Post by Johnkenn on Mar 31, 2017 10:31:46 GMT -6
UUUUHHHHHHGGGGGGGGGGGGGGG Somewhere along the way I must have changed the fade at the end on the bass. Now it rings after the synth at the very end. So, I'm gonna import the 16/44.1 mastered file into PTs and fix the fade on the 2-track wav and then export at 16/44.1. Will this damage anything? Do I need to add dither? Or do I need to fix it in the mix and send back for another mastering pass? Bob Olhsson
Post by Johnkenn on Mar 31, 2017 10:32:19 GMT -6
Also trying the "D" option to see if that's somewhat of an "in-between" on loudness from E to A
Post by Johnkenn on Mar 31, 2017 10:37:51 GMT -6
Damn...D is even louder than A
Post by Johnkenn on Mar 31, 2017 11:47:37 GMT -6
OK - here's the Final (Really) I decided on...
Little crushy, but by God, I'll be as loud as the next guy lol
Post by ChaseUTB on Mar 31, 2017 14:01:36 GMT -6
16 bit has already been dithered, I would not dither again, you will be adding noise to your file for no reason...
Post by mjheck on Apr 1, 2017 10:40:11 GMT -6
JK - have you worked with the NuGen metering plug in at all? In addition to giving reading on LUFS and PLR, It has a really handy feature that allows you to hear your mix through the various loudness limiting and compression schemes of a variety of distribution channels, including iTunes, Spotify, etc. The Spotify option even lets you hear the difference between their regular and premium resolutions.
Im sure they are not exact, given there is bound to be some proprietary stuff in there, but you may find it really useful - especially when trying to find the balance between expected loudness and desired dynamic range.
There are some pretty good articles on the internets digging through exact what is going on in each companies "sound check" programs, but the big idea is that you can at lest hear what will likely happen to your file on whatever you expect to be your targeted end platform.
JMH
Post by Deleted on Apr 2, 2017 14:52:38 GMT -6
You can also minimize the impact of the different platform's own automatic DSPs by loudness normalization to the platforms standard, AFAIK Spotify and itunes radio and broadcast stations etc. may have different loudness standards. I do not know the numbers though... Just another thought on the topic... Hrrrmmmm. Brave new digital world....
Post by Guitar on Apr 2, 2017 17:07:30 GMT -6
Wow, that sounds great! Love the song also.
Post by mitchkricun on Apr 3, 2017 13:47:57 GMT -6
I liked E better than A, but I understand the need to be competitive and A still sounds really good. Great song John! Are you detuning the drums or is that just the samples?
Post by Johnkenn on Apr 3, 2017 17:55:13 GMT -6
I liked E better than A, but I understand the need to be competitive and A still sounds really good. Great song John! Are you detuning the drums or is that just the samples? Just the samples. That alt rock kit is killer. A little roomy but great samples.
Post by mitchkricun on Apr 4, 2017 15:03:44 GMT -6
Yeah, they sound great! I think I'm going to start mixing my toms louder after hearing this! The whole thing sounds really modern and traditional at the same time.
Post by Johnkenn on Apr 4, 2017 18:14:50 GMT -6
I just realized the "Basic" mix gets rid of a lot of the room...but I'm bouncing them down from SD2 anyway, so the mix in the plug doesn't matter much.
