Post by mcirish on May 22, 2019 9:31:30 GMT -6
Carrying on with the discussions from the Sonarworks thread, I'm wondering about optimal monitor placement. Years ago I did a bunch of research and got all the calculations for my room. I followed it pretty closely. I used Mode Calc & ETF5 for finding the position as well as documentation from real traps. My room is 19'2" x 9'8" x 8'. I always "assumed" the calculations were correct and my listening position and monitor placement was optimal. But now I'm beginning to wonder about that. The info from Mode Calc does not correspond to what Sonarworks shows. I believe my listening position is at the 38% position, or very close to it. That renders a lot of dead space from the mixing position to the front wall, which is very well treated. I'm wondering if I should start messing with speaker placement again. Maybe this could improve the 80hz dip (11dB) I have in Sonarworks.
Has anyone found a good, reliable source for info on this or is doing some trial and error the best approach. If I can gain back some floor space and make the dips and peaks a little less, I'd be happy. Yes, Sonarworks fixed the issues at the mix position, but I do lose nearly 12dB of headroom because of the compensation.
What say you?
Post by swurveman on May 22, 2019 11:11:51 GMT -6
I'd be curious to know this as well. After paying for a professional to treat my room, with specific advice of how far apart my speakers should be and where they should be pointed, Sonarworks had a very different response curve than the one I received.
Post by the other mark williams on May 22, 2019 11:12:04 GMT -6
How far are your monitors from the wall? Are they ported? If so, are they front or back ported?
Post by ericn on May 22, 2019 11:16:56 GMT -6
There are no set rules, everything is a compromise through in differences in rooms, speaker design, equipment layout and work flow. It really comes down to moving the speakers and listening. You can use the information provided by manufacturers, acousticians ect as a starting point but you would be surprised what a few cm or degrees tilt can make as far as imaging and bass response.
Post by ericn on May 22, 2019 11:24:30 GMT -6
How far are your monitors from the wall? Are they ported? If so, are they front or back ported? In 99% of the speakers out there front or rear porting makes little difference because the freq the port is tuned to has wavelength long enough that it is radiating in an Omni pattern. This has been proven many times by measuring the response of cabinets indentical except for position of the port. I know there is much miss information out there saying otherwise but it’s all based speakers where there is more differences than just port position.
Post by ericn on May 22, 2019 11:31:45 GMT -6
I'd be curious to know this as well. After paying for a professional to treat my room, with specific advice of how far apart my speakers should be and where they should be pointed, Sonarworks had a very different response curve than the one I received. Software and experts operate in the world of generic speakers, you have to have an understanding of frequency response, driver interaction and radiating pattern as well how all boundaries will effect these of your particular model of speaker to make anything beyond a guesstimate. Now in the world of live sound we have software and measurements provided by manufacturers that help predict a decent response but even then you would be surprised how often small adjustments make all the difference.
Post by swurveman on May 22, 2019 11:54:13 GMT -6
I'd be curious to know this as well. After paying for a professional to treat my room, with specific advice of how far apart my speakers should be and where they should be pointed, Sonarworks had a very different response curve than the one I received. Software and experts operate in the world of generic speakers, you have to have an understanding of frequency response, driver interaction and radiating pattern as well how all boundaries will effect these of your particular model of speaker to make anything beyond a guesstimate. Eric: I don't know if the "you" in your sentence referred to me, or the person I hired, but he used his own Remote Room Test Services to excite and examine the room, with the idea to understand it and treat it as effectively as possible given my budget. I don't know what his subsequent data, recommended acoustic materials along with location advice for treatment and positioning of speakers and desks, and then post treatment data, has to do with the world of generic speakers. They are the speakers I use, which generated the data that the test services analyzed pre and post treatment. So, if you could clarify what you are saying, so I could better understand it, I'd appreciate it.
Post by Tbone81 on May 22, 2019 12:32:50 GMT -6
Its trial and error IMHO, but as Eric said there are many credible sources of information that make great starting points (room calculators etc). There are so many unique variables to each and every room including the actual construction of the room itself. For example, was your room built with cheap ass 1/4" drywall that wasn't properly screwed down (like my room)? In my case the walls literally shake and that can work against you (exciting room modes) or for you (like a tuned membrane trap dampening low frequencies).
From my experience I'd say setup your monitors as best you can based on the information you have. Do it without a sub at first (if you're even using one). Then take measurements with REW (or another similar program), and start making small adjustments to positioning of the both the speakers and sometimes furniture that may be cause boundary reflections. Compare all the waterfall plots, pick the 2-3 that look the best and choose between them based on how they sound NOT on how they look. Trust me, the best "looking" frequency plot is not necessarily the best sounding one. You have to remember that we don't live in acoustically perfect environments, what sounds "normal" or "best" is somewhat subjective, and our ears are very adapted to hearing things in less than perfect environments. After you've figured the best placement and settings for your speakers add your sub and repeat the whole process with your sub, experimenting with different sub position and settings.
This could easily take you an entire day of work but its well worth it.
Post by stormymondays on May 22, 2019 12:51:13 GMT -6
Post by ericn on May 22, 2019 13:09:18 GMT -6
Software and experts operate in the world of generic speakers, you have to have an understanding of frequency response, driver interaction and radiating pattern as well how all boundaries will effect these of your particular model of speaker to make anything beyond a guesstimate. Eric: I don't know if the "you" in your sentence referred to me, or the person I hired, but he used his own Remote Room Test Services to excite and examine the room, with the idea to understand it and treat it as effectively as possible given my budget. I don't know what his subsequent data, recommended acoustic materials along with location advice for treatment and positioning of speakers and desks, and then post treatment data, has to do with the world of generic speakers. They are the speakers I use, which generated the data that the test services analyzed pre and post treatment. So, if you could clarify what you are saying, so I could better understand it, I'd appreciate it. The you was meant in the broader generic sense, but to your point. Even a measured on location with the exact speakers by an acoustician is a compromise based on somebody else’s preference’s. Also we have to take into account that most acoustic measurements are based on average’s and use weighted filters that often hide a problem at a particular frequency as well as don’t really show how a particular speaker is going to image. Don’t get me wrong I wish all the tools worked better at this, moving speakers around and listening is time consuming and I’d kill for a faster solution! One thing that I often find that many ignore are the effects of fatigue and power compression. Fatigue is self explanatory but power compression is the effect of a speaker acting as a compressor as the voice coil gets hotter over time or at higher listening levels. I have found it is even more prevalent in compact powered monitors because of the addition of heat producing amps.
Post by svart on May 22, 2019 13:15:54 GMT -6
To be a little more practical about it, the biggest things are positioning so that the tweeter's sweet spots are pointed at your ears, and that your mixes translate well wherever or however your monitors are positioned.
Everything else is academic.
Post by indiehouse on May 22, 2019 13:23:54 GMT -6
To be a little more practical about it, the biggest things are positioning so that the tweeter's sweet spots are pointed at your ears, and that your mixes translate well wherever or however your monitors are positioned. Everything else is academic. At your ears or behind your head? I've heard both.
Post by indiehouse on May 22, 2019 13:24:31 GMT -6
How far are your monitors from the wall? Are they ported? If so, are they front or back ported? In 99% of the speakers out there front or rear porting makes little difference because the freq the port is tuned to has wavelength long enough that it is radiating in an Omni pattern. This has been proven many times by measuring the response of cabinets indentical except for position of the port. I know there is much miss information out there saying otherwise but it’s all based speakers where there is more differences than just port position. What about closed box speakers with a sub built in the rear?
Post by svart on May 22, 2019 13:30:19 GMT -6
To be a little more practical about it, the biggest things are positioning so that the tweeter's sweet spots are pointed at your ears, and that your mixes translate well wherever or however your monitors are positioned. Everything else is academic. At your ears or behind your head? I've heard both. I'd think the difference would be so small between the two positions that it wouldn't matter much, but I suppose that would come down to the monitor's sweet spots. As I mentioned in the other thread about the Footprint 01's I auditioned, the sweetspot was probably about 5-6" round at about 3ft away from the speaker, which was ridiculously small and unusable in my opinion. In a case like that, I'd expect the position could make a huge difference, but literally leaning forward or back a few inches made radical differences in tonality.
Post by svart on May 22, 2019 13:33:12 GMT -6
In 99% of the speakers out there front or rear porting makes little difference because the freq the port is tuned to has wavelength long enough that it is radiating in an Omni pattern. This has been proven many times by measuring the response of cabinets indentical except for position of the port. I know there is much miss information out there saying otherwise but it’s all based speakers where there is more differences than just port position. What about closed box speakers with a sub built in the rear? A different set of circumstances but similar issues. A port or sub on the back of a box that's too close to the wall will exhibit something like proximity effect and the bass will "bloom" more. This is why a lot of manufacturers put the ports on the front or subs on the side, or specify a minimum distance from the wall.
Post by ericn on May 22, 2019 13:42:32 GMT -6
In 99% of the speakers out there front or rear porting makes little difference because the freq the port is tuned to has wavelength long enough that it is radiating in an Omni pattern. This has been proven many times by measuring the response of cabinets indentical except for position of the port. I know there is much miss information out there saying otherwise but it’s all based speakers where there is more differences than just port position. What about closed box speakers with a sub built in the rear? In theory it shouldn’t matter, but in the case of a built in sub we talking about a driver operating a driver over a couple of octaves range and probably a non linear frequency and phase response. Add in room effects and I’ll say who knows? Of course all other variables being the same the same would be true if the sub were side or front firing.
Post by mcirish on May 22, 2019 14:31:30 GMT -6
Thanks for all the great replies. My issues (well, the ones I can solve) have been with stuff under 500hz. My room has a terrible dip at 80HZ. Reading at Arqen Acoustics shows that I might have my speakers at the 1/4 wavelength of 80HZ from the front wall (42"). That would explain the dip. I'm very curious about shortening the distance to the front wall. Maybe move it to where I have a peak at 180hz (18") and see if that makes things a little better. I know this is all science but there seems to be a little more than simple math at play. I'm not sure how anyone could get it right without making some test measurements with software and a reference mic. i have an idea what I will be doing this weekend.
Post by mcirish on May 22, 2019 15:45:17 GMT -6
I just read the Genelec monitor setup guide. I was also surprised that they recommend 2"-23" from the wall to the speaker to get rid of the low frequency null point at 1/4 wave. Very interesting. My thought is that moving my monitors might significantly improve the speakers in the room and thus Sonarworks would have to do less, which in turn would give me more headroom. Can't wait to try this out!
Post by christopher on May 23, 2019 10:25:02 GMT -6
I don't know if I should bring this up or not, but maybe it will help someone. I recently created an eq curve to flatten out my 3way monitoring, then decided to created one to flatten out the NS10's for fun. I don't have sonarworks, so it took a lot longer. Then I decided, 'well since I'm here what if I align both flattened pairs together to make one super system?'. And wow, this was interesting exercise and made me realize all the times I tried a sub I was doing it wrong.
I rolled off the 3ways to be the "sub" w/NS10's 'flat' on top. Then started to play with delaying one pair until they were in phase with the other. I never would have guessed how radical 1-3 samples of delay can transform the sound of the low mids. I was there, going sample by sample until eventually it was locked. Each new sample of delay caused a massively audible deep node to sound different. When I finally got them in phase, it wasn't what I expected. Out of phase was louder/ in phase was quieter. How I realized I was in phase was by lowering/raising the volume of each pair and there was no sort of filtering or change in sound at all. When in perfect phase, the lows won't have any 'sub' sound to them just depth like turning off a high pass filter. I think maybe its something we might need to consider if using a sub since so many systems have onboard DSP.
Post by professorplum on May 23, 2019 11:00:15 GMT -6
I've been tweaking my mixing/monitor positioning for the last year, and all I can offer is what worked for me:
I tried different room percentages, wave calculation tables, etc. and ended up with my PMCs as close to the front (behind computer) wall as I could. I have concrete walls so bass flys around like crazy in my room, and I have these custom built gigantic 7 feet tall corner traps with low GFR absorption. That made the biggest difference in smoothing out the bass in my room by far, even more so than moving the speakers/listening position. I have 4 inch absoprtion clouds and 6 inch first reflection point absorption panels. Having them on separate heavy stands off my desk with Isoacoustics holding them up helped as well.
I also ended up with them about 65 inches across from tweeter to tweeter, which has been recommended as a good starting width. Seems to sound best to me after tweaking. Make sure to get them toed in at 30 degree angles as well; check out an app called SpeakerAngle for your phone to do this easily. Also, moving the computer monitor so that its parallel with the tweeters with absorption on the back of the monitor like Thomas Barefoot recommends actually made a good bit of difference in my stereo image, especially the center. Was pleasantly surprised by that. Hope any of this helps!
Post by mcirish on May 24, 2019 8:01:56 GMT -6
I did some changes last night to the monitor and mix positions in my studio. I will post more once I do some screen shots. Overall, the change was absolutely for the better. One of the peaks around 180HZ significantly decreased and the huge dip at 80hz (12dB) is now down to only 6.5dB. That gave me a good 5dB jump in headroom alone. Very interesting. For the lst 10 years, I have had the studio monitors set in what I believed was the optimal position, according to all the calculations I ran. A few days messing with various positions and using Sonarworks has really made a vast improvement to clarity. I'm pretty surprised. I moved the monitors as far back as I could without them touching the rigid fiberglass absorbers. I would have never thought that would be a good location, but it has tested as the best so far. Heck, I even gained about 10sq/ft of floor space as well. More tests coming.
Post by Tbone81 on May 24, 2019 9:52:16 GMT -6
That’s awesome, sounds like a significant improvement!
Post by Guitar on May 25, 2019 13:54:03 GMT -6
My best position is about 5 or 6" inches from the front wall 703 panels to the back of the speaker cabinet. Also not exactly in the middle, vertically, from ceiling to floor, a little lower than center or middle I guess. Right in the exact middle of height there is a "dead" spot that is no good. My room is about 10 by 13 with 8 foot ceilings, fairly small. I am also in the "wrong" orientation in the wide setup of the room rather than the long and narrow front to back orientation.
When I moved my computer monitors up a few inches I swear that made an improvement recently as well.
Doing "Monitor Calibration" was critical for me, using an SPL meter to get exact L/R SPL balance. My monitor controller has trim pots for this.
This is something I have fought with for years. Also including speaker choice and DAC choice. As well as monitor controller choice.
My setup may not be applicable to anyone else's gear or room but I gotta give a big encouragement to go after it.
Once you get it right, you can forget about the gear and truly focus on the music. It's like being cured of a sickness.
Like other people have said tiny movements can produce big results, and it's well worth your time to experiment.
Post by javamad on May 26, 2019 6:59:56 GMT -6
I don't know if I should bring this up or not, but maybe it will help someone. I recently created an eq curve to flatten out my 3way monitoring, then decided to created one to flatten out the NS10's for fun. I don't have sonarworks, so it took a lot longer. Then I decided, 'well since I'm here what if I align both flattened pairs together to make one super system?'. And wow, this was interesting exercise and made me realize all the times I tried a sub I was doing it wrong. I rolled off the 3ways to be the "sub" w/NS10's 'flat' on top. Then started to play with delaying one pair until they were in phase with the other. I never would have guessed how radical 1-3 samples of delay can transform the sound of the low mids. I was there, going sample by sample until eventually it was locked. Each new sample of delay caused a massively audible deep node to sound different. When I finally got them in phase, it wasn't what I expected. Out of phase was louder/ in phase was quieter. How I realized I was in phase was by lowering/raising the volume of each pair and there was no sort of filtering or change in sound at all. When in perfect phase, the lows won't have any 'sub' sound to them just depth like turning off a high pass filter. I think maybe its something we might need to consider if using a sub since so many systems have onboard DSP. I am expecting delivery of the Dynaudio LYD48's and the 18S Sub next week. The reason I got the 18S (which is not cheap!) is because of the 3 band eq I can apply to help with room modes plus it has a feature where you can input the distance of each speaker and the sub and it lines up the phase. That phase feature could be the key to getting a natural sound. I will create a thread with more detail and my experience on them once they get here.
