Post by guitfiddler on Jan 5, 2018 4:17:54 GMT -6
If you buy a satellite Octo they say they give you the Neve, SSL, and whatever else totaling up to $1100...whatever? Anyway, if you own all those plugs they should give you anyway, do you get to choose your own plugs? I remember on these promotions in the past they gave you a voucher totaling the same amount of their promotion if you owned the plugs.
Post by kcatthedog on Jan 5, 2018 5:20:32 GMT -6
They did do that in the past. I think now you can select but from a defined sub set of plugs not anything check the fine print. Sone people seem to have luck talking to CS directly?
