Post by Blackdawg on Mar 29, 2018 20:09:03 GMT -6
So jealous!
And I wanna build that myself. So much soldering therapy..
Post by Johnkenn on Mar 29, 2018 20:11:49 GMT -6
I - in no way shape or form - want to build one lol.
Post by Blackdawg on Mar 29, 2018 20:24:04 GMT -6
I - in no way shape or form - want to build one lol. aw why not? I mean..i know its a lot, ive seen the photos of the cards..but can't be too bad!
Post by gabygab2 on Mar 29, 2018 20:36:20 GMT -6
The ADA8200 seems great, the only thing I don't like about it is running the line ins from the front. It's not pretty looking.
Post by gouge on Mar 29, 2018 21:19:58 GMT -6
Id be interested in an 8200 group buy if it has universal power and does 96k but id need to check local prices too.
Post by BenjaminAshlin on Mar 29, 2018 23:25:27 GMT -6
What price would the 8200 be with a GB?
Post by kilroyrock on Mar 30, 2018 6:57:24 GMT -6
the focusrite 8 channal ad/da's are worth the bang for buck. 300 for a used one with compressor for each channel, or you can get your clarrett converter version (i know you like those) for 4-500. reverb.com/item/11096080-focusrite-octopre-mkii
Post by hasbeen on Mar 30, 2018 13:25:58 GMT -6
Btw - if anyone wants to do a group buy on these things, I could give some damn good deals. I am interested, let me know how many respond. Best current online price is $155 from dealers selling returns. Thanks
Post by kilroyrock on Mar 30, 2018 21:06:00 GMT -6
It has to be better than my tango 24 that I use for strip #3, right? I'm in if it gets lower than 150, why not
Post by peterhess on Apr 4, 2018 15:14:26 GMT -6
A quick question on this topic: I go Silver Apollo 8 out plus stereo spdif to my Heritage MCM 8, and since I have a small room and low track counts this works just fine: however I am left with no I/O for hardware inserts: ie overheads->hardware comp->back in-> bussed to drums out. Would chaining the Focusrite or something like it to set up just for inserts be a fool’s errand riddled with delay comp errors, or do you think I could make it work? Obviously clocked to the Apollo. Thanks in advance! P
Edit: always 44.1 or 48
Post by Johnkenn on Apr 4, 2018 19:32:43 GMT -6
A quick question on this topic: I go Silver Apollo 8 out plus stereo spdif to my Heritage MCM 8, and since I have a small room and low track counts this works just fine: however I am left with no I/O for hardware inserts: ie overheads->hardware comp->back in-> bussed to drums out. Would chaining the Focusrite or something like it to set up just for inserts be a fool’s errand riddled with delay comp errors, or do you think I could make it work? Obviously clocked to the Apollo. Thanks in advance! P Edit: always 44.1 or 48 I’m not sure why there would be any errors as long as you go adat to the focusrite.
Post by Blackdawg on Apr 4, 2018 21:46:41 GMT -6
A quick question on this topic: I go Silver Apollo 8 out plus stereo spdif to my Heritage MCM 8, and since I have a small room and low track counts this works just fine: however I am left with no I/O for hardware inserts: ie overheads->hardware comp->back in-> bussed to drums out. Would chaining the Focusrite or something like it to set up just for inserts be a fool’s errand riddled with delay comp errors, or do you think I could make it work? Obviously clocked to the Apollo. Thanks in advance! P Edit: always 44.1 or 48 Should work fine although I am not sure if you computer could handle the delay compensation for all the hardware inserts..
Post by peterhess on Apr 5, 2018 10:08:49 GMT -6
Opinions on the Focusrite 40 vs the Scarlett 18i20 for this application? Thanks for the help guys!
Post by gouge on Apr 6, 2018 21:41:03 GMT -6
Opinions on the Focusrite 40 vs the Scarlett 18i20 for this application? Thanks for the help guys! hi peter, I've not used the 40 but have used the 18i8 gen 2 for a year now so feel I know it quite well. here is my take on it. the adc is more than good enough for pro use. sure there is better out there but it costs a lot more. the dac is also more than good enough for pro use. stuff I loop out and back sounds fine. again granted there is better out there. the drivers are ok. focusrite has good latency for usb connection. it bugs me a little that occasionally i have to reboot during a session but that has not happened while actually recording. I'm comparing to the lynx converters I use which have better latency and better sound quality and have never had a driver issue ever in 7 years of use. the focusrite mixer is pretty good. not completely intuitive but it only took me 2-3 sessions to start to use it to it's full potential so no complaints there. as far as a device to connect other devices to a computer it's fine. whilst usb is generally never as reliable as pci it's generally more reliable than firewire. the bad.... the headphone amp is not to a pro level. to be honest it's a bit of a surprise its not better considering the conversion is pretty good. I don't think you can do reliable mixes with it. I've done a/b's with my RMA bare beast and it wipes the floor with the focusrite for monitoring. the focusrite is muddy in comparison. at some point when I get a Microsoft surface with usb3/thunderbolt i'll upgrade to the clarett range.
Post by gouge on Apr 6, 2018 23:45:51 GMT -6
I neglected to mention preamps. They do the job well enough. The di I think sounds pretty good on bass.
Post by jazznoise on Apr 9, 2018 2:36:33 GMT -6
you need a super computer that will launch rockets, otherwise, its an Aggravation Device.
Post by adamjbrass on Apr 11, 2018 12:24:03 GMT -6
Whats the deal with level control on the Sumbus? Are you just meant to push DAW faders around with this box?
Post by peterhess on Jun 18, 2018 15:20:40 GMT -6
Anyone here used an Apogee Rosetta for additional I/O with an Apollo? Thanks!
