Post by bartacusad on Dec 22, 2017 20:46:03 GMT -6
I got a TV to use as a second monitor and it looks great but there is some serious latency going on with the keyboard and mouse (Kensington with latest driver). Is there some trick to making it work? I'm using a Thunderbolt to HDMI adapter to get the video to the TV (fyi). Also, each time I reboot the computer I have to go back in and turn on mirroring and that's seriously annoying also.
Post by drew571 on Dec 22, 2017 21:35:51 GMT -6
Post by bartacusad on Dec 22, 2017 22:48:59 GMT -6
Thank you so much. Really helpful....and educational!
Post by mulmany on Dec 22, 2017 23:10:45 GMT -6
Try turning off all the special features in the tv. Basically turn off all processing. That should help a bit.
Post by bartacusad on Dec 22, 2017 23:48:16 GMT -6
Try turning off all the special features in the tv. Basically turn off all processing. That should help a bit. Yes, that did help. I also switched to the 60hz input and put it gaming mode. Its not perfect bu it’s definitely a lot better.
