miklo
Junior Member
Post by miklo on Apr 14, 2019 16:29:59 GMT -6
Just got a sweet deal on a used pcm42.
Any vocal tricks? What should I expect?
Is this a good tool for modern pop vocal processing?
Post by jeremygillespie on Apr 14, 2019 17:33:07 GMT -6
Sure - download a delay sheet, then take your tempo and figure out what an 1/8 note or 1/4 note would be and use that as your start. Bring up the feedback a touch and mix to taste.
I generally use two of them and use an 1/8th note on one and a 1/4 note on the other.
miklo
Junior Member
Post by miklo on Apr 14, 2019 19:04:34 GMT -6
Sure - download a delay sheet, then take your tempo and figure out what an 1/8 note or 1/4 note would be and use that as your start. Bring up the feedback a touch and mix to taste. I generally use two of them and use an 1/8th note on one and a 1/4 note on the other. Im slightly concerned about maintenance. With it being such an old unit. How often have you had to get yours serviced? And if so who serviced it? I want to make sure I'm covered if this thing is faulty lol
Post by Martin John Butler on Apr 14, 2019 20:32:20 GMT -6
That's still my favorite delay, and it's simple to use.
Post by jeremygillespie on Apr 14, 2019 21:00:05 GMT -6
Sure - download a delay sheet, then take your tempo and figure out what an 1/8 note or 1/4 note would be and use that as your start. Bring up the feedback a touch and mix to taste. I generally use two of them and use an 1/8th note on one and a 1/4 note on the other. Im slightly concerned about maintenance. With it being such an old unit. How often have you had to get yours serviced? And if so who serviced it? I want to make sure I'm covered if this thing is faulty lol Never had any problems. There is a sticky button on one of them but if you hit it just right it works fine haha. Honestly, if you tweak an H-Delay enough it gets damn close to the lexicon.
Post by Martin John Butler on Apr 14, 2019 21:14:34 GMT -6
I always get confused with the H-Delay. I gotta watch a tutorial or something. The PCM 42 was plug and play for me.
Post by Blackdawg on Apr 14, 2019 22:58:38 GMT -6
Best electric guitar delay too. Push the input to hit the built in limiter. So epic. Hope I can score a second one one day
