Post by Quint on Sept 17, 2018 18:39:59 GMT -6
Does anything out there exist similar to the Motu Monitor 8?
Not that I need all of the features of the Monitor 8, but the ones that do matter to me are:
1. Minimum of 6 to 8 individual HP amps 2. Minimum of 6 to 8 analog inputs 3. Digital matrix mixer for flexible internal routing 4. Web app/wifi/some other kind of wireless remote control accessible through a mobile device 5. Rack mountable and 1ru tall 6. It doesn't have to have the best conversion ever but must be reliable 7. Low latency (sub 2 ms rtl) 8. Under $1000 (new or used)
Post by EmRR on Sept 17, 2018 20:11:09 GMT -6
I'll tell you the Monitor 8 headphone outputs do not have enough juice to power an actual rock band with a drummer. I suspect similar of other similar products.
Post by Quint on Sept 17, 2018 20:21:36 GMT -6
I'll tell you the Monitor 8 headphone outputs do not have enough juice to power an actual rock band with a drummer. I suspect similar of other similar products. I'm also not necessarily opposed to just using a decent 8 channel interface with good routing, low latency, and wireless remote control to send to a separate HP amp, though that adds additional complexity and connections.... What interfaces beside the Motu stuff even offer wireless control? What headphones have you used with the Monitor 8, impedance of the phones being an obvious question?
Post by EmRR on Sept 17, 2018 21:10:31 GMT -6
MDR7506's. I forget the quoted power, 1/4W? It's not gonna fly with a drummer, no matter the headphones. Any decent headphone amp gives sufficiently more.
That's all I can add really, I don't have awareness or experience with any similar interfaces.
Post by javamad on Sept 18, 2018 2:35:00 GMT -6
I commented about using the Behringer Powerplay system in response to your post on the Apollo X thread.
Let me just add here that using Extreme Isolation EX25's you can't really put the volume past 50% unless you are in fact a rock drummer :-) This is fed from power over LAN so quite a good volume headphone amp there. I have also run 2 headphones using a splitter where I had more musicians than mixers and they had no volume problems ... it was just a bit tricky to get them to agree on a mix. I think the overall price of the Powerplay is going to be higher as each mixer costs $250 so you would need to take that into account.
I am actually not sure I would want people to be doing their own mixes on their phone(if that is your idea) .. it's difficult enough to see what they are doing on the Powerplay mixers but at least I can diagnose issues by walking over and clicking through the channels to see the volumes they have set. In the case of the Motu .. you'd have to take their phone off them? Could be awkward if there is not a good vibe with the artist. I recently had a drummer tell me the click wasn't coming through at all .. he had the master volume way down and all the channels way up ... I did a quick re-set and he was happy straight away. I had only met him 2 hours before .. not sure I would have felt comfortable asking him to hand over his phone?
Post by mulmany on Sept 18, 2018 4:04:34 GMT -6
Try looking at the rack mount versions of live digital mixers. Most of them are the same price as a 16a.
Post by Quint on Sept 18, 2018 7:36:23 GMT -6
MDR7506's. I forget the quoted power, 1/4W? It's not gonna fly with a drummer, no matter the headphones. Any decent headphone amp gives sufficiently more. That's all I can add really, I don't have awareness or experience with any similar interfaces. If so, I could just use one of the line outputs on the Motu instead and feed that to a standalone HP amp for the drummer if necessary.
Post by Quint on Sept 18, 2018 7:38:54 GMT -6
Try looking at the rack mount versions of live digital mixers. Most of them are the same price as a 16a. I have, and it's hard to find one that is 1ru tall and is remote controllable from mobile devices.
Post by ericn on Sept 18, 2018 9:52:01 GMT -6
I wish all these personal monitor systems had 24 or more ch!
Post by mulmany on Sept 18, 2018 15:16:21 GMT -6
Try looking at the rack mount versions of live digital mixers. Most of them are the same price as a 16a. I have, and it's hard to find one that is 1ru tall and is remote controllable from mobile devices. X32 rack, gives you all the features but is more then 1u. You would need a headphone amp system.
Post by javamad on Sept 19, 2018 16:33:33 GMT -6
I wish all these personal monitor systems had 24 or more ch! Depends on the artists I suppose. Many would be intimidated/distracted by all that tweaking power when they are supposed to be focussing on their performance ... or maybe you are getting a better class of artist :-)
Post by christopher on Sept 19, 2018 16:54:02 GMT -6
