Post by M57 on Jun 18, 2019 11:13:24 GMT -6
I can't imagine just running a studio with just a laptop. I guess there are sonic reasons to not have too much glass in front of you, but I use up every square inch of a 21" and my 27" iMac. Come to think of it, I can't imagine not having two monitors.
Post by Tbone81 on Jun 18, 2019 11:17:03 GMT -6
I use a 32” tv and it’s great. I’ll never buy a “real” computer screen again.
Post by M57 on Jun 18, 2019 11:21:03 GMT -6
I use a 32” tv and it’s great. I’ll never buy a “real” computer screen again. Hah, That's not what it looks like on your avatar.
Post by Ward on Jun 18, 2019 11:21:14 GMT -6
I’m using dual 42” LCD screens. May bump up to 60s as my ‘screen efficiency ‘ decreases.
Post by Tbone81 on Jun 18, 2019 11:23:28 GMT -6
I use a 32” tv and it’s great. I’ll never buy a “real” computer screen again. Hah, That's not what it looks like on your avatar. Haha, fair enough! That pic was from when I worked in broadcast. You can’t see it but there were actually a total of 5 screens, including a tv.
Post by Deleted on Jun 18, 2019 11:24:02 GMT -6
1 24" monitor for eight years now. If it dies I might get a 32" TV instead.
Post by Bender on Jun 18, 2019 12:11:37 GMT -6
I've done three screens, and two screens....currently running one 34" Ultrawide at 1440- kind of like two screens.....feel like two might be the sweet spot.
Post by stormymondays on Jun 18, 2019 12:48:44 GMT -6
Laptop here, plus a miniature screen dedicated to Console 1. I love that people can’t stare at waveforms when listening to playbacks. Editing sucks which means I try to get people to play things correctly :-)
If I could have some kind of stowaway screen that I could use when clients are not in, I might get one. However, my studio build doesn’t allow for that.
Post by Blackdawg on Jun 18, 2019 13:18:42 GMT -6
I love having two. One where you're editing on. The other for certain plugins that stay open all the time, limiter, Insight, stuff like that. Not every system I use has 2 though.
Post by jcoutu1 on Jun 18, 2019 14:34:20 GMT -6
I use my laptop with a second screen. 55" at the studio, 34" in my home mix room. I get by on just the laptop when traveling.
Post by mulmany on Jun 18, 2019 14:47:15 GMT -6
32" tv and 24" 4k monitor. Monitor for edit window and tv for mix window.
Post by subspace on Jun 18, 2019 14:57:03 GMT -6
15” MBP + 34” ultrawide over HDMI. The ultrawide runs a screen splitting control panel so I can pop each section in/out of full screen.
Post by popmann on Jun 18, 2019 15:08:34 GMT -6
So, I answered 1 as that's my current configuration--a 27" LED. But, there's a second monitor I used to use sitting there, debating whether I should plug it in (there's not a really great location right now)....and when I use Cubase, it's nice to have. They've improved that---it used to be that you NEEDED multiple screens (and I had them)....but, I also want to throw in a "defense" of the laptop:
When I did that--had the ability to dock the laptop to the 27"....or use the tiny Air screen (it's the bigger one so....13"?)....if I was working on music creation, I liked to leave just the laptop on. Mixing--other way, I'd clamshell it and put the big monitor on--but, I've LONG said that one of the things that's a LOSS in a modern studio is the intentional blindness. The constant barrage of bright colors to the visual cortex is negative. I'f Im being a musician--whether that's singinging or playing an instrument--why do I need to see much of anything? The MCU or TranzPort can do most of the interaction I need until I get the take. So, I digress--but, if you're mixing on an analog desk--the fact that MBAir can play you say 300 tracks of a 96khz audio to however many IO over Thunderbolt means you CAN just live and breathe like the old days largely with a laptop over to the side on a stand/desk....I know LFAC aren't how most of us work....but, even without that, I'm telling you--there's a creative spark to be had from not seeing everything moving and flashing and colorful all the time.
I've actually considered what it would take to get one of those custom button macro controllers and just turn the monitor OFF until mix down. I just turned on the DAW, and I've been fiddling for literally an hour. Why? I dunno--bright lights and buttons are like lighter fluid for ADD. Imagine for a minute that you boot your machine, select the song....and then there are 24 record status buttons....no visuals. That's how I worked for a LOT of years. What did I NEVER do? Load one up and "fiddle with it" for an hour.
Side note: the thing I typically used the second scree for? permanent references: Totamix's mixer....master bus (VU) meters....input (Dourrough) meters big enough to see from the other side of the room....CPU/DSP/ASIO load meter....then when I was using the MacBook (so technically 3 screens) I kept the virtual instrument PC on the little screen that I didn't need to look at often....Logic maximized on the 27"....because OS X's multi desktops that you can literally swipe between means multiple screens aren't that useful BEYOND some specific things like "always on" metering to glance at....Win10 has something similar--and actually seemingly more powerful BUT....there's no Magic Mouse that swipes between them....that's one of those "devil's in the details" things that Apple did really well, I think.
Post by svart on Jun 18, 2019 15:08:52 GMT -6
1x 32" 1080p tv. Had a 27" monitor at 1440p but the fonts were too small to be practical.
4k would be too small. If I could find a 37" 1440p that will be ideal i think.
Post by Vincent R. on Jun 18, 2019 20:20:33 GMT -6
Post by jeremygillespie on Jun 18, 2019 20:28:55 GMT -6
1 - 27”. Flipping between mix and edit windows is quick and easy enough, and after my initial mix stuff, I do it all in the edit window anyways when I’m itb.
Two screens would mean I’d have to lose a set of monitors. And I don’t really want to do that.
The giant tv thing isn’t for me either. I’ve worked in studios that had them mounted behind the console and it wasn’t for me.
Post by sirthought on Jun 19, 2019 1:28:41 GMT -6
I have a 27" iMac and I just have two desktops and quickly swipe on the magic pad between the two. More screens would be nice, but I don't have the space. Doing the laptop thing is doable but just not fun.
Post by drew571 on Jun 19, 2019 1:45:09 GMT -6
If you guys haven't heard of it, check out spectacle. It's a free app for Mac that lets you snap windows wherever you want them with customizable keys. Really helps with window management.
Post by svart on Jun 19, 2019 8:45:07 GMT -6
For years I experimented with dual monitors, 14", then 17, then 19", etc. I finally had enough of the fiddling with windows and such and just went to the largest single monitor I could and never looked back. I can flip between docked windows easier than using multiple monitors because it doesn't involved having to reorient myself everytime I look at a new monitor.
Post by johneppstein on Jun 19, 2019 17:55:31 GMT -6
Zero screens. Well, there is one on the computer but it's not used for mixing and it's set up to the side, out of the way. It's used for unavoidable computer stuff, cueing tracks, etc.
If I did have to work ITB <shudder> I'd want two screens - one Slate Raven for mixing and a computer screen for other stuff.
Post by Guitar on Jun 19, 2019 19:54:15 GMT -6
2 Screens. Gotta have my two.
During leisure hours the right side small screen is permanently used for foober2000 which is my music player of choice, constantly being used.
With cubase the edit window goes on the big one and the mixer window on the slightly smaller one.
Sometimes some big visual references on the right side as well like others have said. Key plugins, meters, and whatnot.
I'd be interested in trying "one big screen to rule them all" but I have no real reason to switch it up right now.
Post by EmRR on Jun 19, 2019 20:08:31 GMT -6
I'd like a second, but I can't figure out where it goes relative to my control room window. I don't like the first one's sonic footprint in the first place. Running 4 desktops with things spread across them, so it's a quick flick to move around.
Post by kilroyrock on Jun 19, 2019 20:57:28 GMT -6
I mounted two 24s to walls with long moving arms. I can set up a keyboard and bring one monitor directly in front for a VI plugin, and then work directly from that without bending a neck. does that guy still sell the pro tools plugin that lets you split it to two monitors still? I think I may actually buy that now - dedicate one to mix screen, one to tracking
