Post by M57 on Nov 12, 2017 11:51:04 GMT -6
Did you do any adjustments of the level of the actual file in trying to get the dynamics right? I think Aria will read the RMS of a track and then that is what will raise the RMS to a certain point. I asked Colin if it set the track to a certain RMS level per setting and he'd told me it depended on the RMS level of the track when it came in. I'm recalling being told the opposite from Collin. I specifically asked if changing the peak RMS level of a submitted track would change the DR of the Aria output, and I recall being told that it doesn't make much difference. Now what I didn't ask him was, "What if I changed the DR of the submitted track?" I.e., what if I pre-compressed it a bit before submitting it. Regardless, I recall Collin suggesting that submitting (and paying for) multiple files adjusted on my end in an attempt to alter the Aria master was a waste of time. I should go back and look for those threads. I'm pretty sure they're here on RG.
