Post by M57 on Feb 23, 2017 10:19:38 GMT -6
I'm starting a fresh thread on this partially in response to the emergence of automated mastering sties and software, but mostly because I'm admittedly just not knowledgeable about expectations, standards, practices, etc. So I'll just start it off with a bunch of questions in no particular order of importance.
So for instance, if you were working with a pro - What's on the table? Obviously compression, but EQ, HP, LP, automation of any sort?
Convince me I should be using a pro and not an automated system. What exactly are they doing (technically) that makes a difference? In other words, what specific kinds of things can I ask a pro to do that I can't ask an automaton to do?
What types of things can an M/E "fix?"
When you master your own work (assuming you're not an m/e) What do you end up using and why?
Assuming you're mastering differently depending on the venue (SoundCloud), CD, etc, would you ask an m/e to give you multiple mixes?
What do the pros like to work with? What are their expectations? In a perfect world, would they be happy to just slap on a compressor or two and be done? ..or is that a waste of their talents?
Post by EmRR on Feb 23, 2017 10:31:26 GMT -6
It should sound better and not worse.
It should sound better across all types of systems.
It should not be required to do differing processing for differing platforms, apples to apples.
There should be no automatic approach. They should do whatever their experience tells them is needed. Blank slate. That may be practically nothing at all, but rarely. Vinyl should require a slightly different approach later in the process, but not an entirely different approach.
What they can fix is dictated by the particular case. The same problem might be fixable in one case and not in another. Obvious things like reversed polarity should be fixable as a given by an attentive engineer.
Post by mrholmes on Feb 23, 2017 10:44:52 GMT -6
I expect someone who checks my mixes and is going to repair minor things. I expect someone who advises me to remix something if I failed - can happen. I don't expect to get a total different mix back. I had test sessions where strings have been mixed in the background and with some of the stupid tools they where up front in the master I had test sessions where they used on a nice song their stupid limiters and limited the shit out of it. I want a ME with taste and feel for the music. None of those who thinks he needs to show me all his tools. I have found someone over the years, but I am nosy to try Bob O. next time.
Post by ChaseUTB on Feb 23, 2017 14:33:41 GMT -6
I'm starting a fresh thread on this partially in response to the emergence of automated mastering sties and software, but mostly because I'm admittedly just not knowledgeable about expectations, standards, practices, etc. So I'll just start it off with a bunch of questions in no particular order of importance. So for instance, if you were working with a pro - What's on the table? Obviously compression, but EQ, HP, LP, automation of any sort? Convince me I should be using a pro and not an automated system. What exactly are they doing (technically) that makes a difference? In other words, what specific kinds of things can I ask a pro to do that I can't ask an automaton to do? What types of things can an M/E "fix?" When you master your own work (assuming you're not an m/e) What do you end up using and why? Assuming you're mastering differently depending on the venue (SoundCloud), CD, etc, would you ask an m/e to give you multiple mixes? What do the pros like to work with? What are their expectations? In a perfect world, would they be happy to just slap on a compressor or two and be done? ..or is that a waste of their talents? This is me and my process. It may or may not vary from one ME to the next: My process is not the only way set in stone: 1. Serve the song and or album. There is never a set guideline to make a list like each master needs : eq, compression, limiting etc. Most of what you listed can and has been employed in many masters however those processes don't have to happen per se. May just need more level ( gain ) 2/3. A pro has human ears and is a second line of defense before the world will hear your music. When mixing it's easy to get caught up in minutae, plus a mastering engineer Room 95% of the time is tip top notch as well as their monitoring. They provide a safety net, a check and balance, and can tell you what needs to be corrected to have the best master b4 any processes are applied. Now that's not to say that a ME can't travel to different rooms with their mobile setup and still kill it, Glenn Schick does this and has #1 albums, so a permanent room is not always a must. A pro can sequence an album based off feel and emotion, not by spread sheet or bpm. Someone like Bob O can do tape, vinyl, etc. You have the ability to ask a pro whatever not sure how you ask aria anything.. I don't know how aria works, I assume the ME listens to the file then picks one of the algorithms A-E which would best suit the song. So if that's how it works then you still have a pro ( prob not Colin but his assistant ) still listening, i.e. Human ears. If it's all automated and a ME doesn't actually listen then idk, you are at the mercy of whatever parameters have been set in the algorithms..( not saying Aria does this either ) Idk how Aria would order an 11 song album ( I'm guessing bpm or maybe DR, idk ) or if the service even offers that.. Aria is an algorithm that masters the song / processes the mix you send and From my understanding if you don't like the result you pick another algorithm. 4. I am usually just adding level and isp protection for conversion downstream. I handle heavy lifting during mixing. May hear something I don't like so some notch filtering, nothing major because I get the mix right while also making sure to monitor at reference master playback ( grab a major label release, import into DAW, use clip gain or a limiter's ceiling/ output to turn down ref to -.5db so it won't clip, and match your mix's volume ) 5/6/7. I want the best mix you can give and whatever it takes for you to get that mix. If you leave me no Headroom I clip gain your mix down and start from there. I provide the best master and then provide the correct dither and conversion files as well. Meaning separate MP3, MFIT, Cd, Hi Def Master ( 24bit - 96 kHz ) for Streaming, sharing, distribution, etc 8. I don't ever just slap on a compressor and call it done. If the master doesn't need anything but gain / level and proper dither/ conversion I am happy because that's an easy master baby! Got to love those 🤑😀 I posted in the " What Are You Working On " thread 6 new Masters I did with my SA4000. I listed some settings and brief workflow.
Post by Deleted on Feb 23, 2017 17:27:32 GMT -6
Convince me I should be using a pro and not an automated system. What exactly are they doing (technically) that makes a difference? What do the pros like to work with? There's a Mastering Engineer who lives relatively local to me. Despite working on albums by major bands that we all would have heard of, he offers a reduced rate for unsigned artists (his way to support the industry). Despite knowing I'm severely limited artistically / recording / mixing wise, I phoned him one day just to ask about his services. I found making the call a bit daunting as I didn't know what to expect.We ended up chatting for ages about bands we liked and had seen, the various venues nearby etc.. No hard sell. No pressure. What he did offer was to have a listen and give feedback to any track I sent him before he touched it. Once I've raised my game a bit I will be using him for at least one album, just so I know what a real ME can do, and so I don't always wonder what if...? He charges (not much, believe it or not) more than Aria and the likes, but I'll use him simply because I know I can chat with him about the process, obtain advice and change stuff accordingly, and because his work speaks for itself ( much same way as Bob O's does). He wasn't all grandiose, and I really felt he genuinely wanted to help and do the best for my music. M57 I think work of the quality you produce deserves a good mastering engineer. It's the 2-pack lacquer on a great paint job.
Post by svart on Feb 23, 2017 21:54:03 GMT -6
To me:
Above all else, the mastering engineer should provide feedback to improve the mix even before he/she touches their gear. The mix is the place where everything happens. A mix engineer should aim to create a mix that the mastering engineer should not need to touch, and you're just paying for the ears of a person who has listened as a professional and offered insight.
When the mastering engineer decides to act, it's to add musicality to the mix and bring forth the elements that make it better, without resorting to huge changes that might turn the song into something it was not intended to be.
Above all, the mastering engineer should be a friend for hire that will give you insight to make your mixes better.
Post by johneppstein on Feb 23, 2017 22:31:45 GMT -6
I'm starting a fresh thread on this partially in response to the emergence of automated mastering sties and software, but mostly because I'm admittedly just not knowledgeable about expectations, standards, practices, etc. So I'll just start it off with a bunch of questions in no particular order of importance. So for instance, if you were working with a pro - What's on the table? Obviously compression, but EQ, HP, LP, automation of any sort? Convince me I should be using a pro and not an automated system. What exactly are they doing (technically) that makes a difference? In other words, what specific kinds of things can I ask a pro to do that I can't ask an automaton to do? What types of things can an M/E "fix?" When you master your own work (assuming you're not an m/e) What do you end up using and why? Assuming you're mastering differently depending on the venue (SoundCloud), CD, etc, would you ask an m/e to give you multiple mixes? What do the pros like to work with? What are their expectations? In a perfect world, would they be happy to just slap on a compressor or two and be done? ..or is that a waste of their talents? I expect it to sound like what I sent in but...... better, more "like a record". If there is something I've been unable to deal with hopefully the ME will be able to figure it out and take care of it. Since a real ME with real mastering gear has more accurate EQ and can do some things I can't I expect some detail work to come back improved if needed. Sometimes I'll provide notes on specific points that I feel require individual attention - Like "The "S" in such and such word in the third line of the last verse has an annoying sibilance I haven't been able to adequately deal with". I expect him to use his superior experience to be able to understand what I'm shooting for and implement that. I also expect the set of tracks I send in to work together to sound like an album, as they may have been recorded over the space of one or more years and may not have the same players on them. And of course all the metadata stuff. What I DO NOT want or expect and will not pay for is for something to come back drastically different from what I sent in. But that's not really a problem because I don't use people I don't trust. I also DO NOT want it to come back sounding slammed or brickwalled, although I do expect a reasonable level that hopefully won't sound totally wimpy compared with other music of the same general type. I don't master at all (To me doing that would defeat the purpose), but my music partner will do "fake mastering" for nonrelease purposes - he uses some sort of commercial mastering suite, I think Ozone. Although I've actually been impressed by the "automated mastering" test that was conducted here I still would not use such a service, although it's a lot cheaper and faster because it cannot furnish what I expect from a good ME - experience, taste, and attention to individual detail. Machines are not able to provide those things, and I don't want my music processed through some sort of "cookie cutter" assembly line that uses some sort of algorithmic evaluation process. "So for instance, if you were working with a pro - What's on the table? Obviously compression, but EQ, HP, LP, automation of any sort?" Whatever is necessary to achive the desired result. "Convince me I should be using a pro and not an automated system. What exactly are they doing (technically) that makes a difference?" Listening (both to the music and to me) and thinking. Also they have access to hardware I don't have and can't afford (and might not know how to use properly if I did.) " In other words, what specific kinds of things can I ask a pro to do that I can't ask an automaton to do?" Listen. Think. Discuss my intent with me. Automatons can't think and can't listen. They have no taste. They have no emotional response. "What types of things can an M/E "fix?" " Ok, here's a somewhat embarassing anecdote that provides a good answer - When we sent in my first album to Bob we'd been chasing a weird problem on mixes of a couple of songs where thing panned center in an LCR mix were not coming out centered and there was a weirdness in the low end. Almost immediately on receipt of the tracks Bob got back to me with the news that there was a phasing problem primarily on the low end of exactly the tracks we'd been having trouble with. I told him that we were aware of a problem but had tried everything we could think of and it still wouldn't go away and asked If he could do anything. He did, no problem, I'm not sure exactly what he did but it went away. Later on, after considerably more hair tearing and redoing the processing chain on the 2 buss several times it turned out that one of the converters in the system had developed a flaky problem on all the odd (or maybe even, I don't remember) channels of conversion. It was present in one out of three 8-channel converters and of course it was the converter we had assigned to the mixdown channels. Since all the channels in the one box had the same problem, switching channel pairs in the box didn't help and we hadn't thought that it might be a problem specific to all the channels on one side of one converter box.
Post by M57 on Feb 25, 2017 5:23:04 GMT -6
I've been reading these great responses. I get the "human" musical aspect, and I like the idea of having a 'back-up' set of ears, and the concept of the 'partnership' and need for trust. But as far as 'fixing' things is concerned, it seems to me that 95% of fixes are better applied to the mix, not the master. I think Svart nailed this one with his comment. If there's an 'ess' problem, a noise problem, something that needs to be notched, etc. isn't it much easier and more musical to fix it on the offending tracks?
I'm thinking in terms of my own mixes, which I know are highly flawed. For instance, I do my best to notch areas where there's build-up, but with mixed results. I'm a song-writer and musician first. I'm fortunate enough to be able to afford a reasonable space and some pretty nice gear, but I work in a vacuum and my knowledge and level of experience as an engineer is pretty much home-grown. When I've reached out for support from members of this community, both on in the forums and in PMs, I've gotten some really good advice, but my ability to execute is fair ..to good at best. I don't know what it costs to have a song professionally mastered, but it occurs to me that I would get more bang for my buck if I had my songs professionally (but remotely) mixed.
Now obviously this is Pandora's box, but it occurs to me that there are 'levels' of mixing/mastering. Imagine that I could for instance send an M/E stems that are processed with pre-set levels. So essentially the mix is done, but now at least the M/E can isolate the problems in a much more musical fashion. He may only need to make a 'fix' in one or two stems. Now I'm guessing that most M/E's set-ups don't support this work-flow, but I'm just thinking hypothetically.
I bring this up because I'm trying to figure out the calculus of the value of work that I sub out. If I'm parting with money for services, it may not be so much a question of "Is this guy doing a great job?" as much as, "Is this where and how my money is best spent?"
Post by keymod on Feb 25, 2017 5:41:52 GMT -6
I've been reading these great responses. I get the "human" musical aspect, and I like the idea of having a 'back-up' set of ears, and the concept of the 'partnership' and need for trust. But as far as 'fixing' things is concerned, it seems to me that 95% of fixes are better applied to the mix, not the master. I think Svart nailed this one with his comment. If there's an 'ess' problem, a noise problem, something that needs to be notched, etc. isn't it much easier and more musical to fix it on the offending tracks? I'm thinking in terms of my own mixes, which I know are highly flawed. For instance, I do my best to notch areas where there's build-up, but with mixed results. I'm a song-writer and musician first. I'm fortunate enough to be able to afford a reasonable space and some pretty nice gear, but I work in a vacuum and my knowledge and level of experience as an engineer is pretty much home-grown. When I've reached out for support from members of this community, both on in the forums and in PMs, I've gotten some really good advice, but my ability to execute is fair ..to good at best. I don't know what it costs to have a song professionally mastered, but it occurs to me that I would get more bang for my buck if I had my songs professionally (but remotely) mixed. Now obviously this is Pandora's box, but it occurs to me that there are 'levels' of mixing/mastering. Imagine that I could for instance send an M/E stems that are processed with pre-set levels. So essentially the mix is done, but now at least the M/E can isolate the problems in a much more musical fashion. He may only need to make a 'fix' in one or two stems. Now I'm guessing that most M/E's set-ups don't support this work-flow, but I'm just thinking hypothetically. I bring this up because I'm trying to figure out the calculus of the value of work that I sub out. If I'm parting with money for services, it may not be so much a question of "Is this guy doing a great job?" as much as, "Is this where and how my money is best spent?" I'm in the same boat. A great space and gear, but not enough time to practice the art.
Post by jcoutu1 on Feb 25, 2017 8:49:26 GMT -6
I've been reading these great responses. I get the "human" musical aspect, and I like the idea of having a 'back-up' set of ears, and the concept of the 'partnership' and need for trust. But as far as 'fixing' things is concerned, it seems to me that 95% of fixes are better applied to the mix, not the master. I think Svart nailed this one with his comment. If there's an 'ess' problem, a noise problem, something that needs to be notched, etc. isn't it much easier and more musical to fix it on the offending tracks? I'm thinking in terms of my own mixes, which I know are highly flawed. For instance, I do my best to notch areas where there's build-up, but with mixed results. I'm a song-writer and musician first. I'm fortunate enough to be able to afford a reasonable space and some pretty nice gear, but I work in a vacuum and my knowledge and level of experience as an engineer is pretty much home-grown. When I've reached out for support from members of this community, both on in the forums and in PMs, I've gotten some really good advice, but my ability to execute is fair ..to good at best. I don't know what it costs to have a song professionally mastered, but it occurs to me that I would get more bang for my buck if I had my songs professionally (but remotely) mixed. Now obviously this is Pandora's box, but it occurs to me that there are 'levels' of mixing/mastering. Imagine that I could for instance send an M/E stems that are processed with pre-set levels. So essentially the mix is done, but now at least the M/E can isolate the problems in a much more musical fashion. He may only need to make a 'fix' in one or two stems. Now I'm guessing that most M/E's set-ups don't support this work-flow, but I'm just thinking hypothetically. I bring this up because I'm trying to figure out the calculus of the value of work that I sub out. If I'm parting with money for services, it may not be so much a question of "Is this guy doing a great job?" as much as, "Is this where and how my money is best spent?" I'm in the same boat. A great space and gear, but not enough time to practice the art. Killer space. Wanna trade? Haha
Post by keymod on Feb 25, 2017 9:16:25 GMT -6
I'm in the same boat. A great space and gear, but not enough time to practice the art. Killer space. Wanna trade? Haha Don't want to trade, but I wish you could come and work here often.
Post by ChaseUTB on Feb 25, 2017 14:05:37 GMT -6
jcoutu1 has his price to make that happen we all do 🤑😀
Post by johneppstein on Feb 25, 2017 20:35:02 GMT -6
Somebody mentioned "stems". Using stems is NOT MASTERING.
Using stems is REMIXING.
If a "mastering engineer" asked me for stems he would not get the job. Period. I'm not looking to have somebody impose his vision on my mix.
As far as I'm concerned, the only legitemate reason for anyone to ask for stems is if the music is to be used on a soundtrack for a movie or broadcast TV show, which would conceivably require remixing to, fopr example, duck the vocals a bit during dialog or similar video related requirements. And the guy who got the stems would NOT be a so-called "mastering engineer", he would be a professional film remix engineer, working for the director of the film. And I'd better see some bucks up front along with a contract that passes my lawyer's scrutiny. (Fat chance of this actually happening, but you never know...)
Odds are, though, that we'd just send remixes to meet the requirements, as "stems" don't exist in my analog mixing process.
Post by massivemastering on Feb 26, 2017 1:05:22 GMT -6
I want to preface this with "I wholly support NOT using stems - But I occasionally get them and I'm fine with that too. I'm guessing that most M/E's set-ups don't support this work-flow, but I'm just thinking hypothetically. Most ME's I know (including myself) do most of the "stem adjustments" digitally and then just run 'em all out of the main buss. This is a trickier one -- Although there CERTAINLY ARE mastering engineers that go WAY overboard on what they do with stems, some artists would just rather send in stems "just in case" -- And that "just in case" is usually something simple -- Maybe the client wants "excessive loudness" and it pushes the vocals down a touch too much. Easy to just add a dB to the vocals. Maybe it pushes the cymbals into cymbal sibilance (Cymbilance?™) and it'd just be easier to apply a little side EQ to the drum stem. Maybe the guitars just wind up being a bit too "thwumpy" (?™) and cutting a little 100Hz on the guitars makes lets the bass cut through as it did on the original mix. PLEASE KEEP IN MIND that I'm TOTALLY not suggesting that I (or again, most ME's I know) prefer to work this way -- Lord knows, I want the client's mix to sound like *the client's* mix when it's done. And I would argue that most of the time when a client insists on sending in stems, I just set them all at unity and do whatever I was going to do in the first place. That said - I *do* know of a few guys who actually *prefer* to use stems from the start. And some of those are followed up by forum threads by folks who are pissed off because they went all "remix" with their stems. I'm not trying to defend the use of stems - But it's not the use of stems that's evil. It's what *some* people do with them. And almost without fail, the better sounding mixes have no reason to use them anyway.
Post by johneppstein on Feb 26, 2017 1:45:36 GMT -6
I want to preface this with "I wholly support NOT using stems - But I occasionally get them and I'm fine with that too. I'm guessing that most M/E's set-ups don't support this work-flow, but I'm just thinking hypothetically. Most ME's I know (including myself) do most of the "stem adjustments" digitally and then just run 'em all out of the main buss. This is a trickier one -- Although there CERTAINLY ARE mastering engineers that go WAY overboard on what they do with stems, some artists would just rather send in stems "just in case" -- And that "just in case" is usually something simple -- Maybe the client wants "excessive loudness" and it pushes the vocals down a touch too much. Easy to just add a dB to the vocals. Maybe it pushes the cymbals into cymbal sibilance (Cymbilance?™) and it'd just be easier to apply a little side EQ to the drum stem. Maybe the guitars just wind up being a bit too "thwumpy" (?™) and cutting a little 100Hz on the guitars makes lets the bass cut through as it did on the original mix. PLEASE KEEP IN MIND that I'm TOTALLY not suggesting that I (or again, most ME's I know) prefer to work this way -- Lord knows, I want the client's mix to sound like *the client's* mix when it's done. And I would argue that most of the time when a client insists on sending in stems, I just set them all at unity and do whatever I was going to do in the first place. That said - I *do* know of a few guys who actually *prefer* to use stems from the start. And some of those are followed up by forum threads by folks who are pissed off because they went all "remix" with their stems. I'm not trying to defend the use of stems - But it's not the use of stems that's evil. It's what *some* people do with them. And almost without fail, the better sounding mixes have no reason to use them anyway. Well, from this post it doesn't seem to me that I was talking about you. According to what you've said you accept stems but don't ask for them. That's fine, I guess - if the client doesn't trust his taste or abiolity to come up with a decent mix that's his problem. And if he wants his product slammed to thge point that it develops serious problems (probably including having people; want top turn it down - or off) that's his problem as well*. I was specifically talking aboute "MEs" who ask for them or, dog forbid, insist on them. And yeah, I was also getting a little dig in at people who lack confidence in their mixing abilities to the point where they want the ME to remix it for them. * - I'd argue that it should be a good ME's responsibility to explain to the client that he really shouldn't want his stuff slammed like that, as it will have the exact opposite of the desired effect on radio or MP3 streaming services due to the way that the processing in those outlets interacts with a too loud program, but I understand that a lot of guys don't wanty scare off customers.
Post by wiz on Feb 26, 2017 2:19:37 GMT -6
I want to preface this with "I wholly support NOT using stems - But I occasionally get them and I'm fine with that too. I'm guessing that most M/E's set-ups don't support this work-flow, but I'm just thinking hypothetically. Most ME's I know (including myself) do most of the "stem adjustments" digitally and then just run 'em all out of the main buss. This is a trickier one -- Although there CERTAINLY ARE mastering engineers that go WAY overboard on what they do with stems, some artists would just rather send in stems "just in case" -- And that "just in case" is usually something simple -- Maybe the client wants "excessive loudness" and it pushes the vocals down a touch too much. Easy to just add a dB to the vocals. Maybe it pushes the cymbals into cymbal sibilance (Cymbilance?™) and it'd just be easier to apply a little side EQ to the drum stem. Maybe the guitars just wind up being a bit too "thwumpy" (?™) and cutting a little 100Hz on the guitars makes lets the bass cut through as it did on the original mix. PLEASE KEEP IN MIND that I'm TOTALLY not suggesting that I (or again, most ME's I know) prefer to work this way -- Lord knows, I want the client's mix to sound like *the client's* mix when it's done. And I would argue that most of the time when a client insists on sending in stems, I just set them all at unity and do whatever I was going to do in the first place. That said - I *do* know of a few guys who actually *prefer* to use stems from the start. And some of those are followed up by forum threads by folks who are pissed off because they went all "remix" with their stems. I'm not trying to defend the use of stems - But it's not the use of stems that's evil. It's what *some* people do with them. And almost without fail, the better sounding mixes have no reason to use them anyway. Welcome cheers Wiz
Post by gouge on Feb 26, 2017 3:15:02 GMT -6
And yeah, I was also getting a little dig in at people who lack confidence in their mixing abilities to the point where they want the ME to remix it for them. that really says a lot about who you are as a person. i'm stunned that you even wrote that online.
Post by M57 on Feb 26, 2017 5:32:08 GMT -6
I'm not trying to defend the use of stems - But it's not the use of stems that's evil. It's what *some* people do with them. And almost without fail, the better sounding mixes have no reason to use them anyway. This is exactly what I'm talking about. Traditionally, pro mastering engineers get pro mixes, and I think there's a new world order here, with thousands of neophytes creating mixes that are simply not up to the standards that old-school MEs are accustomed to. As for johneppstein 's "dig" - I think he's right. He's talking about people like me and I take no offense. I am not super-confident about my skills. This is the pandora's box I'm talking about. You could argue that I should have my songs professionally mixed, but I know what I want and I'm not a total neophyte. Besides, I like mixing. This is my hobby/avocation and it's my art. The fact that I'm even considering sending my mixes to a ME should tell you that I do have a certain level of confidence. I'm actually pretty happy with my 'mixes,' but I know they have flaws.. mostly on the EQ side of things, and I'm smart enough to know that it's not best practice to have the ME fixing those kinds of problems on the 2. I feel like my work straddles the fence. I liked what Aria did to my mixes. Just the part where it went through a layer of analog gear made a huge difference to me - I can only imagine what a real human ME would do with same, but if I'm going to pay for another set of ears, why shouldn't find someone that could work with "pre-mixed" stems - just in case there are problems that SHOULD be solved before the 2?
Post by M57 on Feb 26, 2017 10:19:54 GMT -6
Mind you, I'm talking about the M/E keeping the stems at unity as @amassivemastering described, maybe making a small adjustment as necessary to balance whatever work they do at that level.
And I get it - or at least I think I get it. Mastering is not mixing. I just wonder that M/Es who are willing to shift the paradigm of the job description may be in a better position to attract and please clientele who reside at the edges of the industry.
Post by johneppstein on Feb 26, 2017 14:03:38 GMT -6
And yeah, I was also getting a little dig in at people who lack confidence in their mixing abilities to the point where they want the ME to remix it for them. that really says a lot about who you are as a person. i'm stunned that you even wrote that online. A bit thin skinned, huh? And it wasn't even directed at you.... (but if you want to own it, ok....) People need to develop confidence in themselves. You won't do that by passing your responsibilities off to somebody else. If you're gonna do that, why not just have somebody else do the whole mix? At least you'd have a coherent vision behind it. You call yourself a mix engineer? Then mix! Who am I as a person? I'm a person who is willing to tell people what I think they need to hear. Sometimes they don't like it, but if they pay attention hopefully it will be to their benefit.
Post by johneppstein on Feb 26, 2017 14:26:59 GMT -6
Mind you, I'm talking about the M/E keeping the stems at unity as @amassivemastering described, maybe making a small adjustment as necessary to balance whatever work they do at that level. And I get it - or at least I think I get it. Mastering is not mixing. I just wonder that M/Es who are willing to shift the paradigm of the job description may be in a better position to attract and please clientele who reside at the edges of the industry. Yeah, I have mixed feelings about that. I understand that there are a lot of people who feel they need to do whatever it takes to bring cash through the door. As far as clientele who reside at the edge of the industry are concerned, I question whether it's really a good idea to encourage those who don't have what it takes to do their own work, given the glut of unqualified people on both sides of the glass. I dunno, there's a lot that I have to say about this from a lot of angles, but I'm not sure if this is the place to do it.
Post by Deleted on Feb 26, 2017 15:30:09 GMT -6
Many good points. First, i want the ME to reliably do the technical side of pre-master, i.e. ensure, that i do not get format problems for whatever medium i let him master. Also proper appliance of metadata. What nowadays is not that often done anymore - adjusting the silence gaps and volume levels in the line of the music, if it is an album. This is something different than normalizing, and therefore it isn't done too often anymore - because people want all songs mastered for radioplay, streaming etc. and compete to other masters you see on itunes or whatever, i.e. you can't have both normally, optimal album levels and total compatibility to a single master (i.e. normalized)... If you want the master for vinyl, this is more important, because there all songs do have a context, and i would like to have all songs in musically sounding levels and only the whole side of the vinyl normalized as a whole - and also musical gaps. Maybe a dying art. I surely would like he OFFER to do a stem mix if a good master is just not possible with the mix AND there is no possibility for the artist to get a proper remix on their own. Good communication. Probably even before everything else. If an ME did not even ask about the mastering goals of the client, i would assume the guy doesn't know what he is doing. OK, and lots of the already mentioned points....
Post by M57 on Feb 26, 2017 16:01:25 GMT -6
Yeah, I have mixed feelings about that. I understand that there are a lot of people who feel they need to do whatever it takes to bring cash through the door. As far as clientele who reside at the edge of the industry are concerned, I question whether it's really a good idea to encourage those who don't have what it takes to do their own work, given the glut of unqualified people on both sides of the glass. I dunno, there's a lot that I have to say about this from a lot of angles, but I'm not sure if this is the place to do it. Sure it is. The thread is about expectations, so your opinions are on topic as far as I'm concerned. But I submit that everyone is qualified to write and record music. No one is unqualified. It doesn't mean that individuals can't have standards. If someone hits the record button on their iPhone and records their dog wailing and then sends it to an ME, he has every right to refuse the business. I understand that reputations are at stake. When I talk about the fringes of the industry, I'm talking about anybody who spends or receives money to make music. As far as I'm concerned, that starts with your first guitar lesson. We all started somewhere, and we're all at different places right now. There are many teachers who only take students at certain levels, music schools that have auditions, right on up to the major labels that impose the highest of standards. Aria doesn't care if it's Beyonce or your dog. Bob O., Jcoutu, or >insert name ME here< on the other hand could very well turn down my business if they don't want their names associated with the end product, or they could specify to me what I need to fix, or even tell me that I should get it mixed by a professional in a "real" recording studio before they are willing to get involved. They might hate the music, the message, the performance, the choice of microphones and pre-amps - and in every case, it is their right to turn down the business. I don't think we're necessarily in disagreement about this. Any M/E, could in all good conscious discourage me by suggesting that I sell my equipment, give up trying to record my music at home, and spend it in a proper recording studio. If I hold their opinion in high regard, I'd have to consider that as an option, however briefly I'll bet it happens all the time, and on both sides of the glass.
Post by Deleted on Feb 26, 2017 16:13:52 GMT -6
And - i would like to get a recommendation of a good mastering engineer, if he can not do the master on his or the clients quality level or for any other reason that makes it impossible for him to master the piece of music. I.e. if the music is totally not his cup of tea and he thinks that someone else could forseeably get better results because of this or he is swamped and the client has deadlines and a dozen reasons i just forgot...
Post by cowboycoalminer on Feb 26, 2017 16:25:57 GMT -6
I want to preface this with "I wholly support NOT using stems - But I occasionally get them and I'm fine with that too. I'm guessing that most M/E's set-ups don't support this work-flow, but I'm just thinking hypothetically. Most ME's I know (including myself) do most of the "stem adjustments" digitally and then just run 'em all out of the main buss. This is a trickier one -- Although there CERTAINLY ARE mastering engineers that go WAY overboard on what they do with stems, some artists would just rather send in stems "just in case" -- And that "just in case" is usually something simple -- Maybe the client wants "excessive loudness" and it pushes the vocals down a touch too much. Easy to just add a dB to the vocals. Maybe it pushes the cymbals into cymbal sibilance (Cymbilance?™) and it'd just be easier to apply a little side EQ to the drum stem. Maybe the guitars just wind up being a bit too "thwumpy" (?™) and cutting a little 100Hz on the guitars makes lets the bass cut through as it did on the original mix. PLEASE KEEP IN MIND that I'm TOTALLY not suggesting that I (or again, most ME's I know) prefer to work this way -- Lord knows, I want the client's mix to sound like *the client's* mix when it's done. And I would argue that most of the time when a client insists on sending in stems, I just set them all at unity and do whatever I was going to do in the first place. That said - I *do* know of a few guys who actually *prefer* to use stems from the start. And some of those are followed up by forum threads by folks who are pissed off because they went all "remix" with their stems. I'm not trying to defend the use of stems - But it's not the use of stems that's evil. It's what *some* people do with them. And almost without fail, the better sounding mixes have no reason to use them anyway. Great to have you on board, John! Lots of knowledge here with John, Brethren.
