Jcm2000
Nov 13, 2019 22:01:57 GMT -6
via mobile
ragan likes this
Post by svart on Nov 13, 2019 22:01:57 GMT -6
Just repaired one of these I got for cheap because it was an early model that suffered from the notorious bias failure the early versions had once they got older. I also changed a couple resistors to get the Marshall sound to come out a little more.
Sounds pretty rocking even though I'm only running it as a 50w amp with two el34s instead of the normal 4.
Post by jcoutu1 on Nov 14, 2019 14:25:46 GMT -6
I've got a 2000 DSL. Use it ALL the time. My most used amp by a mile.
Jcm2000
Nov 14, 2019 15:00:26 GMT -6
Post by svart on Nov 14, 2019 15:00:26 GMT -6
I've got a 2000 DSL. Use it ALL the time. My most used amp by a mile. Yeah this is a MIE 2000. It's a DSL but doesn't have the DSL printing on the front. I guess it was pre-TSL and they hadn't yet needed to differentiate between them. I'll try it as 100W tonight and see how it goes.
Jcm2000
Nov 14, 2019 15:35:43 GMT -6
via mobile
Post by jcoutu1 on Nov 14, 2019 15:35:43 GMT -6
I usually pair it with a recto cab and not the Marshall.
Post by svart on Nov 14, 2019 15:55:32 GMT -6
I usually pair it with a recto cab and not the Marshall. Rectos usually have V30's in them and the marshalls have greenbacks. I typically like V30's on marshalls too as the greenbacks can get too screechy.
Jcm2000
Nov 14, 2019 16:40:27 GMT -6
via mobile
Post by jcoutu1 on Nov 14, 2019 16:40:27 GMT -6
Recto can just feels more solid.
It's really perfect for a lot of the punkish stuff I work on.
Jcm2000
Nov 29, 2019 13:20:19 GMT -6
via mobile
EmRR likes this
Post by svart on Nov 29, 2019 13:20:19 GMT -6
I finally got this thing running at 100w. Had to replace the octal sockets because one was corroded beyond repair.
This is probably one of my favorite amps now. It really does sound better running at 100w too. The extra distortion from driving the output tubes seems to really smooth the overall tendency to have too much grit.
It also seems to really like an old ds-1 distortion a lot.
Jcm2000
Nov 29, 2019 17:43:16 GMT -6
via mobile
svart likes this
Post by notneeson on Nov 29, 2019 17:43:16 GMT -6
I finally got this thing running at 100w. Had to replace the octal sockets because one was corroded beyond repair. This is probably one of my favorite amps now. It really does sound better running at 100w too. The extra distortion from driving the output tubes seems to really smooth the overall tendency to have too much grit. It also seems to really like an old ds-1 distortion a lot. Reminds me... A couple years back I was recording a jcm 900 that really came to life with a DS-1, very familiar sound. Also, that amp sounded pretty mediocre, except at the settings someone had written on the face plate in sharpie. Same studio has sharpie marks on their 1176, also very good!
Post by monkeyxx on Aug 6, 2020 5:47:54 GMT -6
I have the modern made in Vietnam DSL 100W head, it's a wonderful amp. I also have the 40 combo of that amp.
Speaker cabinet makes a big difference. My favorite cab right now is the 1960A standard cab from Marshall, with the G12-T75 speakers. Gives it a fuzzy, relaxed, resonant low end sound. It's a sound you hear on records. Fugazi, Smashing Pumpkins, that kind of stuff. With the right guitar you can nail those tones with this amp/cabinet.
The clean channel is probably a little bit better with the Avatar cabinet, which I am in the process of adding new speakers to (Texas Heat, Classic Lead 80).
The comobo almost sounds like a different amp, I have a G12M-65 Creamback in that one. It's easier to haul to small gigs.
Both amps are very smooth on the top, not zingy. More thick and rich or something.
Anyway, yeah, I'm a fan. A no fuss amp. Plug it in and rock. Clean or dirty, pedals, whatever.
Post by johneppstein on Aug 6, 2020 21:45:32 GMT -6
2 JMP 50s in the hall downstairs, belonging to my guitarist and his son. Bob's is EL34s. Steve's is 6550s, I think.
Post by ward of the state on Aug 7, 2020 19:26:07 GMT -6
2 JMP 50s in the hall downstairs, belonging to my guitarist and his son. Bob's is EL34s. Steve's is 6550s, I think. I have some of those JMPs also. Best Marshalls ever, save for Plexis, but that's debatable. Both are tone generators.
Post by levon on Sept 25, 2020 8:40:55 GMT -6
The DSL 50 (JCM 2000) was my first Marshall amp. I still have it and love it, even though I now have a '79 JMP 50, an '88 Plexi reiusse and a Silver Jubilee too. My DSL is the UK-built model with a spring reverb tank, not the later one that came from Asia with digital reverb. Jeff Beck used to play it too, he had a couple on stage back in the day.
