Post by Johnkenn on Dec 19, 2016 16:00:24 GMT -6
Post by Guitar on Dec 19, 2016 16:01:59 GMT -6
I got some really nice digital cables from Monoprice. Have not tried this one, but I'd say go for it.
Post by john on Dec 19, 2016 16:32:26 GMT -6
I use a lot of monoprice cables along with my home grown mogamis. they are actually pretty stout. I had a few proco patch cables crash and burn faster than the monoprice. the monoprice cables are a perfect fit for cheap patchbays (joke)
Post by Johnkenn on Dec 19, 2016 16:41:50 GMT -6
I use a lot of monoprice cables along with my home grown mogamis. they are actually pretty stout. I had a few proco patch cables crash and burn faster than the monoprice. the monoprice cables are a perfect fit for cheap patchbays (joke) Well then that will be perfect
Post by mdmitch2 on Dec 19, 2016 16:51:26 GMT -6
I've had good luck with monoprice snakes, but their cables are usually cheaper to order directly from their website rather than amazon.
Post by lpedrum on Dec 19, 2016 16:55:05 GMT -6
I've bought so many Monoprice cables I've lost count. I haven't had any problems yet. And yes, you're better off to buy direct from the Monoprice site.
Post by jcoutu1 on Dec 19, 2016 16:57:41 GMT -6
I buy the GLS 6-packs.
Post by thehightenor on Dec 19, 2016 17:11:04 GMT -6
The only issue I've had with cheaper cables especially the Chinese Neutrik connector copies are they don't fit very tightly and can introduce less than reliable connections.
I'm not sure at line level, I could pick out a $10 cable against a $100 cable!
So if the connectors are up to it, these cables look ok for line level signal.
Post by lpedrum on Dec 19, 2016 17:23:34 GMT -6
The only issue I've had with cheaper cables especially the Chinese Neutrik connector copies are they don't fit very tightly and can introduce less than reliable connections. I'm not sure at line level, I could pick out a $10 cable against a $100 cable! So if the connectors are up to it, these cables look ok for line level signal. I've actually found the opposite with Monoprice XLR cables--a little snug but never a problem.
Post by john on Dec 19, 2016 19:32:51 GMT -6
I've bought so many Monoprice cables I've lost count. I haven't had any problems yet. And yes, you're better off to buy direct from the Monoprice site. Yes definitely order from the site. Off topic but if you need a flatscreen mount they have the absolute best deals out there.
Post by ericn on Dec 19, 2016 20:24:49 GMT -6
I've bought so many Monoprice cables I've lost count. I haven't had any problems yet. And yes, you're better off to buy direct from the Monoprice site. Yes definitely order from the site. Off topic but if you need a flatscreen mount they have the absolute best deals out there. Careful some of there mounts have zero safety factor in there rating ! I like the folks AT what was once ATM Flyware insist that every component be rated for at least 5 times the load at the angle of the greatest load! What can I say I'm the guy who goes to the circus and says the rigger is the most important person!
Post by ericn on Dec 19, 2016 20:30:24 GMT -6
The only issue I've had with cheaper cables especially the Chinese Neutrik connector copies are they don't fit very tightly and can introduce less than reliable connections. I'm not sure at line level, I could pick out a $10 cable against a $100 cable! So if the connectors are up to it, these cables look ok for line level signal. I've actually found the opposite with Monoprice XLR cables--a little snug but never a problem. The stupid thing about XLRS is there is no standard for the size of the pins or the contacts of the XLR! I have known guys who will only use Neutrik to Neutrik, Switchcraft to Switchcraft, Amphenol to Amphenol! Another guy will only buy gear with Neutrik or that doesn't use PCB mount XLRs unless it has either 1/4 or barrier strips! And you thought JW was picky!
Post by levon on Dec 20, 2016 0:33:44 GMT -6
Nay. Definitely.
Post by thehightenor on Dec 20, 2016 2:29:45 GMT -6
Here in the UK I've found a chap who makes up cables for me from Vann Dam cable and Neutrik plugs for cheaper than I can make them myself!
It's worth looking around for a local tech who offers a service like this as you end up with better quality cable for sensible money.
My whole rig is wired exclusively with Vann Dam cable with Neutrik connectors, when I was recently reviewing my insurance schedule I added up the cost of replacing every single cable and figure made me have a double take .... a whole studio of high quality cable gets expensive, make sure cables are a listed item on your Equipment insurance!
Post by lcr on Dec 20, 2016 7:03:45 GMT -6
I think hi-Z guitar cables are more effected by cable and connector quality than mic or line level. Maybe Im completely wrong, which is often the case, I can hear a drastic difference in guitar tone swapping cables, not as drastic with everything else.
Post by indiehouse on Dec 20, 2016 8:39:24 GMT -6
Wait, so cheap cables are okay but cheap Samson patchbays are a mortal sin? What the hell?
Post by jcoutu1 on Dec 20, 2016 8:46:49 GMT -6
Wait, so cheap cables are okay but cheap Samson patchbays are a mortal sin? What the hell? Ward, Bill, JW, and JE haven't popped into this thread yet. When they do, we'll hear about the sins.
Post by ericn on Dec 20, 2016 9:11:52 GMT -6
I'llbite One with cheap cables from a source like Monoprice is they don't spec the cable or make it so one batch can be pretty good, but your next order might surprise you!
Post by tasteliketape on Dec 20, 2016 9:39:35 GMT -6
All good points, also probably factor in how often is the cable going to be plugged and unplugged also. Cheap ones probably won't last as long being plugged and unplugged often.
Post by svart on Dec 20, 2016 10:23:19 GMT -6
I have some of the GLS cables. They've held up very well over the years, only 2 broken cables at the strain reliefs over many years of use. No noise or anything to complain of either. Connectors have always worked without bad connections.
The only complaint I have is that over time the conductors and shield wire get twisted inside the cable jacket making it lumpy. Even super careful wrapping just prolongs the inevitable lumpy cable. It still works fine though.
Post by winetree on Dec 20, 2016 20:21:29 GMT -6
Post by levon on Dec 21, 2016 0:06:46 GMT -6
20 cables for 80 bucks, cheap Chinese plugs included. Good luck:
It always amazes me that people spend a fortune on pres and microphones, discuss endlessly about modding capsules and Neumann mics and then buy cheap crappy cables. WTF.
Post by jjinvegas on Dec 21, 2016 4:49:23 GMT -6
Plus four over 24 gauge chinese lo mein with plugs that look fine on the outside and inside are pathetic. Every one i ever used let me down. soldering your own cables gets you connected to your devices in more ways than one.....
Post by jjinvegas on Dec 21, 2016 4:56:38 GMT -6
I have a big box of hook up if anyone wants a bargain. 24 channel insert snake, about 20 feet long with patchbay, half dozen eight channel TRS--TRS fifteen foot. Some neutrik, some Proco. Enough TRS to BNC ADAT snakes to hook one up down the block, other odds and ends.....
Post by mrholmes on Dec 21, 2016 5:31:59 GMT -6
Last year I have thrown away a big box with cheap cables done with cheap connectors. The cheapest I use in my studio is cordial cable from Germany with Neutrik-Rean-Connectors... ah and I solder them myself. www.cordial.eu/en.html
