Post by mrholmes on Feb 24, 2018 12:50:14 GMT -6
Stupid me.
I am playing a song which has a wide dynamic range and there is that Eb -7b5 chord that makes a dynamic jump from - 24 dbfs peak to - 9 dbfs. I backed off at the verb input with a trimmer -8 dbfs.
Some reverb plug ins still distort like hell special Slates VMR.
I was checking everything untill the verb came to my mind.
How is it possible that the reverb distrots even if it should not?
Cheers and thanks in advance to all.
Holmes.
Post by Deleted on Feb 24, 2018 15:01:49 GMT -6
I don't know this particular reverb, but it wouldn't surprise me if the reverb output is boosted a little. It's not that rare. Sometimes users may complain that a 'verb doesn't have enough output, so the makers may boost the signal in response. The issue with a reverb (at least those I know) is that the output is highly-dependent on the content of the input as well as the parameter settings. Sometimes the right combination may cause a surprising jump in level.
I do the best I can to calibrate my presets to unity gain using pink noise as a source. Even so, you're simply not going to get unity gain if--for example--you've got an input that's mainly high-frequency and a 'verb with a big rolloff. Pretty much the nature of the beast.
Post by mrholmes on Feb 26, 2018 18:19:47 GMT -6
Crazy problem is absent today....maybe the problem was internal in Logic....
