Post by drbill on Apr 27, 2017 20:39:24 GMT -6
drbill you ever used the drawmer mx 30? Nope.
Post by adamjbrass on Apr 28, 2017 6:41:52 GMT -6
I only use Dither when going from 24 bit to 16 bit File internally within the DAW. I could not even fathom using dither on every track of my mix. You might as well kill me now.
Post by drbill on Apr 29, 2017 12:59:15 GMT -6
I only use Dither when going from 24 bit to 16 bit File internally within the DAW. I could not even fathom using dither on every track of my mix. You might as well kill me now. Preferred method of demise???
Post by adamjbrass on Apr 30, 2017 6:47:33 GMT -6
Truncated. Ashes to Ashes, Dither to Dither.
"There is no latency in heaven" - Steve Gursky inside Mixerman's Dream
Post by stormymondays on Apr 30, 2017 8:06:26 GMT -6
I followed this discussion attentively at the purple place. Tried a few flavors of Airwindows dither before all my IO plugins. Couldn't hear a meaningful difference, but I kept them on. I then decided that whoever coded that Logic plugin was smarter than me and would have added a simple triangular dither to it. I took off the dither plugins. My mix was still kicking ass, if I say so myself!
Post by Deleted on May 1, 2017 9:42:01 GMT -6
I see WWI mass graves coming like in Ardennes. It's a dirty war. Just after Loudness War is over.
Post by mrholmes on May 3, 2017 11:57:08 GMT -6
I followed this discussion attentively at the purple place. Tried a few flavors of Airwindows dither before all my IO plugins. Couldn't hear a meaningful difference, but I kept them on. I then decided that whoever coded that Logic plugin was smarter than me and would have added a simple triangular dither to it. I took off the dither plugins. My mix was still kicking ass, if I say so myself! BK told me that some gear self dithers to a good degree ....
Post by Deleted on May 3, 2017 18:03:28 GMT -6
My Mytek AD dithers if you chose 16 bit out. Of course. That's a mastering function, so to speak. Self-dithering DAC? I wonder how this could be possible technicallly. If it induces noise, it is noise, not dither, because it gets a 24 bit signal - after conversion... too late for dither.
