of times counting 5-10 seconds in between power ups .
If anything is wonky in surge should stress it. If nothing fails, then leave it on for an extended time : a day or two, but ventilated.
Post by sirthought on Feb 23, 2020 16:55:44 GMT -6
I've had my ASP 800 for about six years with zero issues. Technology can have problems, so anything is a risk.
Like you said, that many channels at a decent price is hard to find. I'd take the risk knowing that there is a warranty. A good power condition might be a good idea.
Post by gwlee7 on Feb 23, 2020 17:27:28 GMT -6
I am gonna do what kcatthedog says and fire that puppy up.
Post by kcatthedog on Feb 23, 2020 17:46:00 GMT -6
You've got the warranty but it should work fine !!
Post by sean on Feb 23, 2020 20:54:27 GMT -6
I think, with the internet, you often only get to hear about the “bad” and not the good. Especially with brands available from major retailers. There are probably 10,000 of those units in the world being used but it takes something to go wrong for someone to go online and complain.
If it checks the boxes of your needs then use it! Don’t let a few peoples bad experience steer you away.
Post by javamad on Feb 24, 2020 12:28:41 GMT -6
I have mine since 3 years back. Gets used every day. Is switched on for 4-8 hours a day. Not a single issue.
I love the sound and the flexibility for that price.
So ... another positive experience to counter some of the bad.
Post by gwlee7 on Feb 24, 2020 19:17:21 GMT -6
I was just kinda psyching myself out for a minute. I pretty much sit in my room and record mostly by myself in working on original material. Occasionally, the other two guys I play with come over and we cut some demo tracks to update our song list for getting gigs as a mostly acoustic trio that plays classic country and rock covers. What’s the worse thing that can happen to me? OH NO!! the Audient crapped out and now I have to plug the Scarlett octopre back in till replaced or fixed. Like I said, it’s first world problems.
Post by kcatthedog on Feb 24, 2020 19:19:55 GMT -6
Well just make certain you don’t plug it in upside down otherwise everything will be out of phase !
Post by 000 on Feb 24, 2020 22:36:08 GMT -6
I’ve been using one of these as part of a mobile recording rig/utility pres in the studio. Great fast clean sound. No issues at all.
Post by gwlee7 on Mar 1, 2020 19:42:36 GMT -6
I may end up being that guy. Took it out of the box this afternoon and used two channels to start knocking down some ideas. Worked fine so I powered it off and did some other stuff. Came back after a while and when I powered it back up, one of the channels was crackling and popping so I powered back off and then back on and it stopped. It is not making me feel very confident. I may just send it on back and save up and get the Grace. Hmmmmm.
Post by kcatthedog on Mar 1, 2020 20:37:04 GMT -6
Give it one more chance, sure your buffer is set correctly ?
Post by gwlee7 on Mar 1, 2020 21:16:20 GMT -6
Give it one more chance, sure your buffer is set correctly ? I believe so but, I will certainly mess with it some more. I still have a good long time to try it out.
Post by gwlee7 on Mar 7, 2020 22:22:22 GMT -6
I really, really, like sound of this thing. So, I hope it holds together. 😀
Post by plinker on Apr 17, 2023 12:48:26 GMT -6
I really, really, like sound of this thing. So, I hope it holds together. 😀 What ever happened here, Greg? I'm considering one. Thanks.
Post by srb on Apr 17, 2023 14:12:58 GMT -6
I have an 800 for the last 6-7 years. It has been used to cut radio/voice over, and for quick capture of song ideas. It's in my B room, so not something I turn to every day, but often enough. I interface it with a Lynx Hilo, and it's worked flawlessly. It's a good value, I think.
Post by gwlee7 on Apr 17, 2023 16:41:37 GMT -6
I really, really, like sound of this thing. So, I hope it holds together. 😀 What ever happened here, Greg? I'm considering one. Thanks. I sold it to Mister Chase a right good while ago. As far as I know it’s still kicking ass and taking names.
