Post by terryrocks on Dec 8, 2016 19:24:48 GMT -6
I scored a serpent audio sb4000 for a great price and want to use it both for various bus duties as well as master 2bus.
i will have connected to a bay so I can patch in as needed, but what i'm a bit confused about is how to use it for the 2bus.
if I want to use it while tracking, I'll need to compensate for delay, right? and if i want to use it as a 2bus comp, i'll have to monitor the stereo track it's writing to. just trying to wrap my head around some of the processes so i can prep for it's arrival
Post by kcatthedog on Dec 8, 2016 20:41:56 GMT -6
what daw are you using ?
Post by terryrocks on Dec 8, 2016 21:04:58 GMT -6
I use both logic and protools11
Post by kcatthedog on Dec 8, 2016 21:14:49 GMT -6
me too, logic is easy it has an i/o plug that acts as in insert and it can ping for you to establish delay time and you can set the output and input levels google logic tech help guy i/o plug I just got the stam 4000 so am setting up logic too.
Post by kcatthedog on Dec 8, 2016 21:16:00 GMT -6
Post by swurveman on Dec 9, 2016 8:44:04 GMT -6
If it's on a patchbay, unless I'm misunderstanding something- and assuming your preamp outs are on the patchbay as well, why would you have to compensate for delay? Just patch preamp(s) out->Serpent in-> Serpent out-> a/d ins->Daw stereo channel inputs matching a/d ins
Post by terryrocks on Dec 9, 2016 11:09:20 GMT -6
Yeah, using it on a stereo source while tracking would be the easiest configuration. I'm asking about using it as a bus comp on summed groups. I don't have any outboard summing capability, so the group stereo bus would have to be a send from my interface, patch thru the comp, and then returned to the interface. This is where my delay compensation would be required.
And then the thing that really sort of confuses me is using it on the master 2 bus. I guess I would just always master the return and the bounce in real time if I want my bounce to use the compressor.
Just trying to wrap my head around this workflow.
Post by jcoutu1 on Dec 9, 2016 11:51:04 GMT -6
And then the thing that really sort of confuses me is using it on the master 2 bus. I guess I would just always master the return and the bounce in real time if I want my bounce to use the compressor. You capture the return on a stereo track in your DAW and monitor that. If you have everything running out through outs 1-2, set the capture track to 3-4 and send that to your monitors. Pow.
Post by swurveman on Dec 9, 2016 12:24:58 GMT -6
Yeah, using it on a stereo source while tracking would be the easiest configuration. I'm asking about using it as a bus comp on summed groups. I don't have any outboard summing capability, so the group stereo bus would have to be a send from my interface, patch thru the comp, and then returned to the interface. This is where my delay compensation would be required. And then the thing that really sort of confuses me is using it on the master 2 bus. I guess I would just always master the return and the bounce in real time if I want my bounce to use the compressor. Just trying to wrap my head around this workflow. In that case, at least for my setup, I'd need a submixer. As far as mixing with a compressor on the 2-bus: In Cubase, I set it my 2 Bus compressor routing as an FX insert in the VST Connections. So, the routing to and from the compressor is predetermined. As an insert on the 2bus- which I access from the plugin menu- it does its thing and the post compressor signal goes to my main monitoring outputs 1/2. If I want to hear what the 2 bus sounds like without the compressor, I bypass it using the external FX plugin like interface. Cubase also has a ping for determining and compensating for latency times. I use this same process in Pro Tools, though my version PT11 doesn't have an easy way to bypass the external FX compressor plugin like interface. So, I just turn it off and then on. It does have delay/latency compensation. As far as the patchbay goes: I have the converter/interface outputs/inputs on one patchbay and my hardware on another. I use patch cords to go from my converter/interface outs and ins to my hardware ins and outs. They are the same connections as I determine in my External FX connections in Cubase and PT. The patchbay hardware ins and outs are non normalled in this configuration.
Post by mrholmes on Dec 9, 2016 13:01:09 GMT -6
I use both logic and protools11 In logic its very easy you use the I/O plug in and you ping for a round trip - logic sets the delay compensation. Just make sure you measure with the compressors in bypass, logic just needs to know the roundtrip latency.....
