Post by Ward on Feb 16, 2017 8:08:41 GMT -6
yeah I'm gonna test it to find out the root of the cause. there is also a usb hub linKing everything together. I wonder if that is the problem. Ditch it and see. These things were causing havoc for line 6 users some time ago. Oh boy... those multi-port hubs cause all sorts of problems!
Post by drbill on Feb 16, 2017 9:33:53 GMT -6
RME does.... it reports it to the DAW .... Doesn't pro tools HD do this as well? cheers Wiz I don't use Pro tools so I don't know. How does RME handle reporting latency to the DAW? It must use its own measurement routines that are separate from those built into the DAW, right? HDX. No problems. Calculates everything perfectly. Inserts, no problem. I don't know HOW it does it, but it does.
Post by ChaseUTB on Feb 16, 2017 10:56:48 GMT -6
I don't use Pro tools so I don't know. How does RME handle reporting latency to the DAW? It must use its own measurement routines that are separate from those built into the DAW, right? HDX. No problems. Calculates everything perfectly. Inserts, no problem. I don't know HOW it does it, but it does. Apollo and PT native HW inserts are perfect as well. Timeline and playback. HW on mixbuss, UAD latency hogs throughout. I think the interface is broken which is what I wrote above. I am saving up to go HD route for peace of mind and to be more " Pro " 😀😆
