Post by Quint on Mar 17, 2018 17:54:27 GMT -6
I'm trying to find a quality adjustable boom arm that can be mounted to the wall for use when recording vocals in the vocal booth. I'm imagining something that would mount to the wall above the window looking out into the live room at around six feet high or so and that would be adjustable so that the vocal mic can be adjusted to whatever position is needed.
Ideally it would be similar to the segmented "spring loaded" booms like you see radio broadcasters use. The thing is, all of those models seem to all have some sort of table mounted clamp type connection. I need something that has some sort of base plate that can be screwed into a hard surface, the wall in my particular case. Thus far, I've not been able to find anything like that.
Does anybody know of something like this?
Post by ericn on Mar 17, 2018 18:03:25 GMT -6
I'm trying to find a quality adjustable boom arm that can be mounted to the wall for use when recording vocals in the vocal booth. I'm imagining something that would mount to the wall above the window looking out into the live room at around six feet high or so and that would be adjustable so that the vocal mic can be adjusted to whatever position is needed. Ideally it would be similar to the segmented "spring loaded" booms like you see radio broadcasters use. The thing is, all of those models seem to all have some sort of table mounted clamp type connection. I need something that has some sort of base plate that can be screwed into a hard surface, the wall in my particular case. Thus far, I've not been able to find anything like that. Does anybody know of something like this? Those broadcast booms have desk mounts that can be used for wall mount as well!
Post by Quint on Mar 17, 2018 18:06:10 GMT -6
I'm trying to find a quality adjustable boom arm that can be mounted to the wall for use when recording vocals in the vocal booth. I'm imagining something that would mount to the wall above the window looking out into the live room at around six feet high or so and that would be adjustable so that the vocal mic can be adjusted to whatever position is needed. Ideally it would be similar to the segmented "spring loaded" booms like you see radio broadcasters use. The thing is, all of those models seem to all have some sort of table mounted clamp type connection. I need something that has some sort of base plate that can be screwed into a hard surface, the wall in my particular case. Thus far, I've not been able to find anything like that. Does anybody know of something like this? Those broadcast booms have desk mounts that can be used for wall mount as well! I must not be looking at the right ones then. Any model that you've seen in particular?
Post by ericn on Mar 17, 2018 18:22:20 GMT -6
Those broadcast booms have desk mounts that can be used for wall mount as well! I must not be looking at the right ones then. Any model that you've seen in particular? Take a look at the RODE PSA1 and the included desk insert that and clamp mount.
Post by Quint on Mar 17, 2018 18:49:12 GMT -6
I must not be looking at the right ones then. Any model that you've seen in particular? Take a look at the RODE PSA1 and the included desk insert that and clamp mount. I've seen that one. But, if I understand correctly, the desk insert doesn't do me any good either. I believe the desk insert is one of those deals where it mounts in your typical desk "hole". If so, that's not a screw mounted type of deal but, rather, something that just slips into a two inch diameter hole cut into the desk top.
Post by ericn on Mar 17, 2018 19:48:24 GMT -6
Take a look at the RODE PSA1 and the included desk insert that and clamp mount. I've seen that one. But, if I understand correctly, the desk insert doesn't do me any good either. I believe the desk insert is one of those deals where it mounts in your typical desk "hole". If so, that's not a screw mounted type of deal but, rather, something that just slips into a two inch diameter hole cut into the desk top. Yeah that isn’t clear but if you mount say a small block you could use the clamp!
Post by mulmany on Mar 17, 2018 19:52:52 GMT -6
Drill a hole through the base and stem and insert a pin to keep them together.
Post by johneppstein on Mar 17, 2018 21:01:45 GMT -6
You might see if Markertek has anything. I believe they cater to that market.
Post by ericn on Mar 17, 2018 21:09:44 GMT -6
You might see if Markertek has anything. I believe they cater to that market. My first thought was BSWusa! Where the Rode came up! There was this company that along with ATLAS specialized in these but I think the Chinese knock offs but them Knocked them out !
Post by keymod on Mar 19, 2018 3:16:51 GMT -6
Post by m03 on Mar 19, 2018 9:39:59 GMT -6
Post by matt on Mar 19, 2018 9:49:33 GMT -6
How high is your ceiling? Hang the thing vertically?
Post by Quint on Mar 19, 2018 16:56:39 GMT -6
How high is your ceiling? Hang the thing vertically? I've considered that. Though with acoustic treatment and everything else, the ceiling is probably too low to make that work.
Post by Quint on Mar 19, 2018 16:57:55 GMT -6
I like the idea of that quick coupler.
Post by Ward on Mar 20, 2018 12:13:44 GMT -6
I like the idea of that quick coupler. As do I!! I'm thinking that 2 of these would work really well in my double-sized vocal booth also!
