Post by raddistribution on Jun 22, 2018 1:25:18 GMT -6
Designed in conjunction with the expertise of mixer Chris Lord Alge, the CLA10 studio monitors are the faithful modern reproduction of the most iconic studio monitor of the last 30 years. Mix with the studio monitors that truly define "the sound of hits". Cabinet A tremendous amount of attention has been put into ensuring that performance matches that of the original speakers. CLA10 is made from MDF with a real wood veneer. We changed the rear terminal plate to use a better grade of connector. The crossover network uses the same value capacitors – just a better grade of material and rating. The inductors exactly match the original in dc resistance, winding dimensions and value. Drivers The AV10-MHF tweeter dome went through a difficult engineering process to get the exact phenolic resin doping to match the original performance curve. We do this in-house to ensure and exact match with every lot. The AV10-MLF woofer uses custom tooled mechanical parts that recreate the original. The AV10-MLF woofer cone is made to match the original. One of the original vendors is our supplier and we worked closely with them to get the same stiffness and weight. The main difference is we chose to go with a pressed cone as opposed to a lapped. This allows tighter control over stiffness and weight. All of our testing revealed no tonal difference or response between ours and the original. This has the added benefit of being the first time matched pairs are truly available. Specifications System Type:*Passive - full-range two-way stereo pair Frequency Response:*60Hz-20,000Hz (Accessible musical range) Power Capacity:*Program – 60W, Maximum – 120W Sensitivity:*90dB SPL (1W, 1m on axis) Components: Low Frequency: AV10-MLF 18cm cone High Frequency: AV10-MHF 3.5cm soft dome Cabinet:*10.4 liter sealed design, 18mm MDF with real wood veneer Cabinet Dimensions:*381.5mm x 215mm x197.5mm ( 15”x 8 ½”x 7- ¾ ” ) Cabinet Weight:*6.3kg / 13.9 Lbs (each) AVAILABLE: August PRICE: $699 per pair Attachments:
Post by mrholmes on Jun 22, 2018 1:41:56 GMT -6
There is in Europe someone doing ns 10 copies for 180 bucks a pair...699 lol....btw I still own a pair which I dont use anymore since I have monitors which translate the mix super well.
Post by M57 on Jun 22, 2018 4:51:11 GMT -6
I sold mine on Reverb a year or so ago ..for ~$600 I think. I can't tell you how relieved I was to get that monkey off my back. But apparently that's what they're worth if they're faithful reproductions.
Post by mrholmes on Jun 22, 2018 8:25:48 GMT -6
I am waiting to see the CLA grin in the PT or Logic Startup-Window.
Post by Johnkenn on Jun 22, 2018 9:02:05 GMT -6
I was shocked at how cheap these were. I guess my first thought wasn’t a negative one.
Post by nick8801 on Jun 22, 2018 9:17:21 GMT -6
Actually kind of interested in these. The price isnt too crazy considering how accurate to the original Avantone claims they are.....now let’s see if they come out with a Bryston copy to power them:)
Post by ericn on Jun 22, 2018 9:33:22 GMT -6
I was shocked at how cheap these were. I guess my first thought wasn’t a negative one. Well that was the thing about NS10’s they were CHEAP and built like crap speakers! Everybody had them because everybody had them and they were cheap. I’m glad for those who think they are the holy grail of monitors that they can get a new pair of speakers and parts, but I’ll never understand the attraction.
Post by jeremygillespie on Jun 22, 2018 9:54:29 GMT -6
I feel at home on my pair. I’ve got 3 sets of drivers and tweets stashed away back from when they were still reasonably priced. I’d be interested in trying out a set of the new woofers just to compare. It’s so easy for me to get correct balances on a set of 10’s for me. Sure I’ll switch to something else for tweaking eq’s and such, but I always double check on 10’s
Post by brenta on Jun 22, 2018 10:05:41 GMT -6
Cool. But if they sound about the same and cost about the same as the originals, i’m not sure why I would buy these instead of actual NS-10s.
Post by m03 on Jun 22, 2018 11:20:52 GMT -6
Cool. But if they sound about the same and cost about the same as the originals, i’m not sure why I would buy these instead of actual NS-10s. New with warranty/manufacturer support is a lot better than an unknown history involving potential items like questionable storage, wear and tear, prolonged exposure to UV light, smoke, etc.
Post by ericn on Jun 22, 2018 11:22:36 GMT -6
Cool. But if they sound about the same and cost about the same as the originals, i’m not sure why I would buy these instead of actual NS-10s. So many abused NS10’s I wouldn’t buy a used pair without hearing them. Probably the most abused speaker out there.
Post by drbill on Jun 22, 2018 12:57:56 GMT -6
Cool. But if they sound about the same and cost about the same as the originals, i’m not sure why I would buy these instead of actual NS-10s. So many abused NS10’s I wouldn’t buy a used pair without hearing them. Probably the most abused speaker out there. I wouldn't buy a pair if I DID hear them.....LOL Hope to never hear a pair again....
Post by jeromemason on Jun 22, 2018 13:04:28 GMT -6
My goodness I've seen it all now.
Post by adamjbrass on Jun 22, 2018 13:06:43 GMT -6
Hope to never hear a pair again.... Amen to that. NS-10's make my ears run and hide inside my skull.
Post by ericn on Jun 22, 2018 13:41:53 GMT -6
So many abused NS10’s I wouldn’t buy a used pair without hearing them. Probably the most abused speaker out there. I wouldn't buy a pair if I DID hear them.....LOL Hope to never hear a pair again.... Well Dah, but there are some people who love them, not that there any thing wrong with that😎
Post by jeromemason on Jun 22, 2018 14:08:46 GMT -6
There was a time for them. They were really helpful when cars had coaxial speakers that were tinny and low mid heavy.
Now most are 3 way and have DSP correction burned into everyone that rolls off the lot.
Post by ragan on Jun 22, 2018 15:01:38 GMT -6
I can’t wait for the CLA-branded mic stands, 500-series chassis’ and cable ties.
Post by drbill on Jun 22, 2018 17:00:41 GMT -6
I can’t wait for the CLA-branded mic stands, 500-series chassis’ and cable ties. Oooohhhhh, CLA Cable ties. That's actually something I might purchase!!
Post by explorer on Jun 22, 2018 17:20:40 GMT -6
The promo video is amazing.
Post by ragan on Jun 22, 2018 17:37:25 GMT -6
Wow. It's so...Trumpian.
Post by kcatthedog on Jun 22, 2018 18:03:19 GMT -6
Ahhhhhhhhggg!
Post by ericn on Jun 22, 2018 18:23:41 GMT -6
Post by ragan on Jun 22, 2018 18:29:54 GMT -6
heheh. Not what I meant. I was just referring to the verbal style. Just kinda tripping around the concepts, but doing so with total self assurance.
Post by m03 on Jun 22, 2018 18:48:53 GMT -6
The promo video is amazing. The oscillating lighting in the video is distracting/weird. Also, it could be worse...imagine if these were a Slate-endorsed product.
Post by Tbone81 on Jun 22, 2018 20:15:38 GMT -6
Dude, his name is on it! Totally getting a pair now, I was kinda on the fence, but there's few things I love more than pseudo celebrity endorsements. Also, I'm kind of a brand whore.
