Post by jcoutu1 on Sept 11, 2018 18:38:50 GMT -6
I've got a couple kits at the studio. I'm looking to make some head changes and maybe add some additional drums. The first is a DW Collectors Series. This is my primary kit, generally used for rock. 8x10, 9x12, 12x14, and 18x20. The toms currently have Evans EC2 heads, which I'm generally happy with, but the 14" (hanging) floor tom especially has a ton of sustain/long decay. What would you suggest to control the decay a bit? This looks like a decent option to try for the bottom head... evansdrumheads.com/EvProductDetail.Page?ActiveID=3567&productid=567&productname=Reso_7_Tom_Reso Anyone have experience with these? Is there something else worth looking into? I've read about guys stuffing cotton balls inside the drum that just live on top of the reso head. I also have a 63' Ludwig 14x22 kick and 9x13 rack tom that need some heads and clean up. I'd like to keep these with a vintage vibe. What would you slap on these guys for heads? I like the look of the faux calf skin reso kick heads, but have never used them. What would you slap for heads on these if you scored these drums. I'm also looking at picking up a stupid big, 14x28 vintage Gretsch/W&A kick. What would you slap on here for trendy indie folk? What's the word on drums from Taiwan? It seems like a lot of mid-level kits are coming from Taiwan. Gretsch, Pearl, Mapex, Taye. Are these any good? Give me the dirt on these.
Post by svart on Sept 11, 2018 20:19:06 GMT -6
I have a ton to say about this but can't right now. I'll do it in the morning when I'm back at a computer
Drum Chat
Sept 11, 2018 20:46:09 GMT -6
via mobile
Post by sean on Sept 11, 2018 20:46:09 GMT -6
DW question: Thicker the head/number of plies usually equals less sustain and a lower fundamental pitch. If your floor tom sustains too long, I would try something like a coated emperor, G2, or a G14. The Evans Reso 7 is a pretty thin head, like a Diplomat, and would have a higher pitch. It might be worth experimenting with, tuning the bottom head higher will usually equal less sustain compared to tuning both heads to the same pitch
Ludwig question: I personally like single ply heads on drums with re-rings. More drum is in contact with the head, which means less sustain. Remo makes a vintage ambassador which is made like the vintage heads which are a bit thicker, but not Emperor thick, so they might give you the sound you want. A coated emperor with a felt strip works great for a bass drum batter. I use Evans Calftones for resonant heads and they work great. They sound good as a batter head but don’t last...the coating has a tendency to crack.
I don’t have much experience with Taiwan drums.
Post by drumhead57 on Sept 11, 2018 22:45:56 GMT -6
re: "What's the word on drums from Taiwan? It seems like a lot of mid-level kits are coming from Taiwan. Gretsch, Pearl, Mapex, Taye. Are these any good? Give me the dirt on these. Read more: realgearonline.com/thread/9084/drum-chat#ixzz5QrLb556kPhilippine Mahogany. Cheap, plentiful wood. Not bad, really. I just played a Gretsch Catalina kit tonight (every Tuesday) and they are decent for the money.
Post by svart on Sept 12, 2018 8:18:35 GMT -6
I've got a couple kits at the studio. I'm looking to make some head changes and maybe add some additional drums. The first is a DW Collectors Series. This is my primary kit, generally used for rock. 8x10, 9x12, 12x14, and 18x20. The toms currently have Evans EC2 heads, which I'm generally happy with, but the 14" (hanging) floor tom especially has a ton of sustain/long decay. What would you suggest to control the decay a bit? This looks like a decent option to try for the bottom head... evansdrumheads.com/EvProductDetail.Page?ActiveID=3567&productid=567&productname=Reso_7_Tom_Reso Anyone have experience with these? Is there something else worth looking into? I've read about guys stuffing cotton balls inside the drum that just live on top of the reso head. I also have a 63' Ludwig 14x22 kick and 9x13 rack tom that need some heads and clean up. I'd like to keep these with a vintage vibe. What would you slap on these guys for heads? I like the look of the faux calf skin reso kick heads, but have never used them. What would you slap for heads on these if you scored these drums. I'm also looking at picking up a stupid big, 14x28 vintage Gretsch/W&A kick. What would you slap on here for trendy indie folk? What's the word on drums from Taiwan? It seems like a lot of mid-level kits are coming from Taiwan. Gretsch, Pearl, Mapex, Taye. Are these any good? Give me the dirt on these. I recently switched from Remo Pinstripes to Evans G2 on toms. After playing drums for 22 years, I'm really feeling that tuning seems to matter more than overall head choices. The better I've become at tuning, the better the drums have sounded and the less tape and moongel I've needed and used more traditional heads with less of all this "control" tech like the EC2 stuff, or really anything with muffling rings on toms. I have a stack of used heads that is at least 5ft tall.. I've tried them all. Currently the G2 on toms, and either Remo CS dots on snare or Aquarian Hi Velocity on snare depending on the snare drum. Brass and metal snares like the CS dot and the wood ones seem to like the Hi Velocity the best. I recently switched from Evans EMAD2 to Aquarian Superkick 3 on bass drum and use less padding inside the drum as a result and get more OOMPH without the beachball sound this way. I stopped using all those tricks like cotton balls years ago. I stopped taping drum heads and such too. Going back to the tuning, I found that it was much more reasonable to tune the drum in a certain way, and use small pieces of moongel as needed to dampen the decay. Note that I mean decay, not ringing. I found that tuning certain notes with this heads created a sweet-spot between attack and decay with minimal over-ring. For tuning the drums themselves, I always tune the bottom head tighter and leave the top head a little looser. I use a Tunebot device and tune my drums to notes at intervals. One trick is to get the batter head to perfect tuning, then either drop half a moongel on the logo for rack toms, or a whole moongel on the logo for floor toms. On the logo puts the moongel at the right distance to snuff the reflections without totally killing the tone of the head. if you want less ring, move the moongel under the mic, if you want more, move the moongel to the opposite side of the head away from the mic, but still the same distance from the rim. Another trick is to get the head in tune, then loosen a single lug at least one turn. You'll maintain most of the tuned note, but the slack will dampen the reflections. Overall, I can't overstate how crucial tuning is. It's a mastercraft that I've barely mastered after 2 decades, even with the help of tuning aids like the Tunebot. For large diameter kicks with short lengths, I'd go with something a little heavier than single ply so it doesn't sound flabby. The depth of the kick dictates how bad the beachball sound is, so a 14" wouldn't be that big of a deal for thinner heads, but you'll get a ripple across the head that will make it sound like paper rustling if it's too thin. Tuning tighter would reduce the ripple, but increase the overtones. It's this intersection of tension and overtones that dictates whether you should go with a thicker head or not. I'd try the original EMAD1 since you can replace the muffling ring to adjust the amount of overtones, and it's only 2 thin plys of mylar. As for drums from Taiwan, a lot of companies have been making their shells in Taiwan and China for years now. I wouldn't worry too much about where they're made, and consider the wood type and the drum sizes as more of a measure of the tone. The head and bearing edge are roughly 60% the tone of the drum, the wood maybe 20%, and then the mounting type the rest of it. I'd personally go for a cheaper drum with rim mounts, than an expensive drum with shell mounts if the type of wood were the same.
Post by bigbone on Sept 12, 2018 9:27:43 GMT -6
I would said the wood is 50% the tone of the drums, heads and tuning the other 50%.
All the rest, wood choice. heads. tuning . brand of drums is personal. Sit 2 drummer at the drums one after the other on the same kit and you will think that they play 2 different kits.Technic and how to play and hit the kit will have a lot more impact.
Drum Chat
Sept 12, 2018 9:35:01 GMT -6
via mobile
Post by jcoutu1 on Sept 12, 2018 9:35:01 GMT -6
Looks like Remo just dropped some prices. Good timing. 😁
Post by bigbone on Sept 12, 2018 10:20:14 GMT -6
REMO been doing very good in the last few years. !!!
Post by svart on Sept 12, 2018 10:58:19 GMT -6
Remo pricing dropped, but I find their heads are not as durable anymore for some reason. They seem to go out of tune a lot easier. I have a CS dot that I had for years in a box, and I recently put it on a snare, and just bought a brand new one and put it on another snare to find that the newer one needs to be tuned EVERY take, while the old one doesn't.
Maybe it's just simple variation in materials, but it seems that I've never had that problem before until this last year.
Post by pouletdegrains on Sept 12, 2018 11:06:40 GMT -6
This is my first post on the forum and to say the truth I feel a bit intimidated. So many great contributors here! I love this place as it offers 1) real discussions (and not lists of ego-centered contributions) and 2) an amazing knowledge base. Thank you everyone.
So, here is my humble opinion on this subject.
I have experimented a lot with drumheads to finally come back to my starting point: single-ply heads. I feel like tuning is the key, especially the resonant head which will give the note. Patience required though. To open the sound, I tune both heads evenly to help them resonate. To cut resonance, as Svart explained, I tune both heads unevenly, tightening the bottom head more than the top one.
I was disappointed recently by Remo heads, as its coating will wear faster than before. Ambassador coated sounds wonderful though. Aquarian heads are now my first choice, as the coating seems to last forever. It doesn't sound as musical as the Ambassadors (we are talking about very small differences), but in a studio environment it may be an advantage. I am interested by the mentioned Remo Ambassador vintage (thin double-ply) but I have not tried it yet.
I set up my Rogers 24" bass drum with a coated single-ply head with rings (Remo Powerstroke 3 or Aquarian Full Force 1) on the batter side, coated single-ply on the resonant head, no hole (it has to be miked specifically though). Amazing sound.
Drums produced in Asia are often made out of Asian maple, which is not as hard as American maple, and I always though it makes a difference. Some Asian-made Gretsch are using American maple, however, for some reasons (wood selection?), it doesn't sound as good as the US production. In my experience, bearing edges have more influence than anything (if the drums are properly tuned!), along with the essence. Rogers drums are my favorite, as it made out of super thin bearing edges (very limited contact of the skin on the wood) giving a great musical sound (to my ears). Gretsch drums are the other extreme, thick bearing edges especially on the early models, giving a very focused and tight sound. Great too.
Given the price of vintage drums in US, I don't think Taiwanese drums are of great value. In Europe (I'm in France), it is harder to find these drums but we have a great selection of birch-made drums (Premier, Hayman, Ajax,...) which still sells for little money. It has a great sound, more focused than maple, great for studio applications.
Post by jcoutu1 on Sept 12, 2018 11:51:38 GMT -6
Just came across this fantastic demo on youtube.
I think I'm going to opt for regular coated Ambassadors for the vintage Ludwig rack tom.
_______
For the DW kit, I think I'm going to go for coated emperors.
Here's a video of clear vs. coated that I found, and I think the guy broke into my studio and stole my kit. haha. Same color and everything.
Here's a good video of the coated G2 vs. coated Emperor.
I think the Emperor sounds a little more toneful and has a bit more attack. The G2 sounds rich and full, but I think it'll hide in the mix a bit.
Post by pouletdegrains on Sept 12, 2018 12:17:05 GMT -6
I forgot to mention I have experienced problems fitting Remo heads on my 70s Ludwig Vistalite, as it didn't seat properly on the shell. They have now a new serie, Classic Fit, designed for vintage drums.
Post by bigbone on Sept 12, 2018 12:43:41 GMT -6
I used REMO coated emperor with my DW kits for years and love it.
Another one that i use and love on my DW kits are REMO Vintage A
Post by svart on Sept 12, 2018 13:03:21 GMT -6
I just never got into coated heads on anything but snare. They always end up too dull in the mix.
Post by bigbone on Sept 12, 2018 13:27:11 GMT -6
To each his own, !!!!
Post by bigbone on Sept 12, 2018 13:33:44 GMT -6
Nice video about tuning
Post by bigbone on Sept 12, 2018 13:43:10 GMT -6
Not for everybody.but that's how i like my drums to sound.
Post by bigbone on Sept 12, 2018 13:44:07 GMT -6
Oupsss double post
Post by joseph on Sept 12, 2018 13:48:39 GMT -6
Albini's tip - I like to put a ring of keys in the hihat.
Tape sounds like shit. I also hate the sound of wimpy over-dampened drums in general, so cliched these days.
It's a pastiche because you listen to old recordings, every track has a distinctive drum sound, often with a lot of sustain.
I'm also not a fan of perfectly tuned and overly close miked drums, as I like happy accidents and particularly too much subkick messes with the groove of any moderate to fast tempo songs. I'd rather just record a different day if the drums are not really working for a given song.
But it's a taste thing. I kind of like the sound of drums after a drummer tunes them to his liking with some back and forth listening to speakers not headphones, and then really lays into them, so they are a little off. That way they don't call attention to themselves so much in the mix and sound a little loose.
Post by jampa on Sept 12, 2018 15:10:32 GMT -6
Just came across this fantastic demo on youtube. That guy also has a snare drum video, which I'll attach below Then if these videos are your sort of thing (they are for me), there are snare and bass drum head videos courtesy of this chap
Drum Chat
Sept 12, 2018 20:32:50 GMT -6
via mobile
Post by sean on Sept 12, 2018 20:32:50 GMT -6
In Europe (I'm in France), it is harder to find these drums but we have a great selection of birch-made drums (Premier, Hayman, Ajax,...) which still sells for little money. It has a great sound, more focused than maple, great for studio applications. Always jealous of all the Premier and Hayman drums I see for sale in Europe. I think Premier’s might be my favorite drums. I have a set of Elite’s from the 70’s that are super punchy, but they are black so I’m looking to sell them to fund restoring an older set I have I want to bring back from the dead and probably wrap in Aquamarine sparkle
Post by pouletdegrains on Sept 13, 2018 1:59:43 GMT -6
In Europe (I'm in France), it is harder to find these drums but we have a great selection of birch-made drums (Premier, Hayman, Ajax,...) which still sells for little money. It has a great sound, more focused than maple, great for studio applications. Always jealous of all the Premier and Hayman drums I see for sale in Europe. I think Premier’s might be my favorite drums. I have a set of Elite’s from the 70’s that are super punchy, but they are black so I’m looking to sell them to fund restoring an older set I have I want to bring back from the dead and probably wrap in Aquamarine sparkle Premier drums from the 60s are great sounding and have some beautiful finishes. They are getting more expensive here though, often advertised around 1000-1500 euros. However, bargains may be found on the Olympic line (300-400 euros for a set). Hayman Vibrasonic drums are my favorite, but it is rare and hard to find in great condition! European drummers are more passionate about American-made drums, which does not make sense given what the market has to offer!
Post by jcoutu1 on Sept 14, 2018 19:29:24 GMT -6
