Post by mrholmes on Nov 22, 2018 13:32:44 GMT -6
I know the Air EQ is very old but:
WOW what a cool EQ concept.
To my ears it is still one of the best sounding digital EQs I know, I can boost anything without getting BS. Just used it on Snare and Kick and this time Steven Slate is right - its a diffrent way to EQ something.
Its one of the "makes it easier" tools.
Got a clean big and open sounding SD in no time today. Same is true for the Kick.
I like the clean top end without smearing the image.
Post by Mister Chase on Nov 22, 2018 21:09:41 GMT -6
I won this in one of puremixes contests. It's really a great eq!
Post by mrholmes on Nov 23, 2018 5:01:16 GMT -6
I like the fact that I can shift click on the Q factor to change the spike of the EQ curve.
It saved me two times from using compression, because the transient peak is mild after the water treatmeant.
Post by lcr on Nov 24, 2018 2:23:04 GMT -6
Water always lowers my transient levels.
Post by bartacusad on Nov 26, 2018 21:49:48 GMT -6
I love it! It saved me from buying another eq I’ve had my eye on for a while. It’s really smooth sounding.
Post by Mister Chase on Nov 28, 2018 15:19:39 GMT -6
This plug sounds really great at 192khz(or other higher rates). I confirmed with Eiosis that is does not over-sample.
Post by Mister Chase on Nov 28, 2018 15:59:33 GMT -6
This plug sounds really great at 192khz(or other higher rates). I confirmed with Eiosis that is does not over-sample. Do any clean (non-dynamic) EQ’s have oversampling? I know EQuilibrium and Pro-Q2 do not I've no idea.
If by clean you mean non analog modeled, then I am not sure. The Sonnox Oxford EQ states oversampling in the manual but due to the wording I am not sure what it means. Then again, that is a model of a hardware EQ.
Is it a thing that no digital parametric(clean) EQ's oversample?
Post by M57 on Nov 28, 2018 18:07:47 GMT -6
I find the shift/click per/band mode to be a nuisance - I don't understand why there isn't a separate water/fire knob for each band. Let go of shift too early and you're changing the Q - or hold down option or control by accident and you're also changing the Q or worse - zero it out. That said, it sounds incredible and does something very useful that no other EQ does. I keep looking for reasons to drop my Everything Bundle subscription and then they go and throw this in, damn it.
