Post by chessparov on Sept 6, 2018 16:00:32 GMT -6
Can either/both of these type tubes, replace a 12 AX7 tube? I'm not sure if either will fit my MXLV69. Thanks, Chris
Post by chessparov on Sept 6, 2018 23:09:39 GMT -6
Probably am going with a NOS GE Jan 5751... Chris
Post by svart on Sept 7, 2018 6:53:00 GMT -6
Can either/both of these type tubes, replace a 12 AX7 tube? I'm not sure if either will fit my MXLV69. Thanks, Chris The 5751 is a ruggedized version of the 12ax7 that comes in the V69. The 5654 is a 6V tube and won't work without some rewiring, but i doubt you'd notice anything terribly different with it. I'd suggest going to a 12AT7 or 6072 tube and see if you like it. It has less gain but will allow more headroom and some folks like the tone a bit better in tube mics. - Also a Chris
Post by chessparov on Sept 7, 2018 15:48:24 GMT -6
Cool-Thanks! Honestly, besides some research, there's another member on a different website (Paul G), who I also respect highly, and he used the 5751 in his Lauten LA-320 with excellent results.
I'll factor in, your comments too! Thanks again, Chris
