Post by kcatthedog on Feb 21, 2017 18:42:59 GMT -6
Just curious,whose actually using a console as opposed to being ITB ?
I am thinking about a 10 slot 500 series stuffed and also thinking for that much dough you could buy a small board ?
Post by john on Feb 21, 2017 19:15:49 GMT -6
I am using the X-Desk along with a bunch of stuff. Not using le box for anything but the mix down and occasionally some stems. Tracking and mixing my own productions and picking up random mix clients along the way. I'm using the Alesis HD24 for my tracking so the computer stays off until I'm ready to record the mix. Still learning a lot as I go of course. Tons of fun though. My day job is computer orientated so I worked hard to remove the mouse from my music world.
Which small board are you thinking of?
Post by tasteliketape on Feb 21, 2017 19:27:56 GMT -6
I found a Ramsa 4424 for a hundred bucks ,just mixing with it ,then out to my analog eq's .comp Haven't had it very long but really loving it so far , for a hundred what the hell.
Post by kcatthedog on Feb 21, 2017 19:42:12 GMT -6
I have no frigging idea what board I am thinking about I read all Tony C's Delta stuff with interest and chat with wiz a bit too. I like to mix in my daw to 8 aux and I have 6 ob pres, 5 comps and no eqs so started thinking about a 10 slot 500 series to get some eq's and a couple more comps and to use them for tracking and mix down. Thinking bout capi bt50, electra, LTLO Chroma etc.. But also think hmm a board with good eq would be useful too ?
Post by tasteliketape on Feb 21, 2017 21:05:31 GMT -6
Just a follow up I doubt that I'd use the Ramsa to record thru just summing.
Post by ericn on Feb 21, 2017 21:18:05 GMT -6
Depends on project prefer OTB, need to find a new home for the Status so I can put the DDA back together!
Post by svart on Feb 22, 2017 5:46:48 GMT -6
I do most everything but bussing of certain instruments OTB through a console. I'm never going back to ITB!
Post by stratboy on Feb 22, 2017 6:14:00 GMT -6
I sum through an APB board. With the board zeroed out, I can compare these two chains: Motu 16a > APB > 2 bus chain > monitors (16 sources summed OTB to 2 ch) vs the same 16 sources summed ITB > Svart > 2 bus chain > monitors. It's not a perfect A/B test, but I always prefer the sound of OTB. There is just something inherently more interesting about it to me. YMMV.
Post by kcatthedog on Feb 22, 2017 6:56:22 GMT -6
Depends on project prefer OTB, need to find a new home for the Status so I can put the DDA back together! I'll bite: which Status ?
Post by ericn on Feb 22, 2017 7:22:56 GMT -6
18R 24 plus 4 stereo missing some knobs ( has all working pots) and dynamics! Sitting here in KC!
Post by Deleted on Feb 22, 2017 7:30:25 GMT -6
i sum through a 16 channel studer 962 at unity, with inserts on here and there (DIYRE Colour custom box), Lexicon PCM 60 reverb and master output through AML 2254, custom THAT4301 compressor and Solid State Pultec.
I do all my automation on Mackie MCU Pro for some physical touch, I really need to touch faders, dim lights and turn off computer monitor when mixing. Once automation is all written I put my feet up and print my mix.
Post by john on Feb 22, 2017 11:16:58 GMT -6
yes, reason I ask which mixer you are looking at is because I went down this rabbit hole some years ago. started with a small ramsa, then a big ass soundcraft, then x-desk with 12 slots of 500 series eq/compression. It was a dream boat but damn it was expensive so after some testing I let go of most of the spendy 500 series in exchange for a few sleeper rack units. Now the only 500 series I have are the Neve 542s, 2 Moog Delays and 2 API Eqs. I do have two empty slots though. Probably grab some dbx 560s and call it. I couldn't find a small mixer that would do more good than bad for under 2k. other than a used x-desk. I gotta tell ya, I love using this mixer and it sounds fantastic.
I am excited to see if and when Harrison makes their button-for-button fader controller for Mixbus. That could be a fun alternative to my current situation.
Post by mdmitch2 on Feb 22, 2017 12:07:20 GMT -6
I was in a similar boat a year or two ago, thinking about making a bunch of 500 series channel strips with preamp, eq, compressor. I ended up buying a 1987 Neotek Elite for less cash.... and I'm really glad I did. That being said, I can't imagine buying an older console unless you're willing to maintain it yourself. Mine was completely re-capped when I bought it, but I've still spent an enormous amount of time refurbishing the channels, center section, and power supplies.... fortunately this console is still in production, and used mostly off the shelf parts. But the same can't be said for the majority of consoles on the used market.
Post by johneppstein on Feb 23, 2017 0:17:46 GMT -6
I have a 32 channel Soundcraft DC2020 inline console with flying faders - which I don't use at present - and onboard patchbay. It's a pretty decent chip-based console, was Soundcraft's top of the line in the mid 90's AFAIK. I don't generally use the mic pres, mainly use it for mixdown. Paid 6 grand for it. Main things I don't like are that it's semi-modular with channels in blocks of 8, which is a service PITA and that the onboard computer that controls moving faders, mutes, routing, and metering sometimes acts up a bit and needs rebooting.
Post by drbill on Feb 23, 2017 9:08:34 GMT -6
If any of you guys really want to go OTB, I've got a BEAUTIFUL and lightly used D&R OrionX - automated, 48 in lines (96 inputs) and12 stereo returns - 120 total inputs. Along with killer Elco TT Patch bay. Just waiting for a new home.
I'm staying hybrid. Not going back to a console. Recall and all....
Post by Calvin on Feb 23, 2017 12:40:04 GMT -6
I was in a similar boat a year or two ago, thinking about making a bunch of 500 series channel strips with preamp, eq, compressor. I ended up buying a 1987 Neotek Elite for less cash.... and I'm really glad I did. That being said, I can't imagine buying an older console unless you're willing to maintain it yourself. Mine was completely re-capped when I bought it, but I've still spent an enormous amount of time refurbishing the channels, center section, and power supplies.... fortunately this console is still in production, and used mostly off the shelf parts. But the same can't be said for the majority of consoles on the used market. I love me some Neotek Elite. Grew up on that board, pretty much. If I had the space, I'd be looking to install one here at home. Will probably never happen. I'm pretty happy with the Hybrid approach since my little place here at home is devoted to overdub/mix. I just HAVE to have at least some real electrical current flowing through real electrical circuits, though. Full ITB just never felt right to me.
Post by jcoutu1 on Feb 23, 2017 13:28:13 GMT -6
Just curious,whose actually using a console as opposed to being ITB ? I am thinking about a 10 slot 500 series stuffed and also thinking for that much dough you could buy a small board ? Me.
Post by illacov on Feb 23, 2017 13:39:42 GMT -6
In all honesty, I'm seriously curious to see how poorly the modern boards fare vs the classics. I mean in terms of summing, headroom per channel, sonics etc...I honestly rely on EQ during tracking and mixing to have a setup where I don't have that at my disposal in an analog sense. I don't even mix on my console most times, but I print the channels through it to get the EQ and transformer mojo. That's even if I tracked with the same board.
I'm still thinking about building my own summing device, but approaching things differently.
Thanks -L.
Post by wiz on Feb 23, 2017 15:03:04 GMT -6
In all honesty, I'm seriously curious to see how poorly the modern boards fare vs the classics. I mean in terms of summing, headroom per channel, sonics etc...I honestly rely on EQ during tracking and mixing to have a setup where I don't have that at my disposal in an analog sense. I don't even mix on my console most times, but I print the channels through it to get the EQ and transformer mojo. That's even if I tracked with the same board. I'm still thinking about building my own summing device, but approaching things differently. Thanks -L. This is how I work... I use the board for its EQ and headroom and interfacing other outboard...and fader rides during reamping. I sum ITB though. cheers Wiz
Post by jimwilliams on Feb 23, 2017 15:51:48 GMT -6
All OTB here. The PC is only used for CD prep. The studio is pretty much the same as it was back in the 1980's except I use a HDR as a tape recorder. Music is done the old way too, play it again, Sam. I like organic music with real people playing real music in real time with real sweat, not programmed insect sounds. Editing is done in the next take like the way all the greats did.
The redesigned current feedback Soundcraft Delta sum amp offers a clarity and depth unmatched by any ITB sum solution. 30 MHz bandwidth, zero degrees of phase shift, 1.5 ppm IMD, -90 db stereo crosstalk at 10k hz, -130 dbu noise and a 2000V/us slew rate makes any analog mixer sound cloudy and any digital mixer sound thin and flat.
Stereo outboard also does better with that sum design, the Bricasti M7 fed analog retains better surround depth and separation than you get using the AES digital I/O ITB. All the other stuff is analog, Lexicon reverbs, a stack of comps, gates and EQ's and some odd balls. Some call me an oddball for this last century set up, but it sure worked good on those last century records.
Post by rocinante on Feb 23, 2017 16:20:50 GMT -6
Hybrid console here. Daw controller for recall through a modded Soundcraft Ghost at unity gain with all inserts connected to patchbay which connects all my hardware. Ive seriously had the worst month. Since breaking my femur, my 17 and 1/2 yr old dog died and my pc wont come on and i can't get to the summing mixer im building in the temporarily disabled condition i am in. Cant work either. Right now im building a daw controller/monitor controller since part of it is learning coding. I can sit in front of a laptop. I intended to have the Mx-72nv (my Neve ended line summing mixer) sitting beside the Ghost to do some testing but thats not gonna happen till i heal a bit more. Hybrids the life for me.
Post by Calvin on Feb 23, 2017 17:22:24 GMT -6
Hybrid console here. Daw controller for recall through a modded Soundcraft Ghost at unity gain with all inserts connected to patchbay which connects all my hardware. Ive seriously had the worst month. Since breaking my femur, my 17 and 1/2 yr old dog died and my pc wont come on and i can't get to the summing mixer im building in the temporarily disabled condition i am in. Cant work either. Right now im building a daw controller/monitor controller since part of it is learning coding. I can sit in front of a laptop. I intended to have the Mx-72nv (my Neve ended line summing mixer) sitting beside the Ghost to do some testing but thats not gonna happen till i heal a bit more. Hybrids the life for me. Wow, sorry to hear of the hard time you're having right now. Hang in there - things will improve.
Post by kcatthedog on Feb 23, 2017 17:24:21 GMT -6
ya rocinante; the worst is behind you !
Post by wiz on Feb 23, 2017 18:08:20 GMT -6
Hybrid console here. Daw controller for recall through a modded Soundcraft Ghost at unity gain with all inserts connected to patchbay which connects all my hardware. Ive seriously had the worst month. Since breaking my femur, my 17 and 1/2 yr old dog died and my pc wont come on and i can't get to the summing mixer im building in the temporarily disabled condition i am in. Cant work either. Right now im building a daw controller/monitor controller since part of it is learning coding. I can sit in front of a laptop. I intended to have the Mx-72nv (my Neve ended line summing mixer) sitting beside the Ghost to do some testing but thats not gonna happen till i heal a bit more. Hybrids the life for me. Sorry for your loss... RIP Wiz
Post by rocinante on Feb 23, 2017 19:32:20 GMT -6
Thanks guys. Cinder was a real beauty. A malamute and a real wolf looking dog. . The cancer had taken over her head and ... well she had done: 7 national tours, over 20 regional, and burningman twice. Alright I am done pissing and moaning. I have built a decent prototype monitor controller with some daw facility since i am stuck in front of a laptop. Midi and code, midi and code Oh what a wonderful world midi and code.
