Post by kcatthedog on Mar 13, 2017 8:10:28 GMT -6
Uncle Eric from JRR messin us around from UA forum : "Blind Test: Marshall JTM45 vs. UAD Marshalls vs. AmpliTube 4 Here's a blind test between my JTM45 HandWired Reissue vs. the UAD Marshalls vs. AmpliTube 4 "Red Pig". I will post this to Gearslutz and KVR, as well, and will post the results as soon there are 20 or more responses between all the forums. The DI was a custom Cinemag run into an Apollo preamp with no Unison plugin. Levels were matched using the meter in the UAD Precision Limiter. All settings are the same where possible. Gain settings were approximated on the Marshalls with separate input gains and master outs. The files were gated because the real amp's noise gave it away. All the tracks were routed to a single gate that was being side chained to the DI, meaning the gate response was identical for all files. The real amp is miked with an SM57 and a NOS Audio Panther ribbon mic, which sounds like an R121, into Apollo preamps with no Unison plugins. The UAD Marshalls lack a ribbon close mic so I chose either the SM7b or 609 as the second mic if they were available. Yes, I recognize that this presents a problem but I didn't see why the real amp and AmpliTube 4 should be punished over something that the UAD Marshalls are lacking:" soundcloud.com/eric-dahlberg-2/sets/marshall-blind-testpersonally, I like 4 and 6 : you ? reveal later this week
Post by jcoutu1 on Mar 13, 2017 9:00:22 GMT -6
I like 2 by a good margin. 6 would be the second choice for me.
Post by Deleted on Mar 13, 2017 10:49:17 GMT -6
they all sound shite ... send me that jtm immediately, it's being neglected .....
Post by svart on Mar 13, 2017 11:07:46 GMT -6
I like 2,4,6. I think I like 2 best for a mix, then 4. 6 for leads.
Post by Ward on Mar 13, 2017 12:18:13 GMT -6
None of them sounds particularly good to my ears. They all sound choked, comb-filtered or EQ filtered. 3 is the only one that legitimately sounds like an amp, albeit a poor recording of an amp.
A Marshall is all about the midrange, and that's what gives it its voice and tell-tale tone. The mid sounds 'happy-faced out' in all these. Some 'happier' than others.
Post by ChaseUTB on Mar 13, 2017 14:01:49 GMT -6
1. Decent vibey sounds most like AC/DC does to me 2. for a lead 3. Horrible 4. Is choked and has no life 5. is no mid all mid lo n lows 6. most balanced would use for LD and mix
Post by wiz on Mar 13, 2017 15:47:55 GMT -6
geeze they are all a bit ordinary....
my guess 6 ... but thats not how I make JTM 45s sound.... 8)
Post by lcr on Mar 13, 2017 15:59:45 GMT -6
Im poppin' popcorn waiting on the results.. is it microwave popcorn or movie theater popcorn?
Post by sozocaps on Mar 13, 2017 16:59:24 GMT -6
2
Post by scumbum on Mar 13, 2017 21:35:39 GMT -6
Yep , 4 and 6 were the best .
My guess is #4 is the real JTM .
and #6 UAD Marshall .
#5............if thats the real amp it was miced VERY poorly .
Post by donr on Mar 13, 2017 21:48:34 GMT -6
WTF is up with #5? I've never heard any amp sim sound that bad. Could be a real amp mic'ed badly (like a mic under a blanket across the room,) but a sim? Especially if the goal was to sound like AC/DC.
Post by kcatthedog on Mar 14, 2017 11:28:39 GMT -6
the reveal:
1 UAD Plexi 2 AmpliTube 4 Red Pig 3 UAD JMP 2203 4 Real Marshall JTM45 5 UAD Blues Breaker 6 UAD Jubilee
Post by ChaseUTB on Mar 14, 2017 11:43:49 GMT -6
What a weird test...
Post by jcoutu1 on Mar 14, 2017 11:52:03 GMT -6
the reveal: 1 UAD Plexi 2 AmpliTube 4 Red Pig 3 UAD JMP 2203 4 Real Marshall JTM45 5 UAD Blues Breaker 6 UAD Jubilee I guess it's time to upgrade my Amplitube version.
Post by Ward on Mar 14, 2017 12:10:35 GMT -6
Time well wasted.
Post by scumbum on Mar 14, 2017 15:02:03 GMT -6
I thought it was a good test . The real amp stood out pretty easily .
