Post by wiz on Jan 7, 2018 0:01:29 GMT -6
Anyone compared OP275 and OPA2134 Op Amps in a modified LA4? I currently have OP275 in mine jimwilliams Wardcheers Wiz
Post by hadaja on Jan 7, 2018 6:32:38 GMT -6
Rob Squire just did my la4 last month. I will check to see what he used in mine
Post by hadaja on Jan 7, 2018 6:35:35 GMT -6
Yep Rob used opa2134 according to invoice. I am yet to use it as the VU bezel mounting broke in freight so waiting for replacement part to arrive. Probably a good question to shoot to Rob why he chooses that one over the other one.
Post by svart on Jan 7, 2018 8:17:17 GMT -6
There's only a couple opamps in the LA4A, so upgrading won't be as much of a difference as it would be if it were a mixer channel with a dozen of them.
Even the ne553x series sound pretty good in la4a once the decoupling is robust.
Post by c0rtland on Jan 7, 2018 8:19:56 GMT -6
I put Fairchild 4136CP in mine if I recall correctly. They are fine. Don't get too dark.
Post by Quint on Jan 7, 2018 9:03:48 GMT -6
So does the opamp change make them more useful or something? I've never used one but I am a huge fan of La3as and I've always wondered what the difference between the two are. Pairs of them seem to come up on eBay from time to time for fairly cheap.
Post by jimwilliams on Jan 7, 2018 14:34:49 GMT -6
I use ADA 4898-2 for the expensive seats and OPA1602's for the cheaper seats. Many other things are also done like the power supply, loop gain staging, power transistors, passive resistors, feedback bandwidth, etc. I use one high quality film cap, the rest is direct coupled.
The OPA's are essentially LME49720's with the BurrBrown rail to rail output section. Those will lower the self noise and add extra headroom on top for an increased dynamic range.
Post by gouge on Jan 7, 2018 15:24:01 GMT -6
not sure if you are aware wiz but joe malone sells adapters for the la4a opamps so they can be upgraded.
Post by wiz on Jan 7, 2018 15:52:15 GMT -6
not sure if you are aware wiz but joe malone sells adapters for the la4a opamps so they can be upgraded. thanks, mine already has those in it... cheers Wiz
Post by wiz on Jan 7, 2018 15:53:00 GMT -6
Yep Rob used opa2134 according to invoice. I am yet to use it as the VU bezel mounting broke in freight so waiting for replacement part to arrive. Probably a good question to shoot to Rob why he chooses that one over the other one. Thanks for that, I might try those Cheers Wiz
Post by wiz on Jan 7, 2018 15:53:21 GMT -6
I put Fairchild 4136CP in mine if I recall correctly. They are fine. Don't get too dark. thanks I will look into those Cheers Wiz
Post by wiz on Jan 7, 2018 15:54:04 GMT -6
I use ADA 4898-2 for the expensive seats and OPA1602's for the cheaper seats. Many other things are also done like the power supply, loop gain staging, power transistors, passive resistors, feedback bandwidth, etc. I use one high quality film cap, the rest is direct coupled. The OPA's are essentially LME49720's with the BurrBrown rail to rail output section. Those will lower the self noise and add extra headroom on top for an increased dynamic range. Hey jimwilliamsthanks for the reply. cheers Wiz
Post by kcatthedog on Jan 7, 2018 19:52:20 GMT -6
So much knowledge in our community: impressive !!
Post by Ward on Jan 8, 2018 4:03:23 GMT -6
Anyone compared OP275 and OPA2134 Op Amps in a modified LA4? I currently have OP275 in mine jimwilliams Wardcheers Wiz Haven't gone down this rabbit hole yet, but I am intrigued and thanks everyone for the fantastic info!
Post by ericn on Jan 8, 2018 8:31:42 GMT -6
Anyone compared OP275 and OPA2134 Op Amps in a modified LA4? I currently have OP275 in mine jimwilliams Wardcheers Wiz Haven't gone down this rabbit hole yet, but I am intrigued and thanks everyone for the fantastic info! Once you wet your toes you will jump in with both feet and enjoy the ride. The LA4 taught a lot of people some very important cruel lessons & Mods by Eddie, Jim and others taught some important wonderful lessons. The original LA 4 was a shock and dissipointment to many after the linage of 176, 1176, LA2 &3, I mean what real studio didn't have 2 of those who would book a room without them? It was also the box that many of told me started the "all Chips are bad " fad, some had a hard time adjusting to the LA3 but the stock LA4 took the reputation of Urei down ! The First time I played with one of Eddies modded LA4's my jaw dropped! I had learned the lesson years earlier that a stock LA4 was just another blah comp, so it took some convincing but this thing while not a LA2 or 3 had some personality of its own and because the Opto was a Faster Anthony Demaria did its own very useful thing that worked on some voices like nothing else! Over the years I have heard many of Eddies, JW's and others mods of these and all brought something a little different to the table all very useful. LA4's are not the bargain they were 15-20 years back but still can be had and modded without breaking the bank and less than its more famous brethren, so go have some fun! Side not always wondered what a CAPI take on SS Opto would sound like with that old API flavor Iron and gain could be a ton of fun with the right Opto!
Post by notneeson on Jan 8, 2018 12:08:01 GMT -6
Anyone compared OP275 and OPA2134 Op Amps in a modified LA4? I currently have OP275 in mine jimwilliams Ward cheers Wiz I have my buddy's Alactronics modded LA4A here. Not sure what's in it, but it sounds great. Maybe I'll pop the top and see next time I'm futzing around at the studio.
Post by svart on Jan 8, 2018 12:40:35 GMT -6
Or alternately, you could just rock the LA4A as it is, because the sound of the LA4A is a sum of the parts.. Change a part and you no longer have an LA4A.. A lot of these older designs owe a lot of their distinctiveness to their design (read: flaws).
Post by jimwilliams on Jan 9, 2018 14:19:30 GMT -6
Or add a couple of 14 pin Millimax IC sockets and have all the options available? Then you can use some high test chips on a Brown Dog 4136 to dual SOIC adaptor, the old TL075 fet input quad (if you can find one) or the noisy and dirty original RC4136. Plug and play.
Post by unit7 on Jan 10, 2018 16:41:20 GMT -6
Sorry for posting this here, but I've been considering selling my pair of Alactronics mod LA-4s. Unfortunately I don't know anything about the mod. Bought after Fletched hyped it on GS. Sounds good, but after building a pair of Serpent SA-3s and having my rack full something has to go.. PM if interested!
