Post by jeromemason on Sept 18, 2018 22:50:19 GMT -6
Let me just start this with saying #1 Yes, I am endorsed by Izotope, but before these fine folks put their faith behind me, I was putting my faith and extremely hard earned dollars behind them! Next, when it comes to ground breaking innovation and just flat out quality, this new version of Izotope's RX is about as groundbreaking and a (how the F$*# did they do that!?!?!?) as I've seen!
First, let me start out with the new module that completely blew my mind. It's called Music Separation and by golly that's what it freaking does, and how it does it I have no earthly clue. You load a mix up, load this module up, and say after a few listens maybe you want to pull the vocals up a db or down a db..... Or you want to pull the bass up (without increasing the kick/kick sub I might add!) maybe you want the drums to be more punchy and louder, you can actually pull up the percussion I mean it's honestly like having stems! It will blow your mind. Also, you can obviously render sections with this module as well, so I'll let your minds wander and think of all the amazing possibilities with that!
This new version of RX is not only packed with new features, but it's processing has gotten much much better. I know you're probably saying (if you're an RX user currently) "better?!? it was freaking amazing to begin with Jerome!" well I'm telling you, the processing is leaps better and more realistic/pure than previous versions.
I'll let you guys go do the trial so you can experiment with RX7's awesome power on both individual instruments and full blown mixes, but I'll throw one little gem I discovered that would make me want to buy RX7 for it only. That's the De-Clip module. Let's say you've got a mix done and it's perfect, you've done your own mastering (Hopefully with Izotope's Ozone 8 Advanced btw! It's freaking amazing) and you want to go just one more step further, one more step that makes your final mix/master have all the dynamics, loudness and tone you've worked really hard to get, well, if you will just run that mix/master through the De-Clip module, use it's "suggest" function and process your whole mix through it, what you're going to instantly hear is your mix/master just be churned into butter baby. If you mix punchy and bright, you'll actually hear your mix/master retain all that but you'll newly discover this beautiful smoothness "butter" up your mix. It's just a last pit stop to make your mix that much better. It even makes the mix feel more glued, and it's an amazing sounding glue. Not a compressor or limiter glue, it's unique and it'll put a smile on your face.
So go get the trial guys! You can burn up your credit cards on hardware/gear all you want, but this software is worth every single penny and will do more for your mixes/masters/instrument integrity/fixes/creations 1000x more than any 1 piece of hardware dollar for dollar.
Also, anyone just wanting to see what it will do with your mix/master or instrument/voice- just message me and send me whatever you got and what you'd like to see RX7 do and I will be glad to do that for you! No problem!
Jerome
Jerome
