Post by indiehouse on Nov 24, 2019 7:41:58 GMT -6
Please tell me this is a user issue, because I'm losing my friggin' mind. Using Beat Detective per usual. Clip seperation mode, capture selection, analyze, in 'normal mode' I go through entire track to check kick drum markers, then add all to collection. Same for snare track, then add unique to collection.
Now here's the screwy part. My markers are disappearing in collection mode. Like, I literally scroll through until they are just off-screen, then go back and they are gone. Completely random. I've done this process three times now, and it's still happening. I'm losing my mind here.
Post by jeremygillespie on Nov 24, 2019 9:35:47 GMT -6
Only do 8 bars at a time and you’ll be fine.
Sometimes you’ve got to mess with it a bit if there are lots of tripplet kicks and what not... but that’s the best way I’ve found to do it and make it work.
Post by indiehouse on Nov 24, 2019 10:33:50 GMT -6
Only do 8 bars at a time and you’ll be fine. Sometimes you’ve got to mess with it a bit if there are lots of tripplet kicks and what not... but that’s the best way I’ve found to do it and make it work. Right on. Thing is, I’ve already done the messing about part of it. Went through the whole tune adjusting the kick markers (adding, subtracting, etc.),and the same for snare. Added each to collection, which should freeze them, save them in place. But some markers ended up missing, or are there until I scroll the marker off screen and back again, then they’re gone. I’ve used beat detective a bunch before and never had this problem.
Post by Ward on Nov 24, 2019 11:48:19 GMT -6
I swear to God it freaking hates me, and I just do it manually now
Post by indiehouse on Nov 24, 2019 12:18:44 GMT -6
I swear to God it freaking hates me, and I just do it manually now That’s what I ended up doing for the markers that disappeared.
