Post by matt@IAA on Apr 24, 2018 9:07:05 GMT -6
How do you typically set up your cue?
If you track a band, do you have one mix or one per musician for "more me"?
What equipment have you found that makes this a breeze?
Post by svart on Apr 24, 2018 9:28:11 GMT -6
My setup is that I place sends on key tracks/groups and output stereo submixes of drums, bass, guitar, vocals/effects to ADAT outputs to ADA8000 converters. That way I get 4 stereo analog stems that go out to 8 channel behringer mixers I use as headphone pods. The musician gets to "mix" their own headphone cues to their liking.
This cuts out most of the "more me" discussion.
Post by adamjbrass on Apr 24, 2018 11:34:39 GMT -6
Right now, my room is small, (I only record small ensembles usually) so Artist Mix is usually the same Mix that I am hearing. I half-normal the Analog outs of my Symphony to an 8channel HP box in my live room. Then I use the two outs of my Dbox, which gets the Talkback. I need a better solution. I know a company planning to make a really rad HP distro box. Waiting on him.
Post by bram on Apr 24, 2018 11:41:52 GMT -6
I know a company planning to make a really rad HP distro box. Waiting on him. Any more info on this? I've been looking into the Hear back system in the meantime.
Post by notneeson on Apr 24, 2018 11:49:24 GMT -6
I know a company planning to make a really rad HP distro box. Waiting on him. Any more info on this? I've been looking into the Hear back system in the meantime. I find with the Hearback system, it’s easy for the client to make it sound bad if they just start twisting knobs. The headroom is sub optimal and the limiter sounds really bad. But, once you get them up and running it’s usually ok. For whatever reason, I don’t have this issue with the Furman system. In the small room I share closer to home, we just make do with my mix in the cans, although my band mate has offered his Furman. One nice trick in PT: get a good balance going and then use the copy to send function to get the same mix on a stereo send to the cue. Then you pick your more me channels based on need.
Post by bram on Apr 24, 2018 12:16:59 GMT -6
Good to know about the HearBack, sounds like the limiter should only be used to touch to the top for saving headphones.
Post by adamjbrass on Apr 24, 2018 12:53:52 GMT -6
I know a company planning to make a really rad HP distro box. Waiting on him. Any more info on this? I've been looking into the Hear back system in the meantime. Not sure if I can say anything about it yet But its super cool and you guys would love it. Sorry for the vagueness. I don't want to upset him.
Post by jeremygillespie on Apr 24, 2018 13:29:25 GMT -6
Post by swurveman on Apr 24, 2018 14:58:23 GMT -6
I use an old Rane 4 channel headphone amp-one stereo input with 4 headphone connections- and one of my Central Station's phone outputs if needed. If I had one thing to do over again with my soon-to-be-closing studio it would to (a) have 4 separate stereo headphone controllers and (b) use total isolation headphones for anybody close to the drummer . I have 2- 16 channel RME interfaces and 32 channels of conversion. So, I could control as many "more me" cue mixes as I want via the Totalmix mixer.
The other thing I'd do is have hard wired extension cords for the headphones. Those male/female extension cords are always finicky.
I think that good cue mixes are vital for a good performances and it's something I regret not making one of my first priorities.
Post by woofhead on Apr 24, 2018 16:39:42 GMT -6
In my setup each musician is sent their own separate aux mix they can control . I use a motu 16a which can be controlled over wifi so each musicians setup consists of an inexpensive android tablet in fullscreen mode . Theres a specific touchscreen page for this that works well and you can setup whats visible for each aux. I group the drum mics to one fader except the drummer who gets control of kick snare etc whatever they need. For the audio, each stereo aux out of the 16a is sent to a multi channel ross audio installation amp to boost the signal and then sent to furman hr2 headphone taps which take xlr in that clamp to a mic stand. The nice thing about the headphone tap is no power so easy to move around quickly. I use a different colour for the xlr lines to the taps and run them in parallel with the xlr mic cable so makes for an uncluttered setup. I plan to make nice little wood boxes that integrate the tap and the tablets but havent gotten around to it yet.The ross audio amp sounds really clean and I got if for 20 bucks on ebay.I had a setup a few years ago with behringer analog mixers and that worked but was noisy and bulky plus all the snakes and half of them burnt out.Heard good things about that newer behr digital hp system as well though.
Post by spindrift on Apr 24, 2018 19:22:14 GMT -6
Old Furman HDS-6 headphone amp system with 7 headphone units has been working great for me.
Post by bluegrassdan on Apr 24, 2018 20:17:34 GMT -6
Aviom. Best investment a studio can do.
Post by Martin John Butler on Apr 24, 2018 21:00:36 GMT -6
This is interesting. Let us know how it works and sounds Jeremy.
Post by allbuttonmode on Apr 25, 2018 3:05:15 GMT -6
I have the Behringer solution. Works and sounds great.
What's not so great, is giving the artist control over her/his own mix. In my experience, it(the mix) ends up being so skewed, their performance suffers. This is especially true when it comes to vocal sessions.
Post by EmRR on Apr 25, 2018 7:17:09 GMT -6
I thought the Behringer worked OK the time I used it, my beef is that each station only has one HP output. They should each have multiples, for the times people can share the same alt mix.
I built a multi-mix in the DP AVB mixer, and the fatal flaw there is complete lack of talkback function with proper speaker dimming.
Post by allbuttonmode on Apr 25, 2018 8:22:11 GMT -6
I thought the Behringer worked OK the time I used it, my beef is that each station only has one HP output. They should each have multiples, for the times people can share the same alt mix. Seeing it has line outs, and these are pretty cheap, I don't see the benefit. It'd make the unit even more costly.
Post by subspace on Apr 25, 2018 8:38:05 GMT -6
I use the MOTU 16A DSP mixer with a Presonus HP60 headphone amplifier. The MOTU is normalled with outputs 1-2 feeding the DAW mix return on the desk, then the desk's stereo cue out feeds the main LR input on the Presonus. That control room mix is available to all six headphone outputs with talkback. MOTU outputs 3-8 are normalled to a patchbay above the Presonus so they either feed additional mono mixes to each of the six channels or 3 stereo mixes to pairs of channels. I run the control room mix and the 3-6 additional mixes are handled via iPad over wifi. Honestly, that's more so I can sit next to the drummer and get a good mix rather than guess-ti-mixing from the other side of the glass. Running at 88.2k, the MOTU has 32 channels, 3 stereo subgroups and 6 auxes. The first 16 channels are the analog inputs, the next 8 are ADAT in and the last 8 are returns from the DAW. Those 24 live inputs feed one stereo subgroup and 8 DAW returns feed another. This makes it easier to mute all the live inputs for playback or get a good balance between input and playback during overdubs. The last 8 outputs on the MOTU are direct outs from those 8 DAW returns which return to the console so I can solo instrument groups without affecting the cue mix.
Post by EmRR on Apr 25, 2018 8:38:09 GMT -6
I thought the Behringer worked OK the time I used it, my beef is that each station only has one HP output. They should each have multiples, for the times people can share the same alt mix. Seeing it has line outs, and these are pretty cheap, I don't see the benefit. It'd make the unit even more costly. Yeah, I had a maxed single system with 6 stations, but a dozen musicians, so each station was feeding additional 4 channel HP amps I brought in. It might make it $5 more costly to add at least one additional HP out. Then one can break! Like they do! And one will still work!
Post by jeremygillespie on Apr 25, 2018 20:36:20 GMT -6
We’ve got the Mytek PrivateCue system. 3 headphone outs per box, LOTS of power to drive the phones, 12 channels, sounds fantastic.
We have the early version that used DL connectors, which are good for about 3 years, and then get noisy from all the use which is a giant pain in the ass as it requires a re-pin (who has time for that crap?)
I believe they updated the newer version to use a different connector that fixes this problem.
And yeah, some artists need some help with their headphone mix, but many don’t. If a performance is oddly awful, it’s easy enough to go out and help them tweak things a bit. It’s usually just inexperience and most folks are so happy to have you show them, I don’t find it to be much of a big deal. MUCH better than making 6 mixes for people and having them constantly ask for changes. That is something I don’t miss at all.
Post by christopher on Apr 25, 2018 21:05:10 GMT -6
For live I usually only put the scratch vocals in the cans. That way if they know the song they don't have to wear headphones and can hopefully focus on their instrument. Sometimes drummers esp play with more emphasis if they have vocals. This method is strictly about saving time/money for the artist,
Post by ericn on Apr 27, 2018 6:49:08 GMT -6
After mixing wedges and years of these individual cue systems both live and in the studio, unless you have a group of musicians who know how to gain stage or are experienced with the cue system they for the most part waste time and become a distraction! It’s just to easy to try to get that perfect headphone mix and constantly twist the knobs, rather than work on the performance! A couple of aux sends are just easier! The best implementation of a individual cue system both in the studio and live was the Genesis method, live human who mixes stems on a big old monitor console feeding the cue system, and yes my former employer developed one of the earliest and I HATE HATE HATED it! Nobody ever turned stuff down , it was always up up up till it was a distorted mess and the AE had to go back and rebuild the individual cue mixes! Sometimes options are not the best option!
Post by jeremygillespie on Apr 27, 2018 7:06:05 GMT -6
After mixing wedges and years of these individual cue systems both live and in the studio, unless you have a group of musicians who know how to gain stage or are experienced with the cue system they for the most part waste time and become a distraction! It’s just to easy to try to get that perfect headphone mix and constantly twist the knobs, rather than work on the performance! A couple of aux sends are just easier! The best implementation of a individual cue system both in the studio and live was the Genesis method, live human who mixes stems on a big old monitor console feeding the cue system, and yes my former employer developed one of the earliest and I HATE HATE HATED it! Nobody ever turned stuff down , it was always up up up till it was a distorted mess and the AE had to go back and rebuild the individual cue mixes! Sometimes options are not the best option! I totally get that, but sometimes it feels like seperate control is expected, even from inexperienced musicians. I’ve had a few sessions where I was either mixing seperate mixes in the box or doing it on the console and after every take I was getting jammed up for 15 mins at a time changing mixes for everybody. Maybe it’s because I never HAD to do it that it seemed like a burden and PITA. On the other hand, I’m sure I would have spent a lot less time as an intern replacing drivers on those awful Sony headphones if musicians didn’t have the amount of power our system has hahah
Post by javamad on Apr 28, 2018 17:27:24 GMT -6
I just got the Behringer ones too. So far I have just tested it on myself and I am loving it. I re-did my templates to feed 16 channels out of my 2 Apollos using the optical outputs so its a very complete set. I have 8 for the playback and click and 8 for the live. All in all pretty good. I got a hub and 3 mixers, will add another 2-3 if it works out well. It's the only Behringer kit in my studio and I console myself knowing no signal through that is ever going to tape :-)
