Post by keymod on Dec 15, 2019 7:44:46 GMT -6
I need a refresher for proper use. I assume the following:
1) remove knob/cap from shaft
2) apply deoxit to shaft where it meets the body of the pot
3) allow deoxit to work it's way down the shaft, into the pot
4) manually work the pot shaft back & forth to distribute the cleaner into the pot, thereby cleaning the contacts and removing oxidation/gunk/etc..
Is this correct procedure? Any other tips?
Post by svart on Dec 16, 2019 7:50:44 GMT -6
That's not going to get enough into the pots to clean, only to lube. Gotta get to the backs of the pots and blast them from the openings if you really want to gets then cleaned.
Post by keymod on Dec 16, 2019 17:59:20 GMT -6
So then, most pots have openings at the rear?
Post by Deleted on Dec 17, 2019 10:27:20 GMT -6
So then, most pots have openings at the rear? Most.
Post by Ned Ward on Dec 18, 2019 10:11:08 GMT -6
Post by BenjaminAshlin on Dec 22, 2019 21:33:53 GMT -6
What are sprays are people using to clean pots? I haven't found one that doesn't remove the grease. Any recommendations would be appreciated. (we have limited selection over here)
Post by mulmany on Dec 23, 2019 21:52:37 GMT -6
Use a fader lube after the cleaning if you feel like it's removing the grease.
