Post by gouge on Mar 25, 2018 16:16:17 GMT -6
Wondering if anyone has experience with these mics on grand piano.
Indie folk singer songwriter.
Or
Would you record grand piano with dynamic mics. Granted, very good sounding dynamic mics.
Post by reddirt on Mar 25, 2018 20:03:38 GMT -6
202s are dynamic if I remember right; great mic with a double capsule set up which can die over time Were used a lot in BBC/ ABC / NZBC
Cheers, Ross
Post by gouge on Mar 26, 2018 4:25:40 GMT -6
yeah that's the ones. dynamic with double capsules. I use mine on kick and electric guitar. tried them as room mics recently but needed more gain so switched to condensers.
they are fairly flat and have excellent off axis response which is why I thought maybe piano could be ok with them.
Post by ericn on Mar 26, 2018 10:01:44 GMT -6
These are a Dynamic that can work on piano BUT it is a slightly different sound, they compress a bit and don’t seam as fast!
Post by gouge on Mar 26, 2018 15:30:07 GMT -6
These are a Dynamic that can work on piano BUT it is a slightly different sound, they compress a bit and don’t seam as fast! Yeah. I'm a lttle concerned about the top end. Will probably use a pair of ksm137 in xy then ease myself into into the akg on piano by setting them up out from the sound board.
Post by Bob Olhsson on Apr 4, 2018 15:21:49 GMT -6
The main thing about 202s and 224s (I've owned both) is that you need to always be back far enough that one diaphragm isn't favored. That means two or three feet.
