Post by Ward on Nov 9, 2018 9:22:35 GMT -6
Next thoughts on this . . . 1. at what normalized average gain level do most plugins overload? 2. Say you normalized to 66%? 3. Is it better to do that than just rely on clip gain? 4. And is plug in overload necessarily a bad thing?
Post by notneeson on Nov 9, 2018 10:51:50 GMT -6
So, what I love about it is this: say there's a section of a guitar track (or whatever) where the level changes dramatically (maybe due to a pedal going on/off etc). You just highlight the section, command E to separate the region, and then adjust volume accordingly for that section alone. The fader for the affected track stays where you had it, and can still be automated later for effect. I used to do this using audiosuite to adjust gain, but then you either have to be very confident (usually not a problem or remember to dupe the playlist before you adjust.
Clip Gain
Nov 9, 2018 11:30:20 GMT -6
via mobile
Post by Mister Chase on Nov 9, 2018 11:30:20 GMT -6
Yes indeed. Two ways, in fact. 3 even. Place the mouse pointer at the top of the media item and shift click to drag gain up and down. Alternatively you can choose to display the clip gain knob on all media items. The third way is double clicking an item to bring up its properties page. There is a tiny fader in there for gain.
Post by Ward on Nov 9, 2018 13:14:51 GMT -6
So, what I love about it is this: say there's a section of a guitar track (or whatever) where the level changes dramatically (maybe due to a pedal going on/off etc). You just highlight the section, command E to separate the region, and then adjust volume accordingly for that section alone. The fader for the affected track stays where you had it, and can still be automated later for effect. I used to do this using audiosuite to adjust gain, but then you either have to be very confident (usually not a problem or remember to dupe the playlist before you adjust. Something else we do alike.
Post by mcirish on Nov 12, 2018 8:35:13 GMT -6
I use it on everything. It beats riding the fader on the way in, for ease of use. It's always needed to even out vocal performances so the compressors don't do too much in one section and too little in another.
Clip Gain
Nov 12, 2018 11:51:46 GMT -6
via mobile
Post by iamasound on Nov 12, 2018 11:51:46 GMT -6
Ok, it isn't for clipping a signal. I do do this. I have been using Air Windows Purest Gain to effectively raise or lower gain of sections instead of riding fader.
