Post by terryrocks on Jan 29, 2017 15:03:35 GMT -6
I recorded several takes of a tune last night so that i could quick swipe comp between sections. However, i forgot to group and select phase lock option before tracking. Does anyone know how i can swipe comp all tracks?
Post by kcatthedog on Jan 29, 2017 15:06:42 GMT -6
Are all tracks takes of the same recording or do you mean across different tracks but that are time aligned ??
Post by M57 on Jan 29, 2017 15:10:57 GMT -6
You can select phase lock after tracking. Shouldn't be a problem. In fact, I've never done it before tracking - don't see why it would matter.
Post by terryrocks on Jan 29, 2017 15:11:18 GMT -6
Takes done to a click
Post by terryrocks on Jan 29, 2017 15:12:25 GMT -6
I've had problems swipe comping mutitracks after the fact
Post by M57 on Jan 29, 2017 15:18:57 GMT -6
I have too, but only recently and it had an 'intermittent' type of feel to it. I think I was able to do it on a different set of tracks on a different project. May be a bug. Did you make any flex related adjustments to the tracks before phase-locking them?
Post by M57 on Jan 29, 2017 15:21:04 GMT -6
Maybe you moved oone of them moved a skoshby accident. Try re-dropping the tracks into the project "simulating recording them from scratch." That would be a good test.
Post by terryrocks on Jan 29, 2017 15:28:15 GMT -6
Thanks guys. I'll try it after work here in a bit.
Post by Martin John Butler on Jan 30, 2017 9:37:24 GMT -6
Ok, forgive me, but where and what is the Phase Lock. I've comped many times, but it was always the same track, and I chose between different takes.
Post by NoFilterChuck on Jan 30, 2017 11:16:24 GMT -6
Post by M57 on Jan 30, 2017 15:34:24 GMT -6
Ok, forgive me, but where and what is the Phase Lock. I've comped many times, but it was always the same track, and I chose between different takes. If you have a stereo track of something like a guitar or piano. Or any group of tracks where the mics were live and recording at the same time - if they are phase locked, any edits made to one apply to all. This is critical if you are using any flex time editing. This also applies when comping.
