Post by bluegrassdan on Nov 25, 2018 22:42:14 GMT -6
How does this front panel design look? Any suggestions for tweaks?
Post by Ward on Nov 25, 2018 22:44:44 GMT -6
This excites me.
Of course I do!!
Post by hadaja on Nov 25, 2018 22:44:44 GMT -6
Maybe a light to show signal is passing through.looks good
Post by wiz on Nov 25, 2018 22:47:54 GMT -6
Looks beautiful
Post by Deleted on Nov 26, 2018 3:40:37 GMT -6
Looks great to me, better without blinky lights!
What's the Ribbon switch do?
Post by lando on Nov 26, 2018 6:11:35 GMT -6
Beautiful!
Post by bluegrassdan on Nov 26, 2018 7:24:53 GMT -6
The ribbon switch deactivates phantom and bypasses the input transformer secondary resistor, per 1930s RCA console specs for ribbon mics.
Post by Ward on Nov 26, 2018 7:28:15 GMT -6
The ribbon switch deactivates phantom and bypasses the input transformer secondary resistor, per 1930s RCA console specs for ribbon mics. Do you know if this is what 'Grace' does with the M101 preamps?
Post by bluegrassdan on Nov 26, 2018 8:17:31 GMT -6
From the website: “Built in as standard is our unique Ribbon Mic Mode, which bypasses the input decoupling capacitorss, raises the input impedance from 8.1kΩ to 20kΩ, and defeats the 48V phantom power, preventing damage to delicate ribbon mic elements.”
We have an 8-channel Grace at the studio. The ribbon function does sound good on ribbons and dynamic mics too.
Post by bigbone on Nov 26, 2018 8:38:01 GMT -6
A VU meter would be nice, !!!!!
Post by Deleted on Nov 26, 2018 8:46:14 GMT -6
But you'd need four and that'd increase the price considerably. Plus, is there room for 4 VU meters on that fascia?
Post by bluegrassdan on Nov 26, 2018 8:50:21 GMT -6
No room for VU meters. Nor do I want to muddy up the signal path or use a buffering amp. Just clean tube preamplification.
Post by spindrift on Nov 26, 2018 9:26:38 GMT -6
Looks great Dan. Is this a 4ch version of my 2ch unit? I’d be interested but I already have a 4ch Fearn to compliment my 2ch DBPre.
Post by bluegrassdan on Nov 26, 2018 9:35:58 GMT -6
Yes, Keith. But this is just a faceplate mockup. It will be some time before this is ready.
This version also does not have the shelving filters. Have you found them to be useful?
Post by spindrift on Nov 26, 2018 9:49:50 GMT -6
I have, especially on long ribbons ala 44bx or Melodium 42b. The proximity effect starts a couple feet out and your two chosen HPF settings tame them well. It would be a good nice-to-have in this unit but would it greatly increase cost and will another switch fit? All in all, I wouldn’t count the filters as essential because I can HPF later. The only time you might really miss them is if you’re following the pre with a compressor and the exaggerated bass response is pushing the comp too much.
Post by aremos on Nov 26, 2018 10:31:52 GMT -6
U size? Regular rack size also?
ollie
New Member
Post by ollie on Nov 26, 2018 14:05:27 GMT -6
is it possible to get more gain ?
Post by bluegrassdan on Nov 26, 2018 14:23:00 GMT -6
It is a 3u 19” standard rack. Don’t know the depth yet, but probably 11”.
More gain would come at the expense of a higher ratio input transformer, which I wouldn’t want to give up the Jensens. Or changing the output transformer, which I also don’t want to do. Or adding another tube gain stage, which is not my goal either.
Post by plinker on Nov 26, 2018 15:54:35 GMT -6
I loves me some chicken head knobs!
Post by lpedrum on Nov 26, 2018 16:23:50 GMT -6
Looks fantastic. I always like MUTE buttons on pres for same room recording, but only my Phoenix have them. It's so helpful to mute the pre for monitor speaker playback. ...Lorne
Post by spindrift on Nov 26, 2018 18:03:59 GMT -6
is it possible to get more gain ? Maybe a cloudlifter or FetHead for low output mics? Might be a solution...
Post by ulriggribbons on Nov 26, 2018 18:18:33 GMT -6
An extra 7db of gain for ribbon mics?
If you are going mic-> mic pre -> recorder, some ribbons will struggle on softer sources with 63dB of gain....
$.02
Post by nick8801 on Nov 26, 2018 19:21:46 GMT -6
That’s gorgeous Dan!
Post by drsax on Nov 26, 2018 19:42:21 GMT -6
Love this. I’d be interested in something like this if the price is right. Great idea Dan
Post by bluegrassdan on Nov 26, 2018 21:11:52 GMT -6
Looks fantastic. I always like MUTE buttons on pres for same room recording, but only my Phoenix have them. It's so helpful to mute the pre for monitor speaker playback. ...Lorne You’ll notice, it has an “off” position at full counter clockwise.
