Post by gouge on Mar 15, 2018 20:30:50 GMT -6
Title says it all. I've got 10 i/o with ross martins spdif thru focusrite 18i8.
At 96 k I can add 4 more input only via adat according to manual.
Any suggestions. As well as a dedicated converter was also thinking aphex or Yamaha etc. Could look at preamps with adat.
Keen to hear ideas
Post by wiz on Mar 15, 2018 21:29:14 GMT -6
was just thinking the same thing... I want something that has adat out/in and can do smux
Post by ericn on Mar 15, 2018 21:32:30 GMT -6
There are a lot of older 8ch ad’s that will do 4 ch in sumx The Panasonic WzAD96 is one .
Post by wiz on Mar 15, 2018 21:39:57 GMT -6
There are a lot of older 8ch ad’s that will do 4 ch in sumx The Panasonic WzAD96 is one . can't speak for gouge but I want AD and DA cheers Wiz
Post by ericn on Mar 16, 2018 3:13:16 GMT -6
There are a lot of older 8ch ad’s that will do 4 ch in sumx The Panasonic WzAD96 is one . can't speak for gouge but I want AD and DA cheers Wiz In that case grab a WZDA96 as well!
Post by kcatthedog on Mar 16, 2018 5:27:57 GMT -6
Seems apollo does it ( actually 8 channels ? ): help.uaudio.com/hc/en-us/articles/209496906-Using-External-Digital-Gear-With-Your-Apollo-Digital-Clocking-Primer-ADAT & S/MUX A single ADAT cable (TOSLINK) in each direction is all that is required to pass 8 channels of digital audio at sample rates of 44.1 or 48 kHz. However, 2 cables are required in each direction to achieve 8 channels at 88.2 or 96 kHz, or 4 channels at 176.4 or 192 kHz. You can just use 1 cable each way if 4 channels is enough at 88.2 or 96 kHz or 2 channels is enough at 176.4 or 192 kHz. Please note that the secondary device will also need to support the S/MUX protocol in order to function as expected at higher sample rates.
Post by dror520 on Mar 16, 2018 6:23:49 GMT -6
I'm using the M-Audio Profire 2626 for 4 channels of ADAT at 96k
Post by svart on Mar 16, 2018 7:25:15 GMT -6
Behringer AD8000?
I use two of them from the ADAT outputs on my SSL alphalink as the D/A for my headphone system and the A/D for talkback mics and drum trigger inputs.
But be aware that using 88/96 drops the 8 channels down to 4 channels so you'd need two of these boxes in parallel with two sets of adat optical cables in parallel to get 8 channels.
Post by subspace on Mar 16, 2018 8:09:10 GMT -6
ADA8000 is 48k limited. MOTU 8A will work as a stand-alone converter for 8 i/o up to 48k and 4 i/o up to 96k over adat. motu.com/products/avb/8a
Post by aremos on Mar 16, 2018 8:45:36 GMT -6
Sort of stated on another thread, I have a BRC, 3 ADAT's, TosLink & other type cables (audio +4 snakes), AMPEX tapes (in unopened & wrapped boxes) all in mint condition (barely used). Never have had any of it for sale. If anyone's interested, PM me.
Post by svart on Mar 16, 2018 9:09:30 GMT -6
ADA8000 is 48k limited. MOTU 8A will work as a stand-alone converter for 8 i/o up to 48k and 4 i/o up to 96k over adat. motu.com/products/avb/8awell, since I'm running mine at 88.2k... it just mirrors the channels, like channel 1 and 2 are the same, 3 and 4 are the same, etc.
Post by mulmany on Mar 16, 2018 9:39:44 GMT -6
ADA8000 is 48k limited. MOTU 8A will work as a stand-alone converter for 8 i/o up to 48k and 4 i/o up to 96k over adat. motu.com/products/avb/8aIt's a spec they never published as far as I know. I think people found out about it by mistake.
Post by veggieryan on Mar 16, 2018 10:57:52 GMT -6
Lucid 88192 is the best of the lower price range. Apogee Symphony mk1 8x8 can be had very cheap if you look around as well.
Post by kilroyrock on Mar 16, 2018 11:14:55 GMT -6
you're using a focusrite 18i8 - you can buy a focusrite octopre pretty cheap. i have an octopre dynamic - does smux 8 44.1,8 48, 4 96k, 2 192k. the one i have is like 300 bucks now, cheaper without the compressors (but why?) Or you can get the new one which has the newer converters in the clarrett range that also sound great, around 500.
definitely an upgrade for your 18i8!
Post by johneppstein on Mar 16, 2018 11:28:50 GMT -6
Seems apollo does it ( actually 8 channels ? ): help.uaudio.com/hc/en-us/articles/209496906-Using-External-Digital-Gear-With-Your-Apollo-Digital-Clocking-Primer-ADAT & S/MUX A single ADAT cable (TOSLINK) in each direction is all that is required to pass 8 channels of digital audio at sample rates of 44.1 or 48 kHz. However, 2 cables are required in each direction to achieve 8 channels at 88.2 or 96 kHz, or 4 channels at 176.4 or 192 kHz. You can just use 1 cable each way if 4 channels is enough at 88.2 or 96 kHz or 2 channels is enough at 176.4 or 192 kHz. Please note that the secondary device will also need to support the S/MUX protocol in order to function as expected at higher sample rates. He said 96.
Post by johneppstein on Mar 16, 2018 11:31:26 GMT -6
Sort of stated on another thread, I have a BRC, 3 ADAT's, TosLink & other type cables (audio +4 snakes), AMPEX tapes (in unopened & wrapped boxes) all in mint condition (barely used). Never have had any of it for sale. If anyone's interested, PM me. What size and formulation Ampex?
Post by ericn on Mar 16, 2018 12:08:15 GMT -6
Sort of stated on another thread, I have a BRC, 3 ADAT's, TosLink & other type cables (audio +4 snakes), AMPEX tapes (in unopened & wrapped boxes) all in mint condition (barely used). Never have had any of it for sale. If anyone's interested, PM me. What size and formulation Ampex? Those would probably be the “special” Ampex SVHS for the ADAT, you know 30 year old SVHS oh the fun.
Post by kcatthedog on Mar 16, 2018 12:36:25 GMT -6
Seems apollo does it ( actually 8 channels ? ): help.uaudio.com/hc/en-us/articles/209496906-Using-External-Digital-Gear-With-Your-Apollo-Digital-Clocking-Primer-ADAT & S/MUX A single ADAT cable (TOSLINK) in each direction is all that is required to pass 8 channels of digital audio at sample rates of 44.1 or 48 kHz. However, 2 cables are required in each direction to achieve 8 channels at 88.2 or 96 kHz, or 4 channels at 176.4 or 192 kHz. You can just use 1 cable each way if 4 channels is enough at 88.2 or 96 kHz or 2 channels is enough at 176.4 or 192 kHz. Please note that the secondary device will also need to support the S/MUX protocol in order to function as expected at higher sample rates. He said 96. I know it does 88.2 or 96 at 8 channels, Or use 1 cable for 4 channels at 96 ?
Post by wiz on Mar 16, 2018 15:18:19 GMT -6
The ADA8000 doesn’t help as its dropping samples effectively..it’s not multiplexing the signal.
The MOTU 8A is probably the way to go for me
Cheers
Post by BenjaminAshlin on Mar 17, 2018 3:52:42 GMT -6
ADA8000 is 48k limited. MOTU 8A will work as a stand-alone converter for 8 i/o up to 48k and 4 i/o up to 96k over adat. motu.com/products/avb/8awell, since I'm running mine at 88.2k... it just mirrors the channels, like channel 1 and 2 are the same, 3 and 4 are the same, etc. Never knew this about the ADA8000. I would have brought one to modify years ago if I knew.
Post by gouge on Mar 18, 2018 2:27:14 GMT -6
i'll keep an eye out for the units mentioned thanx to all.
in the mean time the rma pcm4222 adc has hiss at 96khz and changing filter settings doesn't get rid of it. i might start another thread bout that.
Post by Guitar on Mar 19, 2018 10:00:11 GMT -6
I'm using a Presonus DP88 for 4 channels at 96K right now into my Apollo Twin.
Sounds as good or better than anything I have ever used.
It's a shame 4 channels are not being used, but, what are you gonna do...
Post by javamad on Mar 19, 2018 12:08:36 GMT -6
Audient ASP880 or ASP800 do smux.
I have the 880 hanging off my apollo optical in and they are great. I clock the Audient off the Apollo. Im using 8 channels at 48k but manual says they do 4 channels at 96 with 2 x optical cables.
Great pres for the money.
EDIT: Correction, it was not clear from the simple Audient manual but the Sound on Sound manual explains that you get 8 channels at high rates: “The upper lightpipe port provides eight channels at base sample rates, and channels 1‑4 at double sample rates. The lower port comes into play for double sample rates, when it carries channels 5‑8.”
Post by ericn on Mar 21, 2018 16:47:01 GMT -6
i'll keep an eye out for the units mentioned thanx to all. in the mean time the rma pcm4222 adc has hiss at 96khz and changing filter settings doesn't get rid of it. i might start another thread bout that. With RME cards playing with different card slots can in some instances can remove noise yrmv.
