Post by kcatthedog on Feb 14, 2020 17:17:54 GMT -6
Just wondering what people are using ?
Post by svart on Feb 14, 2020 17:42:34 GMT -6
Svartbox
Post by wiz on Feb 14, 2020 17:44:33 GMT -6
I know the guy who designed that...... (rubbing nails on chest......) 8)
Post by aremos on Feb 14, 2020 17:48:30 GMT -6
Post by kcatthedog on Feb 14, 2020 17:49:21 GMT -6
How svart of you to have one , you are just a wiz at those kinds of gear decisions !
Post by svart on Feb 14, 2020 17:57:31 GMT -6
How svart of you to have one , you are just a wiz at those kinds of gear decisions ! It was an easy decision since I know the designer.
Post by jcoutu1 on Feb 14, 2020 18:03:00 GMT -6
Built in MacBook Pro DAC.
Post by kcatthedog on Feb 14, 2020 18:17:40 GMT -6
How svart of you to have one , you are just a wiz at those kinds of gear decisions ! It was an easy decision since I know the designer. Fair enuff, but respectfully I question your objectivity !
Post by svart on Feb 14, 2020 18:28:02 GMT -6
It was an easy decision since I know the designer. Fair enuff, but respectfully I question your objectivity ! Well the designer is a bit shifty, but overall a marginally ok person. Marginally.
Post by ericn on Feb 14, 2020 18:38:24 GMT -6
Fair enuff, but respectfully I question your objectivity ! Well the designer is a bit shifty, but overall a marginally ok person. Marginally. Yeah he has this way of dragging things down into the sewer, wait that was his old job.
Post by ericn on Feb 14, 2020 18:39:34 GMT -6
Built in MacBook Pro DAC. How in PC of you, but of course only the post 2018 MBP, anything earlier is just crap.
Post by Blackdawg on Feb 14, 2020 22:05:30 GMT -6
Merging technologies HAPI
Post by drbill on Feb 15, 2020 0:37:31 GMT -6
Grace m905 Black here. It was between that and the Crane Song Avocet II for me, and the grace won out. Really made a big difference mixing. I can hear much better now....
Post by nomatic on Feb 15, 2020 7:19:22 GMT -6
Prism over here.... I also have Metric Halo and JCF in the shop...
Post by trakworxmastering on Feb 15, 2020 12:20:26 GMT -6
Burl BDA4M, BDA4, BAD4M and BAD4 cards in the Mothership. So many great sonic options with these cards!
Post by indiehouse on Feb 15, 2020 12:57:09 GMT -6
Is the Dangerous considered mastering grade?
Post by kcatthedog on Feb 15, 2020 13:21:48 GMT -6
I’d say so!
Post by Johnkenn on Feb 15, 2020 13:33:24 GMT -6
But wait...I was told the Dangerous sounds too good...so there must be some clock issues with it. 🙄
Post by notneeson on Feb 15, 2020 13:52:55 GMT -6
Is the Dangerous considered mastering grade? I think mastering gear is Chris Muth's backgound, isn't it?
Post by Deleted on Feb 15, 2020 15:13:24 GMT -6
recently purchased an old used prism ada for mastering and had it serviced by the company, so far so great..
Post by drsax on Feb 15, 2020 15:58:49 GMT -6
Using Lynx Hilo here for mastering. Have also used Svart’s converter in the past as well.
Post by ericn on Feb 15, 2020 18:22:11 GMT -6
Is the Dangerous considered mastering grade? I’m going to go by the standard of the old days, if somebody uses it for mastering and their work doesn’t sucks it’s mastering grade. Just because somebody decided their gear can be used for mastering doesn’t mean it should be used for mastering i.e. coming soon the Behringer Composer Mastering addition, we put it in a pretty colored case, changed to detented pots that will never match channels and quadrupled the price. So it’s now a piece all mastering engineers must buy because it says so.
Post by cowboycoalminer on Feb 24, 2020 12:42:12 GMT -6
Grace m905 Black here. It was between that and the Crane Song Avocet II for me, and the grace won out. Really made a big difference mixing. I can hear much better now.... I see the Grace has digital out as well as in. I'm assuming with the in, one could clock an interface off the Grace as well?
Post by Blackdawg on Feb 24, 2020 12:54:43 GMT -6
Grace m905 Black here. It was between that and the Crane Song Avocet II for me, and the grace won out. Really made a big difference mixing. I can hear much better now.... I see the Grace has digital out as well as in. I'm assuming with the in, one could clock an interface off the Grace as well? Correct. Or just use the World Clock output.
Post by svart on Feb 24, 2020 13:13:03 GMT -6
I see the Grace has digital out as well as in. I'm assuming with the in, one could clock an interface off the Grace as well? Correct. Or just use the World Clock output. Word typically needs to be upconverted to a higher frequency to be useful for Delta-sigma converter ICs. This multiplication also multiplies the jitter. Digital like spdif has encoded clock in the MHz range and typically is divided down, also dividing jitter. I'd always use the digital stream as clock source if necessary to have an external clock of any type.
